ARP Odyssey Oscillators
Page 10 of 20 [488 Posts]
Goto page: Previous 1, 2, 3, ..., 8, 9, 10, 11, 12, ..., 18, 19, 20 Next
rjd2
PostPosted: Fri Aug 14, 2009 3:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
related question: the pcb for the VCO in a 2600 is super small.
is this because its a very simple circuit, or is a portion of its function displaced to another place in a 2600? (wondering about a 2600-or even better a 2500-vco clone....)
Broadwave
Audio files: 6
PostPosted: Fri Aug 14, 2009 3:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
The module is small because it's only the core sawtooth oscillator - VCO 1 & 3 has the Square converter on the main board, and VCO 2 has the Square/PWM, Triangle and Sine on a seperate "stand off" board.
It's a great oscillator to fiddle about with though!
Synth DIY Projects
Musical Doodlings
rjd2
PostPosted: Fri Aug 14, 2009 3:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
ahh, dig it. sure does sound fantastic....
LetterBeacon
PostPosted: Sun Aug 23, 2009 12:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd just like a quick clarification on hooking up some of the pots:
The Coarse Freq pot I hook the centre lug to the leg of the 221K resistor, the left lug to ground and the right lug to +15v?
The Fine Freq pot I hook the centre lug to the leg of the 3.3M resistor, the left lug to -15v and the right lug to +15v?
The Manual PW pot I hook the centre lug to the leg of the 390K resistor, the left lug to ground and the right lug to +15v?
Broadwave
Audio files: 6
PostPosted: Sun Aug 23, 2009 12:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Everything is correct except that the Manual PW pot goes to -15v not +15v
Andy.
Synth DIY Projects
Musical Doodlings
Boerge
PostPosted: Thu Sep 10, 2009 7:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I have a problem with the Arp Dual VCOs: they don't oscillate. The only schematic I found (earlier in this thread, and also in an service manual) is quite different from the circuit on Andys PCB. Can anybody point me to the right schematic?
PS: I made a schematic with KiCAD, but it ist still very raw and I'm not sure yet if it's correct... it is placed here:
http://www.boergeweb.de.vu/pdf/ARP_Dual_VCO_1.pdf
Regards
Boerge
...ich will doch nur löten...
Broadwave
Audio files: 6
PostPosted: Sun Sep 13, 2009 8:48 am    Post subject: Reply with quote  Mark this post and the followings unread
This is the schematic for the Dual VCO (MKIII Odyssey), taken from the Service Manual, maybe you're looking at the original MKI Oddy schematics?
Andy
ARP Odyssey MKIII VCO.pdf
 Filename:  ARP Odyssey MKIII VCO.pdf
 Filesize:  309.1 KB
 Downloaded:  1030 Time(s)
Synth DIY Projects
Musical Doodlings
LetterBeacon
PostPosted: Sun Sep 13, 2009 9:52 am    Post subject: Reply with quote  Mark this post and the followings unread
I powered up my PCB last weekend and it mostly all works! I haven't got anything coming out of VCO2's pulse output but otherwise it sounds fantastic! Thanks Andy for a great PCB.
Boerge
PostPosted: Mon Sep 14, 2009 5:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Andy
Thank you. I found out over the weekend that the schematic is identical to the ARP Avatar VCO. The only things I have changed are:
2N5910 => I used 2N3906
CA3086 => I used CA3046
I'll try BF245 for the FETs this evening.
regards
Boerge
Boerge
PostPosted: Mon Sep 14, 2009 10:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ha! I got it! It works!
I soldered a 1.65k resistor instead the 16.5k. Who cares for color rings, when the sticker on the little bag says "16.5k"!?
Regards
Boerge
LetterBeacon
PostPosted: Tue Sep 29, 2009 8:48 am    Post subject: Reply with quote  Mark this post and the followings unread
I've finally got some time to try and debug the 2nd VCO which isn't quite working as it should. I've checked the wiring which it all seems correct so I'm a little stumped!
VCO1 seems to work fine - I get a healthy saw and pulse output from the respective outs. VCO2's saw doesn't have the same level as VCO1's and I get nothing out of the pulse output. I've attached some oscilloscope pics.
Where should I start looking for problems?
Thanks a lot!
PS. Each square is 2 volts on the oscilloscope.
VCO1 Saw Output - looks ok!
 Filesize:  125.06 KB
 Viewed:  294 Time(s)
VCO1 pulse output - looks ok!
 Filesize:  124.7 KB
 Viewed:  302 Time(s)
VCO2 Saw level - looks low.
 Filesize:  116.51 KB
 Viewed:  303 Time(s)
VCO2 Pulse output - non-existent!
 Filesize:  117.84 KB
 Viewed:  315 Time(s)
Broadwave
Audio files: 6
PostPosted: Tue Sep 29, 2009 2:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
I recently built an experimental single version of the VCO and had exactly the same problem - I did manage to fix it... but did I write any referral notes down - no of course I didn't Confused
I'm desperately trying to remember what I did, but first of all check the sync input. Do you have the switch fitted from VCO 1, because VCO 2 will have problems if you leave the sync input floating - It either has to have a signal from VCO 1 or must be tied down via the 100k and 150k right next to the sync switch pads.
The next thing is to check the CD4011 - I definitely remember there was also something about loading on the output (one of the nand gates is used as a buffer for the square wave output).
I hope this helps - next time I'm problem solving, I'll takes notes!
Andy
Synth DIY Projects
Musical Doodlings
LetterBeacon
PostPosted: Tue Sep 29, 2009 2:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
I do have the switch in and I can hear it syncing when I turn the switch on, so I assume it's working. I'll check the wiring in the morning just in case.
