RF
Audio files: 28
Posted: Fri Mar 20, 2009 8:44 am Post subject:
Yeah - I kinda like that, Rych Very interesting progression...
On my 4017's/4066 clip the frequency divisions are being switched in and out based on fairly random choices from other Lunetta circuits.
If you have a steady A (440) going in to the 4017's, the seven divisions you get out in notes are..
220 A
146.6666667 D
110 A
88 F
73.33333333 D
62.85714286 B
55 A
and from there the switching of the 4066's determines which of these you hear.
I was thinking of that old "Piaa Chord Egg" idea - but I guess filtering and VCA's were fairly important to that effect.... All I got was an Iron Butterfly organ solo wannabe.
I'll experiment a bit more tonight. That recording was literally the first thing I got out of it.
bruce _________________ www.sdiy.org/rfeng
(Herb Deutsch to Bob Moog ~1963) |
slacker
Posted: Fri Mar 20, 2009 10:22 am Post subject:
I like the sounds from the 4017 thing, it's pretty musical which I guess is because it's playing a chord.
Like Rych I'm not too sure I'd like to hardwire that much stuff just to do one thing. I'd be tempted to patch it out a bit to allow the different 4017s to be clocked separately and maybe make some of the divisions switchable.
Cool idea though. |
RF
Audio files: 28
Rykhaard
Posted: Sat Mar 21, 2009 8:55 am Post subject:
| RF wrote: | Still with the 4017 dividers...
Using one of the audio divisions (/7) to clock a counter which in turn modifies the audio which clocks the counters.
Also- audio rate divisions /2 /3 /4 /5 are switched in and out based on those same counters.
Just a short snip of hands off noodling ...
bruce |
Whilst there seems to be a great deal of change within seconds, listening to the track overall, there seems to be a great deal of repetition. Could there be a greater amount of change, within this setup, or is it going to be limited to a lot of the same variations?
In another view point - I DO like possibilities of repetition but I far prefer them if they can be slightly changed for opening up new possibilities. Lemme try this as an example
The repeating theme for a hookup:
- ABCDABCDABCDABCD
Make a single change
- ABEDABEDABEDABAED
Back to the first for a portion and then a different change part way through
- ABCDABCDCGBCDCGBCD
(Note in the 2nd change within the phrase, the 'length' of repetition also changes.)
Before I type more and confuse my explanation all the more .....  |
RF
Audio files: 28
Posted: Sat Mar 21, 2009 9:11 am Post subject:
Yep - I understand what you are saying...
The repetition is just the simple patch - For the pitch and pattern I'm using one shift register and a binary counter - so the repeating pattern could have certainly be lengthened - even to unrecognizable with a just few more counters involved.
Mainly on that patch I was experimenting with influencing the timings with the 4017's...being clocked by the audio.
BTW - I listened to your last clip again this morning I like the minimalist thing - very enjoyable.
Rykhaard
Posted: Sat Mar 21, 2009 9:38 am Post subject:
| RF wrote: | Yep - I understand what you are saying...
Otay! Thankee. (Glad that U understand me. My method of delivery in communication, seems usually, to confuse others. Someday I have to learn how to properly communicate. )
So then - has your earlier jury debate, come back with a decision as to the usefulness of the module itself? Is it worth building, as far as you went with it? If you feel there's enough possibilities for variation, then I'll go ahead a do a PCB for it. )
| Quote: |
Right then. Yesterday, I was going to mount 2 x CD4029's (4 bit up / down counter, not using the JAM inputs; but USING the Preset Enable as an 'Inhibit' function) to 2 of my 14 / 16 pin templates that I made the previous day ...... I realized I didn't have a PCB for the LEDs required though and was tired. Left it for later. I'll get those done then, as I don't yet HAVE any such counters in my machine.
| Quote: |
bruce |
!! Very cool! I've got a very strong desire to do some multi-tracking WITH that clip to expand it into a 'tune' as well. Also, with different multitracked versions. 1, along the improv. noise ideas and another, along the more structured format - i.e. turning a lack OF structure inTO a structured piece. Shall see what happens. (Also hope to start writing lyrics for it, to use it as my first lyric based noise piece that I've done, in YEARS.)
Totally off subject: I've started constructing the web page section for my Lunetta machine (url is below). Would you (or any other readers) by CHANCE, know of a good FREE (or shareware) web page editor that has WYSIWYG functionality??
