frequency shifter
Page 19 of 23 [574 Posts]
Goto page: Previous 1, 2, 3, ..., 17, 18, 19, 20, 21, 22, 23 Next
mono-poly
PostPosted: Mon Jun 01, 2009 1:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Zthee JH Serge panel pleasee Laughing
davebr
PostPosted: Mon Jun 01, 2009 2:43 pm    Post subject: Frequency Shifter
Subject description: FrontPanelExpress
jhaible wrote:
I heard about this, too, but never really tried it. I guess I'm wasting a lot of money with tick marks for pots that are made from rotated "I"s and such stuff.
JH.
I have used two colors for legends on a panel. I used dual position switches where the up controlled a completely different function than the down. I used different colors to group the controls. It worked well.
I used the 'scale-o-matic' to make HPGL legends for both full size and 3/4 size. The way the program ran, I had to make one HPGL for the major tic marks, and another for the minor tic marks. I then grouped these together with the hole and number legends. BTW, it really took a lot of trial and error to come up with the right thickness and spacing using this tool.
I have them in a 1U and a 2U template on my site.
Template
http://modularsynthesis.com/modules/parts/parts.htm
Scale-o-matic
http://stiftsbogtrykkeriet.dk/~mcs/Scale.html
sduck
PostPosted: Mon Jun 01, 2009 5:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
jhaible wrote:
sduck wrote:
Thanks, Jurgen. It's just a Front Panel Express panel.
That's the US branch of Schaeffer, isn't it?
Yes. They use the same software - in fact, although most of the original German programming has been translated into English, if you ever get an error message, they're always in German.
jhaible wrote:
sduck wrote:
Most people use the default white infill for all the engraving. Adding colors is a one shot price upgrade - I think 7-8$, then you can add any colors infills you want.
I heard about this option, but had never seen it till now.
I balance the added cost by saving money with no infills on a lot of it - on this panel, everything that looks white in the picture is actually not infilled - just etched aluminum, which looks really great in real life.
That's what I often do as well. I think it saved me 200 Euros on the the PolyKorg Clone front panel! Confused
The way I do panels is actually relatively inexpensive - the cheapest fonts they have, as much hpgl as I can use
JH.
Yes - I've saved a LOT of money by using Dave's and some other hpgl I've found. Definitely worth poking around on Dave's site, and the modularsynthpanels site for.
sduck
PostPosted: Mon Jun 01, 2009 7:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Calibration question -
I have a question at step 2. Shape 2 is fine - I get the triangle wave with rounded edges, easy to adjust. Shape 1 is odd - here's a picture of what I'm getting - the trimmer adjusts the width of that shape, but it's clearly not what I'm supposed to be getting - ? Any ideas?
 Filesize:  491.06 KB
 Viewed:  585 Time(s)
zthee
PostPosted: Tue Jun 02, 2009 1:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just got my FS1A up and running!
I think it works OK. Probably not. But it shifts the incoming sound up and down when I turn the knobs. Sounds instant sci-fi!
The only problem - it stops functioning after a few minutes. It just fades out slowly.. Need to look into that later. Right now I need to run more sounds through it! Very Happy
edit: After running my TR-606 through it I can hear that I got massive oscillator bleedthru. Will need to trim it in and hope goes away.
jhaible
PostPosted: Tue Jun 02, 2009 2:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks like something overdriven ...
Wrong resistor value somewhere?
JH.
sduck
PostPosted: Tue Jun 02, 2009 4:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Argh. I'll get out the dmm and go over them later.
I've had really good luck with component placement so far - never had a module not work because of it. So it's about time for something like this.
zthee
PostPosted: Wed Jun 03, 2009 9:11 am    Post subject: Reply with quote  Mark this post and the followings unread
http://www.thehumancomparator.net/606fs1a.mp3
The volume is very low, due to far from perfect recording conditions..
Besides the bleedthru I think it sounds right...?
sduck
PostPosted: Wed Jun 03, 2009 8:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
JH.
