.pch2 to .syx conversion
Page 1 of 2 [26 Posts]
gomidas
G2 patch files: 6
PostPosted: Thu Dec 17, 2009 1:51 am    Post subject:  .pch2 to .syx conversion Reply with quote  Mark this post and the followings unread
Hi everybody
Is there a way ton convert .pch2 to .syx without the editor?
Thanks
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Dec 17, 2009 7:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I think it is sysex...
Wout
PostPosted: Thu Dec 17, 2009 8:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm ... not sure ... i have been experimenting with it some years ago ... sysex and patch format are nearly the same except that for sysex some other header / trailer must be present and the info must be packed in 7 bit fields instead of 8 bit fields ... will have a look at it once i get home tonight and find some time ... meanwhile :
http://electro-music.com/forum/topic-6226.html&postorder=asc
http://www.iaf.nl/Users/BlueHell/html/nm-open/nm-open-g2info.htm
for some info on formats.
gomidas
G2 patch files: 6
PostPosted: Thu Dec 17, 2009 5:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Guys,
it's always nice to hear from you Wink
Changing the extension won't do the trick...i'll try some other stuff later...
Thank you
PostPosted: Thu Dec 17, 2009 5:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry ... didn't find time tonight to sort this out ... and no, extension changing indeed won't do ... the data needs to be reformatted a bit ... i did write a program to do just that, but will need to search for it ... I will come back on this, promise!
cappy2112
PostPosted: Thu Dec 17, 2009 11:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Got source?
gomidas
G2 patch files: 6
PostPosted: Fri Dec 18, 2009 8:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey! Blue Hell! Thanks for your help!!!!
As you must know, my two G2 Engines do have broken USB circuits, so no Editor for me until the repair (I must change the two motherboards, it's gonna cost me some money but I am going to do it).
With sysex I wil be able to load nice patches inside my nords and work like that, MIDI Progam Changes are messy to work with sequencer anyway, sometimes they launch when you start your project(Protools, Live8) and sometimes not, also when you loop a clip(live) or a region(Protools) and the PC is inside that clip, the G2 will reload the patch...
I will also convert my patches to use them but I didn't make the MIDI CC# assignement on all of them, that make some sound kind of useless(what become a synth sound if you cannot tweak is parameter in real time?)
So as a special request.., please don't forget to mention your midi cc# assignement in your Patch Info Wink (I can also send a midi cc request from a BCR2000, but Info will be quicker)
Thanks
PostPosted: Fri Dec 18, 2009 11:35 am    Post subject: Reply with quote  Mark this post and the followings unread
I found pch2midi on my harddisk ... a windows program ... I did not test test it and it does have the Delphi source code ... if it don't work I'll look into it ... it wants to save the midi files as .bin files, but you can rename it to whatever seems best, its just a raw MIDI file ...
License blurb :
Code:
//  Copyright (C) 2006 Jan Punter
//  This program is free software; you can redistribute it and/or modify
//  it under the terms of the GNU General Public License as published by
//  the Free Software Foundation; either version 2 of the License, or
//  (at your option) any later version.
//  This program is distributed in the hope that it will be useful,
//  but WITHOUT ANY WARRANTY; without even the implied warranty of
//  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
//  GNU General Public License for more details.
//  You should have received a copy of the GNU General Public License
//  along with this program; if not, write to the Free Software
//  Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
//    lupd : 2006-03-25
pch2midi.zip
A pch2 (and prf2) to midi translator for G2 patch files
 Filename:  pch2midi.zip
 Filesize:  263.17 KB
 Downloaded:  877 Time(s)
gomidas
G2 patch files: 6
PostPosted: Fri Dec 18, 2009 1:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
P.E.R.F.E.C.T !!!!!!
It works with crossover on mac too, I will use it as a command line for big folders.
Blue Hell, THANK YOU VERY VERY MUCH!!!! You are the Man Wink
See you
Michaël
PostPosted: Fri Dec 18, 2009 1:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow Laughing it actually works & all? you tested that?
gomidas
G2 patch files: 6
PostPosted: Fri Dec 18, 2009 5:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
YES 101% working!
PostPosted: Fri Dec 18, 2009 6:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, good to hear!
3phase
G2 patch files: 141
PostPosted: Wed Jan 20, 2010 4:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
is the g2 able to recive patches via sys ex?
Akum420
G2 patch files: 11
PostPosted: Wed Jan 20, 2010 9:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's not working for all patchs for me ....85% working lol
PostPosted: Thu Jan 21, 2010 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes.
PostPosted: Thu Jan 21, 2010 10:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Could you post a non working patch? or did you mean that the sysex transfers do not always work?
Akum420
G2 patch files: 11
PostPosted: Thu Jan 21, 2010 6:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think it was a patch from the G1/NordLead converted to the G2 (.pch to .pch2). I check this tonight.
Akum420
G2 patch files: 11
PostPosted: Thu Jan 21, 2010 7:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Look at this one. I found what's the problem.
Only some characters in the textpad. It's probably easy to solve in the delphi source code. Btw, it's not a big problem.
n2lib1b1-06.pch2
 Filename:  n2lib1b1-06.pch2
 Filesize:  2.93 KB
 Downloaded:  1231 Time(s)
PostPosted: Fri Jan 22, 2010 8:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Textpad ... right ... that doesnt get stripped I guess while it should. Will have a look later ...
varice
Audio files: 29
G2 patch files: 54
PostPosted: Fri Jan 22, 2010 11:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I think the problem may be with the patch file generated by the g1 to g2 convertor - the 1.5 version is known to have some conversion bugs...
I loaded the posted problem example patch into the 1.40 Editor (not connected to a G2) then saved it back to disk. Comparing the two shows many differences, even the byte counts are different.
I would suggest that you try loading and saving the patch with the Editor and then try the pch2midi conversion on the new Editor generated patch.
varice
PostPosted: Fri Jan 22, 2010 2:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah, thanks for sorting that out Varice!
varice
Audio files: 29
G2 patch files: 54
PostPosted: Fri Jan 22, 2010 2:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
No problem.
I forgot to mention that the problem patch does load and appear to work just fine in the 1.40 G2 Demo.
I would test the new patch converted with pch2midi but my MIDI enabled computer is not connected to my G2X at the moment...
varice
Akum420
G2 patch files: 11
PostPosted: Fri Jan 22, 2010 10:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
The problem is the character in the red circle. What I don't realy understand it's than I have this character in many patchs and I can convert this patch without problem..
You can
-1 : edit the textpad part in the source code from the PatchConversion NordModularPatch
-2 : edit the ".pch2 to .syx" tool to accept this character
-3 : put the patch into the 1.40 Editor then saved it back to disk.
-4 : make a script to delete this character from all your patch :p
-5 : Do it manualy
I got the problem 1/10 patch. Well this is not a big problem.
 Filesize:  33.47 KB
 Viewed:  24760 Time(s)
varice
Audio files: 29
G2 patch files: 54
PostPosted: Fri Jan 22, 2010 11:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Strange... I do not see those characters in the textpad when I open the problem patch with my 1.40 G2 Editor or Demo on my Windows XP computer. Maybe a Windows option setting different on my computer than yours?
Can you confirm that you only see these characters with patches that are generated with the G1 to G2 patch converter?
varice
Akum420
G2 patch files: 11
PostPosted: Fri Jan 22, 2010 11:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
not exactly, I only see it with the NL to G1 to G2.
Edit : and with the G1 ModularEditor3_03 if I look the .pch before to be converted to .pch2, everything is ok, no weird characters