(Just now considering dumping HTML-Kit's freeware one as there's no WYSIWYG functionality. )
I'm hoping to eventually develop this page into something of an 'information center' for Lunetta machines, explaining as many things about as I can, along with audio and visual examples of as much as I can - with user / viewer / person-reading commenting abilities / etc. - overall, to help readers who are curious / etc.  |
RF
Audio files: 28
Joined: Jan 31, 2003 Posts: 18260 Location: Durham, NC
Audio files: 228
Posted: Sat Mar 21, 2009 10:36 am Post subject:
When I was very young, I went to a lecture from a music professor at UC Berkeley. He was very entertaining; a big fan of Nielsen, as I recall.
Anyway, he said that there is someone's, I don't remember the name, law of composition - "Always twice, never thrice."
There is great wisdom in that little expression. _________________ --Howard
my music and other stuff |
Rykhaard
Posted: Sat Mar 21, 2009 12:23 pm Post subject:
| mosc wrote: | When I was very young, I went to a lecture from a music professor at UC Berkeley. He was very entertaining; a big fan of Nielsen, as I recall.
There is great wisdom in that little expression. |
The most immediate of which to my interpretation is: do it once then improv. upon it, but no more, as the original intent may be confused if not lost.
There're quite a few ways to take it, depending on application. Very cool.
I shall keep that in mind when setting down to do something with my minimalist piece that I last posted then. In parallel:
I'll do 2 additional multitrackings to it, separate from each other - so that the results are 2 new 'pieces'. One of them with the 'live improv.' thought and the other with a more organized and planned addition.
Shall post the results here.  |
Rykhaard
Posted: Sat Mar 21, 2009 12:27 pm Post subject:
| RF wrote: | Good idea on the web page! Sorry - I can't suggest an editor...
Not a trouble. In going back to my original search area (c-NET / Download), I again found n-VU which i'd originally found had been abandoned. (Liked it muchlee, but buggy). It'd appeared that there were a new version. (DL'd / reinstalled.) Barely any difference. In searching through it's Help - found confirmation that it HAD been abandoned due to bugs, but that it's OFFspring - Kompozer was the latest. Off to download that and try it out. )
| Quote: |
I think that minimalist bit deserves some multi tracking It'll be fun to hear what you come up with.
Read my adapted reply to Mosc, in relation. Shall see what happens.
| Quote: |
Re: the Jury.
I'm thinking there is a lot of possibility for mayhem. The 7 divisions of any clock or audio you feed it seems to be useful, and being able to switch those divisions on and off with other counters or logic has potential. I like the odd divisions - /3 /5 /7 - those might be more difficult to generate other ways.
I'm not sure about clocking each 4017 differently - I 'spose you could also reset each 4017 using Lunetta clocks/counters, too.... I have not yet tried either of these.
Anyway - Without the 4066 switches on the output it's this bit of circuit. Someone else throw it together and see what you think. |
Otay! That's all, good enough to me! When I do the PCB, I'll leave the clocking connections for each of the 4017's, OPEN so that I can assign them the same clock, or individual. If the latter works well, then I will finalize the front panel, for the switches. If not, then I'll leave them all to the single clock input.
Thank you for your further analysis! Looking forward to trying it out!  |
Rykhaard
Posted: Thu Apr 02, 2009 9:35 pm Post subject:
A short dual Slacker 4017 / 4051 Melody Generator demo |
I just finished recording this 3+ minute demo from the 2 Melody Generators that I built for my machine today.
It was recorded onto my Korg BR-600's stereo microphones. I hadn't expected that they would pick up the sound of me closing my metal cigarette case as well as Zippo lighter! Those are the first 2 click sounds in the tune. The later ones, are me flicking the switches for modulation ON and OFF on the 2 Liquid Voices that the Mel. Gen.'s are playing. 1 voice is hard panned to each side. (Though it's not as clearly noticable in the stereo microphone recording.)
No effects were used.
The recording starts off playing the fun melody that I had left it at, earlier this evening. About 1/3 of the way through, I adjust the clock speed of each of the 2 x 4 Bit Shift Registers that are both being driven by the same CD40106 oscillator, for their timing.
Approximately 1/2 way through the tune I change the panning for each of the voices, to the opposite stereo side.
Somewhere after that (when you start hearing more sharp clicking) I'm changing the modulation switches on the Voices, turning them On and off on each oscillator and finally shortly before the tune ends (and I've changed stereo sides again) I switch off all of the modulation of the voices, back to their pure selves and fade out.
I hope you like the example of this dual Melody Generator! I shall be building more of them in the future!  |
RF
Audio files: 28
Posted: Fri Apr 03, 2009 5:36 am Post subject:
The sound of a Zippo is as distinctive as the lighter itself is functional. Much more pleasing to the ear than the rough grating and plastic click of a disposable. I was a bit thrown by the metal case, though.
Oh - about the clip....
Interesting listening to the different yet related voices moving. Then as you increased the clocks that thing begins to scream.