When you say 'check the 4011' do you mean check it's getting the correct voltages? I don't suppose you have a list of the correct voltages at the pins at all? I have a couple of spare 4011s so I'll try swapping them in.
Broadwave
Audio files: 6
PostPosted: Tue Sep 29, 2009 2:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
BTW, as an addition to this thread, I mentioned above a single VCO version I was working on. I was building a compact clone of the Odyssey - got as far as the two VCO's, S/H mixer, LFO, noise and VCF mixer, and then I got a MKIII Odyssey off ebay.
I guess I should finish this project... one day... maybe...
I've used 30mm sliders - the width of each section is the same as the Odyssey, but the depth is 4 inches shorter.
 Filesize:  183.19 KB
 Viewed:  287 Time(s)
No 3086! I ran out of them, so just used matched pairs of 3904's... works fine! Plug in VCO's not much bigger than the 2600 module.
 Filesize:  191.58 KB
 Viewed:  287 Time(s)
Synth DIY Projects
Musical Doodlings
forbin
PostPosted: Tue Sep 29, 2009 8:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Letterbeacon
what sort of travesty are you involved in? wearing a Moog tee shirt while fixing an ARP oscillator! No wonder your having problems!
LetterBeacon
PostPosted: Sat Oct 03, 2009 9:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Heh, I have tried it with my ARP t-shirt on but no luck either!
I tried some troubleshooting today and noticed something a little odd. When I turn up the Coarse pot on VCO 2 the saw wave increases in amplitude on the oscilloscope. I've tried swapping out the 4011 with a new one to no avail! The Sync switch appear to be wired correctly and I can hear it working too.
I've taken a video of the oscilloscope if that helps at all. It starts off with the Coarse pot completely CCW and then I turn it up. At about 0:28 I plug the oscilloscope into the pulse out.
omnitek
PostPosted: Sat Nov 07, 2009 11:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi everybody,
This is not about building a new oscillator but I hope you guys could help me since you seems to know the ARP Odyssey oscillators very well.
I'm trying to fix a white ARP Odyssey 2800.
The problem is that the octaves on VCO-1 are not linear. For example, if I play a low C on the keyboard the next C will be an A.
I made the adjustments like described in the service manual but I not able to get the octaves in tune.
I replaced the capacitors in the VCO-1 circuit. It improved a little bit the linearity of the octaves but I'm still not able to tune it properly.
Does anybody have some suggestions to fix this problem?
Thank you!
Nicolas
Broadwave
Audio files: 6
PostPosted: Sun Nov 08, 2009 3:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you!
Nicolas
The first thing I would do is replace the exponential transistor pair - that's the TZ81/581 - you can change them with a pair of 2N3904/3906's.
Andy
Synth DIY Projects
Musical Doodlings
omnitek
PostPosted: Mon Nov 09, 2009 2:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Andy
Thank you Andy.
I replaced them and the other transistors as well but I'm still not able to tune the octaves properly by half a tone.
Is it because I need to put a matched pair of transistors?
Nicolas
rjd2
PostPosted: Mon Nov 09, 2009 6:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
sorry if i asked this before:
could the CA3086's be swapped with matched pairs of either 2n3904's or 06's? i had a friend match up a bunch of these a while ago. curious-thanks.
Broadwave
Audio files: 6
PostPosted: Tue Nov 10, 2009 2:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, you can use 3904's, but they don't need to be matched - You don't even have to match the exponential pair, I've built several oscillators without matched pairs and they all work perfectly... great tracking and no high frequency adjustment Very Happy
I'm currently working on a new single VCO PCB (no CA3086/46) - I'll get the details up as soon as I can, but there's a pic I uploaded a few posts ago.
Andy.
Synth DIY Projects
Musical Doodlings
Broadwave
Audio files: 6
PostPosted: Tue Nov 10, 2009 2:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Nicolas
I've never had problems not using matched pairs before... maybe the problem is with the keyboard CV circuitry on board 1.
Sorry to be so vague, but I'm only used to working with later MkII's and the MkIII Oddy.
Synth DIY Projects
Musical Doodlings
omnitek
PostPosted: Wed Nov 11, 2009 7:47 am    Post subject: Reply with quote  Mark this post and the followings unread
I was comparing the voltages beetwen VCO1 and VCO2 and the pitch of VCO1 is shifting when I touch the grid of its JFET (Q6) with my voltmeter probe while there is no effect on VCO2 if I touch the grid of its JFET (Q13).
Is this a clue?
Thanks
Nicolas
emdot_ambient
PostPosted: Mon Dec 14, 2009 5:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
...long read through this fascinating thread...
Someone mentioned wanting to do the Little Brother. Thought I'd throw this out there just for posterity's sake: http://www.synthfool.com/docs/Arp/ARP__Little_brother_2950.pdf
emdot_ambient
PostPosted: Mon Dec 14, 2009 5:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
AndyR1960 wrote:
...I've lifted this from Thomas Henry's Build a Better Music Synthesizer - it's from his CEM VCO design. He used it on the Triangle output (which is also 0-5v PP) to convert it to 10v PP centered around zero.
I haven't tested it, but in theory it should be fine.
Did anyone test this?
Just wondering because I'm actually working on some CEM VCO's and need to bump at least the Triangle wave up to 10v PP centered in order to convert it to a Sine wave. I had come up with a theoretical design (a differential amp and some voltage step down) but this Thomas Henry design is much simpler...half the # of resistors and small enough I might be able to build it on the small experimenter section that's already on the PCB (old PAIA EKx boards).