I've taken the board out, and have gone over it. No wrong resistors. Bear in mind that this is a copy of Dave Brown's build (and using his BOM), so there are some resistor changes - specifically R2 changed from 51K to 36K, and R51 is changed from 430 to 51K. There is also a 36K resistor added at pin 6 of U1. Would any of these make this effect? (Feel free to chime in, Dave, if you had a similar problem - probably not though)
I've also gone over the board with a magnifying glass (again) looking for potential solder shorts, but found nothing.
There's always the possibility that I hooked up my probes wrong (!?) - stranger things have been known to happen, and my 21$ ebay scope and diy probes are not exactly surgically precise. I did get step 1 accomplished with no problem. and the second part of step 2, so I know the equipment works to enough of an extant to carry out this calibration.
Anyway, thanks for any ideas!
davebr
PostPosted: Wed Jun 03, 2009 9:31 pm    Post subject: Frequency Shifter
Subject description: parts changes
sduck wrote:
[Bear in mind that this is a copy of Dave Brown's build (and using his BOM), so there are some resistor changes - specifically R2 changed from 51K to 36K, and R51 is changed from 430 to 51K. There is also a 36K resistor added at pin 6 of U1. Would any of these make this effect? (Feel free to chime in, Dave, if you had a similar problem - probably not though)
I had no problems. The three resistor changes are quite simple. Rather than an attenuator and inverting switch for the exponential CV, I changed it to a reversing style like the linear CV so it's wired similar to the linear CV circuit.
The other change is I used U8A as a summer for the diffout and sumout outputs. Since they are both 10 V pk-pk, I changed the gain to 1/2 so the summation would be 10 V pk-pk.
I see now that the reference designators are repeated between boards. I'll change my website to be more explicit.
sduck
PostPosted: Thu Jun 04, 2009 11:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Aha! I changed the wrong resistor. I didn't do enough background checking, so to speak, and changed the R51 on the wrong board (1). Hopefully fixing this will get things going. Thanks!
sduck
PostPosted: Thu Jun 04, 2009 7:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Getting closer. I switched the 2 resistors I had wrong, and managed to finish all the calibrations. It seems to mostly work, except it only shifts up. The big knob (manual) shifts up from approximately the center position, both ways you turn it from there. It's probably just a simple miswire of the pot, but I'm tired and will mess with it some more tomorrow. Everything else seems to work, more or less.
jhaible
PostPosted: Fri Jun 05, 2009 2:08 am    Post subject: Reply with quote  Mark this post and the followings unread
I bet it does shift down. Laughing
But if the amount of downshift is higher than twice the fundamental of the input signal, it's shifted "thru zero" and into the negative, and the negative frequencies are perceived just as positives, so you perceive an upshift.
Try the same thing with starting with a very small amount of downshift, and gradually increase the downshift. And, use a familiar input signal such as human speech, and the effect will be very clear.
Thru-Zero modulation is a mind-boggling thing!
JH.
ETA: Of course there could also be a fault somewhere in the circuit, where the spinning direction of the oscillator is changed. I just read you were tired, so what I wrote was my first thought.
sduck
PostPosted: Fri Jun 05, 2009 8:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
No, it's definitely not shifting down. Although depending on what I put through it, the effect is different also. I've checked the obvious things, like the pot wiring, and it all looks ok. I still haven't checked the various cv ins to see if the problem is pot related or not.
My first suspicion is that perhaps I've misread Dave Brown's wiring chart - I went over it about 35 times to make sure I thought I knew what I was doing before doing the wiring, so I'm pretty sure I got it right, and consulted with him about various questions also. I hope I didn't switch the INV1/INV2 connections to the DIFFOUT/SUMOUT connections.
My other suspicion is that I messed up something during calibration - I want to go over the last few steps again to be sure.
And I just haven't had a lot of time to do any of this - it's been pretty busy here, so I'm just grabbing a few minutes here and there to go over this stuff. I'll get it going eventually!
jhaible
PostPosted: Sat Jun 06, 2009 2:13 am    Post subject: Reply with quote  Mark this post and the followings unread
The upshift/downshift function is hardwired on the PCB, so it's unlikely that external connections are to blame.
