Let's see your Lunetta!
Page 11 of 22 [526 Posts]
Goto page: Previous 1, 2, 3, ..., 9, 10, 11, 12, 13, ..., 20, 21, 22 Next
vbn9990
PostPosted: Sat Aug 14, 2010 10:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'll post some tomorrow. I just need to find one more 3.5 stereo cable. Shocked
Rykhaard
PostPosted: Sun Aug 15, 2010 7:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Deleted, manually.
Draal
PostPosted: Mon Aug 16, 2010 5:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Rockin'! Cool Looks like the Monolith from 2001. Makes mine look like a Happy Meal Laughing !
Zontar Prevails!
Rykhaard
PostPosted: Mon Aug 16, 2010 5:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Deleted, manually.
electri-fire
G2 patch files: 4
PostPosted: Sat Aug 21, 2010 7:35 am    Post subject: Reply with quote  Mark this post and the followings unread
The beginning of a fractal. Perfboard on perfboard. When it's full, you can mount a couple of these on yet a bigger perfboard.
sndbyte
PostPosted: Fri Sep 17, 2010 9:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi all,
I've been working on a Lunetta recently and finished up a full PC board full of modules. Below is a scan of my notes I used to keep track of what ICs I used as I built it. This is the actually layout on the small board. I'll take a photo tomorrow and post that.
 Filesize:  1.23 MB
 Viewed:  562 Time(s)
stolenfat
PostPosted: Sat Sep 18, 2010 2:53 am    Post subject: Reply with quote  Mark this post and the followings unread
i just recorded this very short video to show my friends why i've been locked away in my lab alot recently. its a proof of concept.
I get a little excited and drop some profanity near the end. apologies.
tjookum
Audio files: 26
PostPosted: Sat Sep 18, 2010 3:36 am    Post subject: Reply with quote  Mark this post and the followings unread
@sndbyte:
Excellent work! I think that is the most logic(phun intended) layout Ive seen yet, very good choice of ic's. Is it just bare perfboard or mounted behind a front panel? Can't wait to see some pictures.
I would also suggest a 4052 and some sort of 4017 sequencer, they are great for making rhytms.
@stolenfat:
Thanks for the video! Really nice machine you have going there, when did you start working on it? I really like the portable suitcase design, looks like a really playable design.
Hahaha, why do you think I use my line in on recordings Razz .
Hunter S. Thompson
movies
noise
stolenfat
PostPosted: Sat Sep 18, 2010 3:44 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for the kind words!
i wish those mixers were more responsive... i guess i'll have to try lower the pot value to 50k. they mute the sound until about 50% turned up, then its a very sharp rise, could be a log/lin thing but i bought those pots from an overstock place so i dont know much about em.
Rykhaard
PostPosted: Sat Sep 18, 2010 4:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Deleted, manually.
slacker
PostPosted: Sat Sep 18, 2010 4:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Great stuff guys, I really need to get back to my Lunetta and back over to Ryk's site to see what's been going on.
sndbyte
PostPosted: Sat Sep 18, 2010 10:41 am    Post subject: Reply with quote  Mark this post and the followings unread
I just took some photos of my work in progress. This took me about 2 weeks to build (being unemployed, I had a lot of free time last month). I got a lot of inspiration from the Absolute Beginners thread and the Lunetta Doc posted on this site.
This is the first time I built something without an enclosure or traditional panel. I decided to go the perf board route but I wanted to mount it on a board so it could be easily moved around (and even mounted on my wall!). The perfboard is mounted on a piece of painted wood (hammered metal spray paint). I have 2 perfboards. One large and populated and one empty and ready for more modules.
There is a 1/8 output jack but I also have 2 piezo speakers mounted on the back. You'll see 2 wires, one green, one red that are hooked up to the piezo discs. This is an easy way to quickly listen to the output of any point on the board without using an amp.
Also I should point out that I used 2 different type of sockets on the board. The square sockets are inputs and the round metal sockets are the outputs on a given chip.
I think there are over 80 leds on this thing (blue, red, green, orange, yellow and white). The leds are all clear so I slipped a piece of black heat shrink tubing around each. Actually, there are 8 square red leds for the sequencer... I forgot about those.
It is all run off of 5 volts with the exception of the WSG filter which is 9 volts. I also have a starve pot and a 3 input mixer.
Now I just need to figure out what to add on the expansion board!
Thanks everyone for your help, ideas and inspiration.
 Filesize:  197.83 KB
 Viewed:  384 Time(s)
 Filesize:  148.35 KB
 Viewed:  274 Time(s)
 Filesize:  137.86 KB
 Viewed:  308 Time(s)
Rykhaard
PostPosted: Sat Sep 18, 2010 11:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Deleted, manually.
