today> Twyndyllyngs Chez Mosc
Haible Vokoder?
Page 16 of 20 [481 Posts]
Goto page: Previous 1, 2, 3, ..., 14, 15, 16, 17, 18, 19, 20 Next
TekniK
PostPosted: Sat Aug 28, 2010 2:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Was sagen sie? Cool
zthee
PostPosted: Sat Aug 28, 2010 3:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Awesome! wave
jhaible
PostPosted: Sun Aug 29, 2010 5:15 am    Post subject: Reply with quote  Mark this post and the followings unread
TekniK wrote:
Was sagen sie? Cool
Basically I apologize for how crappy it still sounds, but I'm happy that the basic vocoding works from the start, so I can now do a little debugging and optimizing. Smile
JH.
axxim
PostPosted: Tue Aug 31, 2010 12:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
No smoke = good
Sound = excellent!
Trimmpot adjusting = work Wink
Just a question about the caps: Did you simulated the filters with inferior (greater) tolerances? What was/would be the overall effect? Bandwidth spread vs. peak loss?
The questions are because my idea is to design a vocoder with its own oscillators for the carrier with the maximum SMD components as possible. I am also thinking of an hybrid solution, with a digital analysis section (more flexibility) and an analog carrier section (more "analogity")
_/\_><_><_|_//_
http://www.axxim.de/r3dias
KEYKEYEYEKIT
PostPosted: Tue Aug 31, 2010 5:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Amazing.
jhaible
PostPosted: Fri Sep 03, 2010 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Vocoder and Frequency Shifter (an alternative to cross patching?)
I found this old sound clip on my PC today. It's from a previous vocoder project (14 channels). The Speech signal is frequency shifted with the FS-1, and then used for vocoding.
http://www.jhaible.de/vocoder/fs1_and_vocoder.mp3
JH.
/mr
PostPosted: Fri Sep 03, 2010 4:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Pitch shift rather than frequency shift would probably be the adequate alternative...
and perhaps also the cheapest way. Interesting demo anyway! Smile
janvanvolt
PostPosted: Fri Sep 17, 2010 5:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
any news JH ?
My dIY - http://diy.czmok.de
Film/Music - http://gfm.me
jhaible
PostPosted: Sat Sep 18, 2010 12:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
janvanvolt wrote:
any news JH ?
Not much time to work on the vocoder.
Yesterday I have shipped quite a number of PCBs from older projects, plus my hand-built SOST Flanger with that blue front panel.
Today I was in Munich from early morning till right now, on an Alpha (http://en.wikipedia.org/wiki/Alpha_course) training course.
But the vocoder just needs a bit more tweaking - you can expect this project to happen, to 99%.
JH.
3vcos
PostPosted: Mon Oct 11, 2010 7:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hate to be a pest but I'm real excited about this project. Any news JH?
jhaible wrote:
janvanvolt wrote:
any news JH ?
JH.
jhaible
PostPosted: Tue Oct 12, 2010 11:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Works, needs minor debugging, will come as a PCB project.
I won't hurry it, but take care that it will really be right.
JH.
sonicwarrior
PostPosted: Wed Oct 20, 2010 1:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Florian Anwander wrote something interesting in a sequencer.de thread about the Doepfer Vocoder:
florian_anwander wrote:
1.) Das Wichtigste am Arbeiten mit dem Vocoder ist die Aufbereitung des Modulatorsignals. Das Modulatorsignal MUSS stark variabel im Obertongehalt sein, und es MUSS MÖGLICHST WENIG variabel im Pegel sein. Pegelmäßig dynamische Modulatorsignale sind ein Garant für unprofessionell dünn klingende Vocodersounds. Nach meiner Meinung gehört das Modulatorsignal bis "unter die Zimmerdecke" komprimiert (speziell bei Sprache als Modulator).
Die Bedeutung des Carriersignals halte ich für deulich überschätzt (sorry, Bernie). Ok, ein Sinus als Carrier bringt nix, aber die meisten Leute können zwar die Bedeutung der Eigenschaften des Carriers für das Ergebnis gefühlsmäßig einschätzen, aber nur die wenigsten können sich vorstellen, was ein gut komprimiertes und EQtes Modulatorsignal bringt.
2.) Das A129-System ist grundsaetzlich schon sehr fein. Das A129 kann aber erst dann die Möglichkeiten seiner Modularität ausspielen, wenn man die Analyse-Spannungen noch anderweitig verwurstet. Wenn man dazu keine Möglichkeit hat, dann ist ein einfacher digitaler Vocoder besser. zB fürs gleiche Geld kriegt man einen MicroModular, mit dem man fast die gleichen Sachen (und sehr sehr viel anderes mehr) machen kann.
Ich hab bisher vier analoge Vocoder besessen, und bin nun definitiv auf digitale Geräte umgeschwenkt. Grundsätzlich sind die meisten analogen Vocoder der Mittelklasse erstmal wegen der verwendeten Bauteile ziemliche Rauschgeneratoren, wenn die Signalpegel nicht ganz optimal sind (und zu der besagten Mittelklasse gehört einfach auch das Doepfer A129). Da haben die digitalen Pendants einfach deutlich die Nase vorn. Ich hab mal einen durchaus renomierten Vocodersammler "vorgeführt", indem er einen Alesis Metavox mit einem Behringerchorus dahinter für einen Roland SVC350 gehalten hat (also ca 120 Euro versus ca 650 Euro Gebrauchtmarktpreis).
