ach_gott
Posted: Sat Jun 26, 2010 12:00 pm Post subject:
magman wrote: | Here's my first attempt at a panel for this PCB in MOTM format (or almost).
It's a little busy, but I think it would work.
I like it. I think I prefer this with the small knobs. |
Posted: Sun Jun 27, 2010 5:12 am Post subject:
Skrog Productions wrote: | would it be easy to implement an incoming clock led ??. |
sure. i think a resistor and a LED would do. _________________
Tech Buddy at Random*Source |
janvanvolt
Joined: Nov 24, 2005 Posts: 285 Location: Mainz, Germany
Posted: Fri Jul 02, 2010 4:52 pm Post subject:
Here's my MOTM Version (which i am currently working on the PCB side).
Description: |
Filesize: |
99.09 KB |
Viewed: |
433 Time(s) |
Description: |
 Download (listen) |
Filename: |
VCPS2.fpd |
Filesize: |
2.05 KB |
Downloaded: |
460 Time(s) |
_________________ Homepage - http://www.czmok.de
My dIY - http://diy.czmok.de
Film/Music - http://gfm.me |
Posted: Tue Jul 06, 2010 3:33 am Post subject:
i eventually added the calibration procedure
to the current building documentation.
BTW nice one, jan. _________________
Joined: Jan 07, 2009 Posts: 1218 Location: Scottish Borders
emdot_ambient
Joined: Nov 22, 2009 Posts: 667 Location: Frederick, MD
Posted: Thu Jul 08, 2010 2:31 pm Post subject:
Nice looking blue design there, very logically laid out.
The color scheme reminds me of the design on old Deltalab Effectrons.  |
Posted: Thu Jul 08, 2010 3:29 pm Post subject:
Skrog Productions wrote: | Just a little problem to solve......
Do i have a problem with my gate ?? , my gate output , when all stages are set to 'on' , the circuit is outputing a constant gate voltage (12v ) (supply is 12v ) traced all the way back to pin 3 of the 40106 . |
not talking about the 12V here:
if all stages are 'on' there will be a constant voltage at the gate output. same goes for two subsequent steps that are both 'on': they will merge and form one long gate. that's the reason i added the trigger. the trigger length follows the clock width, thus generating seperate triggers/gates for all subsequent steps that are 'on'.
what voltage do you measure for a single gate? _________________
Posted: Thu Jul 08, 2010 5:29 pm Post subject:
Ah , ok , i understand now , silly me .
voltage at gate out on single is 11.22v.
Collector on Q5 11.88v.
Dave |
Posted: Thu Jul 08, 2010 11:02 pm Post subject:
sounds good to me. are you using an LM324 for the buffers? _________________
Posted: Thu Jul 08, 2010 11:07 pm Post subject:
BTW great module you've built. and it is good to have the LEDs near the step switches and pots... _________________
emdot_ambient
Posted: Fri Jul 09, 2010 8:45 am Post subject:
fonik wrote: | ...it is good to have the LEDs near the step switches and pots... |
That's what I was thinking. The designs I've seen with the pattern LEDs all together kind of confuse my old brain. I look at them and have to stop and wonder what they mean. Putting them near the switches/pots gives me instant visual feedback as to what's going on. |
Posted: Fri Jul 09, 2010 9:43 am Post subject:
fonik wrote: | sounds good to me. are you using an LM324 for the buffers? |
I am now .
i chose to use 5mm leds because im rubbish at crafting a nice rectangular hole in aluminium for the strip version leds heh , i also had lots in the component drawers to use up .
Thanks for the comments , i will get some audio tests up over the weekend.
Dave |
a100user
Posted: Mon Jul 12, 2010 12:19 am Post subject:
Very nice Dave,
I'll have to get mine built
David |
emdot_ambient
Posted: Mon Jul 12, 2010 9:20 am Post subject:
Nice one, Dave. I'm stoked about this sequencer...got 2 to build, but no enclosure to put them in.
I plan on controlling mine from one of the two M-185 sequencers I've got to build from ryktnk. The combo should be great. The M-185 is 8-steps but each step can be retriggered up to 8 times before moving to the next step. So it can act as a kind of song arranger, storing up to 8 pattern changes and/or CV transpositions over the course of its cycle. |
janvanvolt
janvanvolt
Posted: Tue Aug 03, 2010 11:21 pm Post subject:
glad you found out...
fortunately the labeling on the PCB and in the documentation is consistent, so it is just the orientation of the connector itself, that does not match the MOTM standard... _________________
janvanvolt
Posted: Wed Aug 04, 2010 2:23 pm Post subject:
nearly done with the rats nest last question: how to wire the (and to where) >0V and >5v LEDs (lowest two ones on your design panel) ? _________________ Homepage - http://www.czmok.de
janvanvolt
Posted: Wed Aug 04, 2010 5:10 pm Post subject:
I am still stuck with something:
- LED1 and LED2 now connected correctly (as i may assume), then with 95% turn of clockwise of the Offset i get the >5V LED lit. I NEVER got the <0V LED on, tested function by reversing LED1/LED2, so LED is definitely okay.
- Calibration does not seem to work, i still get fluctuations on the LED and cannot select the last pattern with T1.
@fonik: got a bit of time for troubleshooting ? seems a minor one, but i'm not able to find it. _________________ Homepage - http://www.czmok.de
Posted: Wed Aug 04, 2010 11:02 pm Post subject:
hallo jan,
do you use latest building documentation (06.07.2010)?
last pattern would be 0000000I (gray code).
do you use external voltage to light the <0 LED? _________________
janvanvolt
Posted: Thu Aug 05, 2010 2:14 pm Post subject:
i am using the latest build instructions including the calibration info, however still the same issue.
i connected LED1 and LED2 to those (>5V <0V), but i am not able to get the 0V one lit. what do you mean with "externally powered" ?
i tested the LED's and both _are_ working. _________________ Homepage - http://www.czmok.de
Posted: Thu Aug 05, 2010 2:36 pm Post subject:
the <0V LED does light when the CV is below 0V, this can only be hwen using control voltages that have negative excursions. you won't get negative voltages when turning the offset pots. _________________
diablojoy
Joined: Sep 07, 2008 Posts: 809 Location: melbourne australia
diablojoy