Rykhaard
PostPosted: Sat Sep 18, 2010 12:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Deleted, manually.
electri-fire
G2 patch files: 4
PostPosted: Sat Sep 18, 2010 7:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, that looks good sndbyte.
My method to distinguish inputs from outputs thusfar has been to make multiple outputs and single inputs.
But I noticed you used another trick I've been thinking of but not done yet. You've grouped the outputs and the inputs together.
example: the 4015 dual 4-bit shift register (near topright of your board) has the outputs of section 1 at pins 5-4-3-10. Inputs for reset, data and clock are pin 6-7-9. Not very convenient indeed.
The back of your perfboard must look like a rat's nest of wires crossing to the proper in/ out assemblies on the component side, hehehhe... but I'd do it like that anyway on my next build.
Sweet!
sndbyte
PostPosted: Sat Sep 18, 2010 8:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, the rear of my perf board is a rats nest of short wires. I really wish I had taken a photo of the backside before mounting it. Below is a shot of the backside after I had finished the first 3 modules (40106 osc, 4011 NAND gate and 4001 NOR gate). You can also see my notes that I used to determine the placement of components in the 10 x 12 area which each module is allocated. I tried to place the inputs and outputs on the perf board so that they were easy to use.
 Filesize:  174.22 KB
 Viewed:  273 Time(s)
droffset
PostPosted: Sun Sep 19, 2010 1:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow sndbyte , that's very impressive! It's a very tidy build and looks like a lot of fun to play with.
Edit: Spelling mistakes.
tjookum
Audio files: 26
PostPosted: Sun Sep 19, 2010 11:28 am    Post subject: Reply with quote  Mark this post and the followings unread
thumb up amazing work sndbyte!
Where do I start? Ah yes, the looks Shocked . That is probably the best and cleanest lunetta I have seen so far. I really like the little sleeved leds, the ins/outs, black perf and you've really thought about the ergonomics of actually using it! I build mine in a quite similar way so I know how hard it is to do all the wiring underneath to keep it clean, it gets messy fast. You've done an amazing job, keep it up, and I would love to see a video of this pretty beast in action.
Yeah now you have all the basic modules in, you can try some other cool things. I would suggest a 4052, 4046 VCO and maybe a 4094? First thing that popped in my mind for that spot would be the trusty old breadboard, that combined with the basic modules would give you a very usable machine.
Very Happy Good to hear it has been of use to someone!
Hunter S. Thompson
movies
noise
sndbyte
PostPosted: Sun Sep 19, 2010 7:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the kind words. I don't have a video camera but I did attempt to make a video using a 6 year old Digital Camera. The sound quality is horrible as is the video quality itself. But if you like blinking lights you may enjoy it. There is no amplification, it's just 3 piezo disks connected to the CD4015 shift register. This will give you an idea of what kind of clicking patterns you can make with it. The only thing I'm doing in this video is slowly adjusting the 40106 osc that feeds into the cd4040 divider (which is the sample for the cd4015 shift register). The clock is not being adjusted at all (it is a mid range 40106 osc). The sound is really low and you may even need to wear headphones to hear it.
http://www.youtube.com/watch?v=7MqaJdqKXl0
Draal
PostPosted: Mon Sep 20, 2010 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Great builds guys! It's always nice seeing fresh stuff in this thread Very Happy .
Zontar Prevails!
stolenfat
PostPosted: Mon Sep 20, 2010 9:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
just recorded this wonky noise jam
tjookum
Audio files: 26
PostPosted: Tue Sep 21, 2010 2:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for shooting a vid! I actually really like the clicky sounds, I think the way the piezo turns on and off is very different from a normal speaker, this would be great for a percussion backing track. I would love to see a vid with some more light and good audio, try recording on the line in of your pc.
Very wonky indeed! That howling sound wasn't from your lunetta right? Keep it up and try recording seperate audio next time, it really makes a difference.
Really liking the new progress here, this forum was a little quiet a few months ago but it has picked up fast! Good job guys.
Hunter S. Thompson
movies
noise
corex
PostPosted: Wed Sep 22, 2010 1:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Rykhaard wrote:
The 101010 - also represent binary, as noise machines quite often are made up of digital circuitry.
Read upside down, the 101010, comes out as Oi Oi Oi Smile
And of course, the centred zero is the standard Anarchy symbol. Twisted Evil
Also, 101010 is 42 in decimal, which is as we all know the answer to life the universe, and everything.
RF
Audio files: 28
PostPosted: Wed Sep 22, 2010 4:25 am    Post subject: Reply with quote  Mark this post and the followings unread
lol Nice catch corex! Perfect Exclamation
bruce
www.sdiy.org/rfeng
Ajax
PostPosted: Wed Sep 22, 2010 9:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
That was, I believe, the realization that cinched it Very Happy