Ich hatte selber SVC350, VP330, MAM VF11, Doepfer A129 und ich kenne den Sennheiser VSM201 ganz gut. Der Sennheiser ist der einzige, den ich für besser als einen Nordmodular-Vocoder halte.
Point 1 is the important stuff so I'll try to translate it:
The most important part for a work with a Vocoder is the proper preparation of the modulator signal. It has to be highly variable in the overtone concentration and lowly variable in the level. Highly dynamic signals are a guarantor for unprofessionally thin sounding Vocoder tones. IMO the modulator should maximally compressed, especially when using vocals.
I consider the importance of the Carrier signal highly overrated. Ok, a sine wave as Carrier is of no use but most people are able to estimate the importance of the properties of it emotionally, while few can figure out what a properly compressed and EQed Modulator signal is able to do.
I doubt it makes sense to include a compressor and EQ PCB because there are enough DIY projects for them but I think a note would be appreciated.
jhaible
PostPosted: Wed Oct 20, 2010 4:12 am    Post subject: Reply with quote  Mark this post and the followings unread
On the Living Vocoder, there is a simple opto-electronic compressor / limiter on board. And a one-knob tone control to adjust th ebalance between treble and bass. For detailed control, the channel attenuators (if implemented) serve as an additional 20-band EQ.
And a line-level insert path (send / return) for any compressor or outboard EQ you like.
That's for the Modulator.
The carrier has a compander system. As in Florians's quote, it might not be as important as in the modulator path. But it helps to run a wide range of levels into the vocoder without the need of much adjustment to this level.
And as there is companding, rather than just compression, the dynamic range isn't artificially reduced.
DIYers will find it easy to disable that compander, if not needed.
JH.
sonicwarrior
PostPosted: Wed Oct 20, 2010 10:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds very good. thumleft
Funky40
G2 patch files: 5
PostPosted: Wed Dec 15, 2010 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
JH.
good thing.
i need to plan finances.
Do you have any Idea in which timeframe we can expect the living vocoder Jürgen ?
jhaible
PostPosted: Wed Dec 15, 2010 2:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Funky40 wrote:
JH.
good thing.
I don't know. It sits here, 99% finished, and will definitely come as a PCB project. Certainly not this year (as I intended), but very likely in the first half of next year.
JH.
janvanvolt
PostPosted: Thu Mar 24, 2011 5:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Slowly i have doubts that this thing will ever become to life Sad
TheAncientOne
PostPosted: Thu Mar 24, 2011 6:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
As Jurgen might put in a sig line: "Oh ye of little faith..."
Mike
zthee
PostPosted: Mon Mar 28, 2011 4:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I was thinking of this this weekend.
Just wanted to chime in and say that when it happens I'm still on board!
Can't wait! Very Happy
Funky40
G2 patch files: 5
PostPosted: Thu Apr 07, 2011 6:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Jürgen, when it's coming, just let us know a bit ahead please,
so we can save the funds ( and i have to get back into soldering first Embarassed )
thanks
JoeMorris
PostPosted: Sun Apr 10, 2011 2:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
will we ever see another JH project again? Sad
TekniK
PostPosted: Mon Apr 11, 2011 12:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Juergen is moving houses atm,he will be back when he is settled properly
zthee
PostPosted: Thu Apr 14, 2011 5:24 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm excited to see if his new neighbors have a big fake palm tree as well!
Smile
jhaible
PostPosted: Fri Apr 29, 2011 2:44 am    Post subject: Status of the Vocoder project Reply with quote  Mark this post and the followings unread
All right, I've finished moving houses and slowly get back to thinking about electronic projects. The soldering iron isn't unpacked yet, and it will probably take some more time before I will pick it up again.
And yes, about the Vocoder. I have a really wonderful Vocoder now that is quite close to the big EMS 5000, plus some features from the Sennheiser and some of my own thrown in.
And it's finished to about 98% or 99%, and these last 1% or 2% are responsible for that huge delay of progress.
And honestly, I fear to complete it and offer it as a product, because
1.) It will never be a commercial success (i.e. it will never bring in the money for all the time I've invested in it), and
2.) I'm afraid of what can go wrong with such a huge project and what the customer reactions might be.
I think (1) is clear. So let me explain (2) a bit more.
You know that I can't give much support for debugging, hints on where to look in the schemos I've already published, and so on, for my previous projects. Which all are rather small in size.
Recently, I had a "customer" who outright denied to even look at the forum when I pointed him there for answers which he insisted to have answered from me personally. I pulled the emergency brake and sent him a refund for the PCB he boaugt, just to put an end to it.
I know that most of you are not like this, and that the community of this forum works very well to help one another and free me from most support work. I can only thank you for that!
But for a project the size of the vocoder??
I know what can go wrong with 1892 components, so I see a lot of trouble coming. For a project that will probably never be a commercial success.
That's, frankly spoken, the reason why I hesitate to pull it out of teh boxes and finish these final 1% or 2% of the project ...
I have an idea how to deal with this, though. But before I tell you more, please let me know your thoughts on this.
JH.
zthee
PostPosted: Fri Apr 29, 2011 4:23 am    Post subject: Re: Status of the Vocoder project Reply with quote  Mark this post and the followings unread
Shocked
That is horrible!
Even if this project came with null-zero-zip support I'd be in for it anyway. And the board can be €500 - no problem.
But please, take your time! If you have alternatives, please explore them. And hopefully this will happen.
Thank you Jürgen for doing this!