Referring to http://www.jhaible.de/fs1a/jh_fs1a_schematics_board_1.pdf , I will explain how that part of the circuit works - then you should be able to trace what is wrong.
U3 separates the sign and magnitude of the linear control. (That is, of manual controls and CVs combined. For now, lets asume there is only one linear CV, from the "Manual" pot.)
"Magnitude" is sent to U4. You can measure that value at the anode of D3. It's always a *negative* voltage (actually, "-magnitude"). It should become zero for center position of the Manual pot (or the linear CVs combined being zero), and it should go gradually negative if you turn the Manual pot cw *or* ccw. I guess *that* part is working on your board.
"Sign" is sent to U2B. This also drives the (BiColour) Dir LED ("DirLD" connector). Here (U2 pin 7 - or just watch the LED) you should see the voltage jump from positive to negative when the Manual pot crosses center position. The sign signal controls J1 and J2, which change the spinning direction in the modulation oscillator. So if you have that switching signal at U2 pin 7, there's probably something wrong with J1, J2, D7, D8, R39, R43.
(I hope this helps. I will probably be away from the internet for a week or so.)
JH.
sduck
PostPosted: Sun Jun 07, 2009 6:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, I had another go at it tonight. I think you were right originally - it's shifting down just fine, I just had the range knob at the wrong setting for ordinary pitch shifting. I tried a bunch of various signals, and now that I know better how the different knobs interact I can get the sounds I'm expecting as well as a lot of really neat unexpected ones. I'm going to have to add the resistor to the feedback circuit someone mentioned earlier - feedback comes on much too quickly, and having finer control over that would be nice. So I think I'm happy! Thanks for the great circuit, Jurgen!
zthee
PostPosted: Tue Jun 09, 2009 12:51 am    Post subject: Reply with quote  Mark this post and the followings unread
I got my FS1A up and running yesterday! Had a faulty LM13600 in the compander - swapped it and now it works as it should!
Sounds awesome!
Thank you Mr. Haible for a very difficult but very fun module! Very Happy
Papareil
PostPosted: Sun Jun 14, 2009 4:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello ,
I have added complementary informations ( schematic , pictures , wiring )
about the buffer to output quadrature VCO triangle waves of the JH-FS1a .
It is here , middile of the page
http://m.bareille.free.fr/modular1/jh_fs1a/jhfs1a_mb.htm
Here are pictures of how the mod look like :
and what it produce :
Thanks,
Marc B.
Papareil Synth Labs
PAPAREIL SYNTH LABS
jhaible
PostPosted: Sun Jun 14, 2009 10:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Papareil wrote:
Hello ,
Thanks,
Marc B.
Papareil Synth Labs
Great!
JH.
zthee
PostPosted: Wed Jun 24, 2009 12:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Just wanted to share a sound sample from my FS1A.
http://www.thehumancomparator.net/FS1A.mp3
jhaible
PostPosted: Wed Jun 24, 2009 11:41 am    Post subject: Reply with quote  Mark this post and the followings unread
JH.
sduck
PostPosted: Fri Jul 17, 2009 5:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's a demo video I made of my build. There's very little to go on about this unit, to determine if it's working well or not, so I thought I'd post this, and perhaps Jurgen and others can chime in whether this sounds like it's working right or not. It sounds pretty cool to me. Don't forget to press the HQ button!
jhaible
PostPosted: Sat Jul 18, 2009 12:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool demo!
And the little notes that explain what's going on are really helpful!
And ... apparently that's the first appearance of any of my stuff on youtube!
Thank you.
JH.
TekniK
PostPosted: Sat Jul 18, 2009 1:39 am    Post subject: Reply with quote  Mark this post and the followings unread
excellent demo Steve,thanks!
Funky40
G2 patch files: 5
PostPosted: Tue Jul 28, 2009 5:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello,
i must layout my Frontpanels.
I don't know FreqShifters so i'm looking for a reference Frontpanel that has NOT omitted any controls.
Is any of the Panles with clear Pictures full equipet ? ( no attenuators or CV ins omitted ) ( outgain attenuation is not important for me )
cool , thanks.
