 Forum index » Online Music
Diskenesia
Page 1 of 1 [25 Posts]
aquanaut
PostPosted: Fri Nov 26, 2004 11:12 am    Post subject: Diskenesia Reply with quote  Mark this post and the followings unread
just out of the oven. synth only...i was afraid how it would turn out but the mastering tentative kind of corrected a few annoyance. lesson number one: kik and harmony need to be mastered separately...now comments are more than welcome.
diskenesia.mp3
 Filename:  diskenesia.mp3
 Filesize:  6.15 MB
 Downloaded:  4610 Time(s)
Audio files: 226
PostPosted: Fri Nov 26, 2004 11:48 am    Post subject: Reply with quote  Mark this post and the followings unread
To me, the drum track sounds kinda scratchey, but I'm not into this sytle. Maybe that's the effect you want.
aquanaut
PostPosted: Fri Nov 26, 2004 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm not sure of what i want when i'm working or where i'm going... i kinda go with what the machine spits out. but your right there's some eq to do on the high end and on the mix stage it was more annoying than that. listening to it again i think there just a few sounds that needs to be tamed..and the kik..well that one is garbage.
paul e.
PostPosted: Sun Dec 05, 2004 10:17 am    Post subject: Reply with quote  Mark this post and the followings unread
cool track...enjoyed it as is...like the synth sounds in the background
btw..did you recently change your username... ?
Spiral Recordings
aquanaut
PostPosted: Sun Dec 05, 2004 10:43 am    Post subject: Reply with quote  Mark this post and the followings unread
ya i just changed it...the previous one was a symbol.
zynthetix
Audio files: 10
G2 patch files: 13
PostPosted: Sun Dec 05, 2004 12:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Neat track aqua. This one's in the playlist now. I like the absence of a kick and snare personally, so I wouldn't worry too much about the kick. Some percussive sounds struck me as scratchy, but not in a bad way. These percussive sounds contrast very well to the spacey pads in the background, so I'd not change them (just fix whats bothering you with it).
PostPosted: Tue Dec 07, 2004 6:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I like this one. I didn´t find any problems here at all.
Flickr
seraph
Editor
Editor
Audio files: 33
PostPosted: Wed Dec 08, 2004 12:38 am    Post subject: Re: Diskenesia Reply with quote  Mark this post and the followings unread
I find it pleasant Shocked
aquanaut
PostPosted: Wed Dec 08, 2004 2:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for listening. It was done with the instruments in Logic 7. The more i play with them the more i find how much they can't do what the XT and the Ultra can do in term of amplitude and pitch modulation.
i recently bought a m-audio usb midi interface..is it me or midi over usb is simply not tight. anyway that case is closed. the G3 with the old serial macman interface is way more precise..that little thing better not break.
thanks again
seraph
Editor
Editor
Audio files: 33
PostPosted: Wed Dec 08, 2004 3:17 am    Post subject: Reply with quote  Mark this post and the followings unread
when you say XT I guess you mean the Waldorf XT and what about this "Ultra" Question
aquanaut
PostPosted: Wed Dec 08, 2004 3:36 am    Post subject: Reply with quote  Mark this post and the followings unread
sampler Emu e5000 Ultra.
PostPosted: Wed Dec 08, 2004 4:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I have that big Steinberg 1 U Midex thingie. It uses USB. I am mainly using that one with the dual 1.2 ghz G4. Midi timing is OK, but not what I would call great. However it is far better than how I remember midi timing from way back in the 80s.
Flickr
aquanaut
PostPosted: Wed Dec 08, 2004 4:58 am    Post subject: Reply with quote  Mark this post and the followings unread
i have two drivers in there.
m-audio usb support
emagicusbmididriver
should i put the emagic driver somewhere else or it's essential
Carlo?
PostPosted: Wed Dec 08, 2004 5:00 am    Post subject: Reply with quote  Mark this post and the followings unread
do not move the drivers..
Flickr
seraph
Editor
Editor
Audio files: 33
PostPosted: Wed Dec 08, 2004 7:43 am    Post subject: Reply with quote  Mark this post and the followings unread
m-audio usb support
emagicusbmididriver
Carlo?
well...the emagic driver is needed in case you use their midi interfaces but as Stein says I wouldn't touch it Very Happy
PostPosted: Wed Dec 08, 2004 8:24 am    Post subject: Reply with quote  Mark this post and the followings unread
The Emagic USB drivers should be left alone. Apple might suddenly decide to update/patch it.. and now they have made a kind of integration of Garageband with the Logic products. Unless you really know what you are doing and why.... leave those files alone Very Happy
Flickr
aquanaut
PostPosted: Wed Dec 08, 2004 1:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks. i taught the emagicusb driver was only needed if you had an emagic interface. maybe this driver interfere with the m-audio one...i don't know..timing is not there. the 1/4 note is kind of slightly different all the time. its not so bad but when i used the g3 i saw the difference right away..upgrades Question Question waiting for tiger.
PostPosted: Wed Dec 08, 2004 2:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm... if the 64s are going Steve Reich in ya.. then I guess you should check the Logic settings. That app is deep. Carlo s probably an excellent diver.
Flickr
aquanaut
PostPosted: Wed Dec 08, 2004 2:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
i'm gonna look around again..it's the interface because the timing is fine when using an internal instrument.
if the 64s are going Steve Reich on ya
not sure i'm getting this one..you mean anal precision
PostPosted: Wed Dec 08, 2004 2:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
I tend to use a hardware MIDI clock with my system (I use a PC though). Software, in my mind, is too un-dependable (kernel interrupts, USB driver, USB physical, etc.) for generating a clock, so I sync software to external clocks, then calibrate for latencies. Audio has timed DMAs & buffers, so it is made to be accurate, but MIDI drivers are entirely software driven...very bad.
I have the Emagic AMT8 on USB...which is *supposed* to get really great timing under Logic (It more or less pre-loads the midi data to the AMT8, then sends it out when a clock arrives). I have never used it with Logic, so I think it reverts to a "standard" mode, which would be like any other interface. Timing doesn't seem bad, but like I said, I tend to have my software sync to my hardware.
So, in short, try using a hardware clock if you've got one, and sync Logic to that.
PostPosted: Wed Dec 08, 2004 3:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
I said Steve Reich, not anal..
Shocked
Flickr
aquanaut
PostPosted: Wed Dec 08, 2004 3:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
good idea. That might do the trick.
Carlo. There's one thing i find very annoying with Logic. Say you input midi note for a bassline with the mouse. If you go back and work on the drum part the lenght and the velocity info of the previous note is remembered. can you desactivate that?
aquanaut
PostPosted: Wed Dec 08, 2004 3:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey remember i'm french..i'm kinda bad with the english subtelties..even morse when it's mixed with norvegian humor.
phpspell does not seem to work with safari
PostPosted: Wed Dec 08, 2004 3:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
aquanaut wrote:
if the 64s are going Steve Reich on ya..
Music For 18 musicians
click here
Steve Reich composed the music in order to explore timing issues and phasing etc. Long story. Very Happy
Flickr
seraph
Editor
Editor
Audio files: 33
PostPosted: Wed Dec 08, 2004 4:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
I never input notes in step time so I would have to check the manual for that but it seems logical (pun intended) to remember "the lenght and the velocity info of the previous note" but I am sure you can alter that through key commands (maybe Embarassed )