Good job! Thanks for posting it!
slacker
Posted: Sat Apr 11, 2009 11:31 am Post subject:
I recently build some of Rych's 4023 oscillators, and finally got round to recording something using them this afternoon. It's just 3 of the 4023 oscillators clocked by 6 40106 oscillators, a bit of delay and a lot of knob twiddling. It gets a bit loud at the end so watch ya speakers
flight_of_the_oscillator.mp3
It's my attempt at a Rykhaard style live noise piece, hope he doesn't mind a bit of plagiarism. |
telstarmagikistferrari
Joined: Jun 16, 2008 Posts: 280 Location: Indianapolis, Indiana
Audio files: 43
slacker
Posted: Fri Apr 24, 2009 9:36 am Post subject:
| I like it, sounds like some sort of crazy robot insect swarm. |
RF
Audio files: 28
Posted: Fri Apr 24, 2009 10:07 am Post subject:
Great to hear your machine! More!
I'm expecting part of that was the 4051 pattern generator? What else was involved there?
Rykhaard
Posted: Fri Apr 24, 2009 11:56 am Post subject:
| slacker wrote: | I recently build some of Rych's 4023 oscillators, and finally got round to recording something using them this afternoon. It's just 3 of the 4023 oscillators clocked by 6 40106 oscillators, a bit of delay and a lot of knob twiddling. It gets a bit loud at the end so watch ya speakers
A great overall AD-VENTURE type of sound at the beginning!! Almost like a 'march'!
Is the deep hum at the bottom of the track, a Ground looping problem? (Like I have.)
1/2 way through, almost like laser blasts in a video game. Military equipment making noises, during a computer battle. Heh.
Great harmonics changes in the swept sounds! (The CD4023's??) The sound wonderful!!
Why the hell didn't I see this message earlier?? (2 weeks ago. )
What a GREAT live / improv. track!!
| Quote: |
Haha! Plagiarize away! I was far by, more'n happy with THAT performance!!  Last edited by Rykhaard on Fri Apr 24, 2009 12:01 pm; edited 1 time in total |
Rykhaard
Posted: Fri Apr 24, 2009 12:00 pm Post subject:
| telstarmagikistferrari wrote: | | here's a bit of random fiddling, not nearly interesting as some others posted here, but what the hey, thanks to RF for the synthesizer. |
WOWCH! As soon as it started in my headphones, it just about ripped my ears off!! Startled the crap outta me. Haha.
RIPPING!! It's almost like a noise machine being tortured!
Machine gun rippings ....... (1:55'ish)
Grinding the guts out! (2:20) GREAT SOUND!
The final grinding tears! (2:50)
Oh my friggin' gawd! That's a great aural assault track!  |
Audio files: 43
Posted: Fri Apr 24, 2009 1:16 pm Post subject:
Thanks Rych, (and the rest) coming from you that all means a lot!  |
slacker
Posted: Sat Apr 25, 2009 4:29 am Post subject:
Thanks for the comments Rych. I love the different textures you can get with the 4023 oscs, thanks for posting the design.
Yeah the hum in the background is from the cheap old guitar amp I use. I think it needs some attention, probably new power supply filtering caps. |
Audio files: 43
Rykhaard
Posted: Sat Apr 25, 2009 8:47 am Post subject:
| telstarmagikistferrari wrote: | Here's a little melodic stream of blips created with the following modules:
R/2R ladder
4024 divider clocked with a 40106
i discovered the pattern generator still operates with all of its switches turned to off and got interesting results; the 'default' melodic mode you hear at the beginning of the sample. |
Now I'm VERY curious about this one! Could you tell me:
- which pattern generator the 4051 is? Is it's Slacker's?
- if so, could you let me know how you patched it all together to see if I can emulate it on my machine?
(I love making melodies with my machine. Having different melodies playing against each other, works really well. ) |
droffset
Joined: Feb 02, 2009 Posts: 515 Location: London area
Posted: Sat Apr 25, 2009 9:37 pm Post subject:
This all sounds great !
Finally finished my WSG, so I'll upload some Lunetta/WSG mutant samples soon.  |
RF
Audio files: 28
Audio files: 43
Posted: Mon Apr 27, 2009 9:09 am Post subject:
three more samples of me messing around with RF's box. I love this thing. It really can make a wealth of different sounds. All of these rely on the R/2R ladder for the magic.
 Download (listen) |
| Filename: |
higrind.mp3 |
2.76 MB |
| Downloaded: |
1072 Time(s) |
 Download (listen) |
| Filename: |
higrind_0003.mp3 |
1.86 MB |
| Downloaded: |
1084 Time(s) |
 Download (listen) |
| Filename: |
higrind_0005.mp3 |
1.87 MB |
| Downloaded: |
1066 Time(s) |
