today> Bill Fox solo tonight! Chez Mosc
TOM WHITSHIRE VCLFO PCB
Page 4 of 5 [105 Posts]
haxster
PostPosted: Sat Jun 27, 2009 9:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some Mac users are not able to see the layout file. I made a 600dpi picture of the silkscreen incase you can't see the small lettering
 Filesize:  2.45 MB
 Viewed:  387 Time(s)
Luka
PostPosted: Sat Jun 27, 2009 10:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks haxter
so is there a schematic also?
i've seen the one at tom's site
but would like to see the your pcb version if poss so i can work out how and where to tweak to my needs
problemchild
melbourne australia
haxster
PostPosted: Sat Jun 27, 2009 10:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I have to do that. I will post soon. I just got express PCB schamtic all setup for my needs to make it faster.
a100user
PostPosted: Mon Jun 29, 2009 1:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Haxster,
Board and PIC has arrived.
many thanks
David
haxster
PostPosted: Tue Jun 30, 2009 10:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's the schematic for the DVCLFO core.
 Filename:  REV1.2_PAGE1.bmp
 Filesize:  866.31 KB
 Downloaded:  453 Time(s)
 Filename:  REV1.2_PAGE2.bmp
 Filesize:  866.31 KB
 Downloaded:  416 Time(s)
Luka
PostPosted: Thu Jul 02, 2009 5:51 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks mate
problemchild
melbourne australia
jojjelito
PostPosted: Mon Jul 13, 2009 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Drats! Missed out on both runs... Any chance of a new one? I would be in for at least 2 boards with PICs if that came to pass.
henrikgo
PostPosted: Sun Jan 10, 2010 9:20 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm about to finish up my LFO but there are a couple of caps that I can't find the value for. The ones marked with red.
haxster
PostPosted: Sun Jan 10, 2010 4:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
The one at the bottom is 0.1uf, that is for the GLIDE/portamento
The two Cap pairs are for the Analog LFO's. Pair them with values like this: 0.0047uf, 0.01uf. You are free to experient with values. The higher the cap the slower the LFO. For example 2UF NP will make it go really slow.
A good combo is like this: 0.00xx uF, 0.0x uF.
The Last one circled in red is an LED not a cap.
Luka
PostPosted: Sat Mar 20, 2010 11:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey haxster
im designing my panel for this
i noticed your schematic only shows a 6 position rotary switch, isnt there 8 waveforms (7+noise) ?
problemchild
melbourne australia
henrikgo
PostPosted: Sun Mar 21, 2010 6:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! I actually didn't get around to finish it when I asked, so one more question the Cap pairs for the Analog LFO's is the higher value Cap the ones closest to the TL074?
sduck
PostPosted: Sun Mar 21, 2010 5:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've got a pcb/pic set of this that I'm probably never going to get around to using - it's way down on the bottom of a huge stack of things that want to get built first. So realistically I should let them go to whoever wants them, for the 40$ US that I paid for them. These are from the first run. PM me.
Luka
PostPosted: Sun Mar 21, 2010 9:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
shame about that
i think this is an awesome design
phase distortion lfo!!
it is a shame it doesnt go into vco ranges
im going to make a mod pcb to get all the options out of the PIC too
problemchild
melbourne australia
haxster
PostPosted: Thu Mar 25, 2010 5:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
The cap values and where they go is not critical. The switch would toggle between them any how. So for example if I say the Higher value is the one Closest to the TL074. You can always flip your Switch on the panel if you prefer it your way.
Luka
PostPosted: Sat Apr 10, 2010 5:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
haxster
did you use this schem for the analog lfo?
i cant seem to get the square / ramp switch working
can you provide a wiring diagram for this for me
it is hard to know what is going on with no real schematic
problemchild
melbourne australia
haxster
PostPosted: Sat Apr 10, 2010 6:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah I used that circuit, I will open up the file and help you out. I am not home right now, I will do it when I get home.
Luka
PostPosted: Mon Apr 12, 2010 3:29 am    Post subject: Reply with quote  Mark this post and the followings unread
that would be great thanks
problemchild
melbourne australia
haxster
PostPosted: Mon Apr 12, 2010 10:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh wait I used the Soundlab Plus LFO not the Ultimate. I will have info soon.
Luka
PostPosted: Tue Apr 13, 2010 3:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
i finally found the schematic for sl-plus lfo
there is no link for it on the mfos site anywhere but luckily the page is still there and i was able to find a link to it on a forum thread
problemchild
melbourne australia
haxster
PostPosted: Tue Apr 13, 2010 11:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Did you figure it out yet or do you still have trouble? If I recall on the first run, the Analog LFO has the 1 2 3 labeled wrong I think i mentioned this on the previous page.
Luka
PostPosted: Wed Apr 14, 2010 1:15 am    Post subject: Reply with quote  Mark this post and the followings unread
my pcbs were from 2nd batch
i think i have got it now, yet to test
ive been working on my mods to the digital lfo today but ill test this again now
the problem was i had no idea how those numbers match the switch pins
even now that i have an idea of how to route the wires the numbers dont make sense to me
how can 1 and 4 mean the center pins of the switch?
is this correct?
i usually think that dpdt switches are like this
1 4
2 5
3 6
where as i think you have it like this
2 5
1 4
3 6
problemchild
melbourne australia
haxster
PostPosted: Wed Apr 14, 2010 1:22 am    Post subject: Reply with quote  Mark this post and the followings unread
It's like this:
1 is the center, then 2 is above, then 3 is below (that's one column)
2
1
3
next 4 is the center, then 5 is above, then 6 is below (that's one column)
5
4
6
Luka
PostPosted: Wed Apr 14, 2010 1:23 am    Post subject: Reply with quote  Mark this post and the followings unread
cool thanks
i havent seen those conventions before
problemchild
melbourne australia
Luka
PostPosted: Wed Apr 14, 2010 1:47 am    Post subject: Reply with quote  Mark this post and the followings unread
ok that works
my square is almost rail to rail whereas the tri is 10vpp
problemchild
melbourne australia
Luka
PostPosted: Mon May 10, 2010 5:42 am    Post subject: Reply with quote  Mark this post and the followings unread
so has anyone built their lfos?
i have finally got mine completed
the squarewave on the analog lfo was running rail to rail (30vpp)
i used a simple voltage divider (49k9/27k) to get it down to 10vpp
i also implemented vc-sample'n'hold, vc-waveform selection, vc-phase distortion
took a lot of work to get it going but it was worth it
im doing the 2nd one now
here is the panel
and the mess
problemchild
melbourne australia
