| interested? |
| yes |
97% |
[ 43 ] |
| no |
2% |
[ 1 ] |
| Total Votes : 44 |
JoeMorris
Posted: Fri Jul 17, 2009 10:25 am Post subject:
| excellent. count me in as soon as its ready. |
Funky40
G2 patch files: 5
Posted: Fri Jul 17, 2009 10:40 am Post subject:
| jhaible wrote: |
Yes, the TDA1022's. And a 1k tempco resistor. One 3086 (or 3046). The rest is garden variety stuff.
JH. |
only one TDA1022 ? |
2thick4uni
vtl5c3
Posted: Fri Jul 17, 2009 7:06 pm Post subject:
Thank you, 2thick! Didn't think to check evilbay. Got two on the way. I'll test them in my Triple chorus when they arrive. No way am I going to miss out on the SOST!!!
oldschool57
Joined: Nov 15, 2006 Posts: 17 Location: Bellerose, NY
jhaible
Posted: Thu Jul 23, 2009 11:04 am Post subject:
| Funky40 wrote: | | jhaible wrote: |
JH. |
Two
JH. _________________ "I tell you the truth, if anyone says to this mountain, 'Go, throw yourself into the sea,' and does not doubt in his heart but believes that what he says will happen, it will be done for him. Therefore I tell you, whatever you ask for in prayer, believe that you have received it, and it will be yours." (Mk 11,23f) |
vtl5c3
Posted: Wed Jul 29, 2009 12:56 pm Post subject:
Just got a packet with those TDAs from goodbuy711. They're mounted in white styrofoam and wrapped with cellophane. I don't have high hopes for these.
Spratty
Posted: Thu Jul 30, 2009 1:44 am Post subject:
| vtl5c3 wrote: | Just got a packet with those TDAs from goodbuy711. They're mounted in white styrofoam and wrapped with cellophane. I don't have high hopes for these.
I got some of these the other day, from this seller. Plugged two into my triple chorus and they seem fine (Queen belting out, "I want to break free" with extra "solina" mode on as I type ). Not the first or last time I'll get ic's in an odd package me thinks. What made me suspicious of them at first was how clean these really look. I guess it is possible that these really have been kept very well in a good environment. Some look like they are in the same series as the ones I got from Luka previously. Not that I'm an expert on chip stampings!
PS: Obviously can't vouch for all their items.
Spratty  Last edited by Spratty on Thu Jul 30, 2009 2:14 am; edited 1 time in total |
JoeMorris
Posted: Thu Jul 30, 2009 2:00 am Post subject:
| Crickelwood electronics have TDA1022s, not too cheap though. |
StephenGiles
Posted: Thu Jul 30, 2009 6:11 am Post subject:
£5 not too cheap?? I have never seen them so cheap in 20 years! Cricklewood were charging £50 each for their last stash of SAD 1024s a few years back.
Cricklewood is not a part of London that I would visit after dark! |
jhaible
Posted: Mon Aug 03, 2009 6:40 am Post subject:
UPDATE
Feature List:
Two BBDs - can choose long/short delay for left/right channel independently.
Long Resonance loop or short resonance loop
1/x modulation for "natural" Flanging
1V/Oct input (temperature compensated) for Physical Modelling
Approximating Thru Zero Flanging with All Pass Filters in the direct path and "rectified 1/x" sweep
ARP-Quadra-style compander and germanium diode clipping for ultra-smooth high-resonance sound
"Bounce"
4 Built-in Modulation sources:
Triangle Wave
Expo-slew'ed Square Wave
Sample & Hold Random Steps
Envelope Follower
Voltage controlled Modulation Rate
Built-in power supply (only need AC wallwart) or MOTM +/-15V supply
Requires two TDA1022 chips!
JH.
527.54 KB |
| Viewed: |
795 Time(s) |
numbertalk
Posted: Mon Aug 03, 2009 7:13 am Post subject:
| jhaible wrote: | UPDATE
Feature List:
"Bounce"
Triangle Wave
Envelope Follower
JH. |
Drool....when do you expect this project might be ready? Just when I was starting to actually catch up a bit on my JH queue too Hopefully I'll finish the Living VCOs and Varislope Filter before there are boards for this. |
jhaible
Posted: Mon Aug 03, 2009 1:59 pm Post subject:
Probably in 2 months if all goes well.
jhaible
Posted: Wed Aug 19, 2009 1:30 pm Post subject:
Prototype board populated - got the first sounds out of it - sounds very promising so far. As far as I can tell with alligator clips and all.
Too soon for real audio demos, but I'll keep working on it, slowly, as the baby allows ...
Keep up your interest, spread the information: a JH Flanger is definitely coming, if there is enough demand for a PCB run, and enough TDA1022's out there.
numbertalk
Posted: Wed Aug 19, 2009 1:32 pm Post subject:
| I am still very interested in this project! |
TekniK
Posted: Wed Aug 19, 2009 9:14 pm Post subject:
| jhaible wrote: |
JH. |
I missed this completely,i don't know why.
don't exactly know how manny,but will buy several pcb's |
whomper
Posted: Wed Aug 19, 2009 9:32 pm Post subject:
I am looking forward for this project and have already secured the required TDAs.
I have already two phasers in my modular and am deeply missing a Flanger to be hooked into the Neural Agonizer for some interesting sweeps and drones. _________________ Erez Yaary
Home Page: http://www.yaary.com
Buy my CDs at http://www.mellowjet.de |
oldschool57
Posted: Thu Aug 20, 2009 8:58 am Post subject:
Schematic?
Thanks for doing this! |
jhaible
Posted: Thu Aug 20, 2009 9:32 am Post subject:
| oldschool57 wrote: | Schematic?
When everything is tested and in its final version, I'll offer PCBs and publish schematics.
jhaible
Posted: Fri Aug 21, 2009 3:29 am Post subject:
Front Panel Preview |
That's what I'll put my prototype behind ...
JH.
158.73 KB |
| Viewed: |
772 Time(s) |
TekniK
Posted: Fri Aug 21, 2009 5:22 am Post subject:
looks very complete
hmm wander how i gonna crop that into a 5u panel |
jhaible
Posted: Fri Aug 21, 2009 5:56 am Post subject:
| TekniK wrote: | looks very complete
I won't, but I'm sure somebody will!
You can either make a very wide 5U panel, or omit the modulation stuff.
TekniK
Posted: Fri Aug 21, 2009 7:02 am Post subject:
myes,depending on the potvalues,i will probably need to use concentric pots.
as soon as you have a wiring diagram plz post it juergen,can start the layout check for my panels |
jhaible
Posted: Fri Aug 21, 2009 9:01 am Post subject:
| TekniK wrote: | myes,depending on the potvalues,i will probably need to use concentric pots.
LOL, I haven't even wired it myself, yet!
TekniK
Posted: Fri Aug 21, 2009 12:50 pm Post subject:
| jhaible wrote: | | TekniK wrote: | myes,depending on the potvalues,i will probably need to use concentric pots.
JH. |
