2010 Build Pictures
Page 20 of 24 [576 Posts]
Goto page: Previous 1, 2, 3, ..., 18, 19, 20, 21, 22, 23, 24 Next
-minus-
PostPosted: Tue Nov 02, 2010 12:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes! Just noticed the MFOS text in the glass! That is superb! Very Happy The box is nice too! Great job!
Cardinen
PostPosted: Thu Nov 04, 2010 11:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Finally completed my Yusynth modular !!! Shocked
EdisonRex
Audio files: 172
PostPosted: Thu Nov 04, 2010 12:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow! That's beautiful. How does it sound?
Garret: It's so retro.
PostPosted: Thu Nov 04, 2010 3:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
that IS beautiful! great color scheme.
you decided to use different socket/plug standards for CV and audio, right? nice idea. gives a special look.
Cardinen
PostPosted: Fri Nov 05, 2010 8:34 am    Post subject: Reply with quote  Mark this post and the followings unread
@EdisonRex
It sound incredible !!! Laughing
@fonik
Yes,
i don't like the small plugs for audio, is more intuitive whit 2 type of connectors and this way i can plug my guitar in a filter for example.
For special modulation i'll use the 1/4" to 1/8" adapter.
TekniK
PostPosted: Fri Nov 05, 2010 9:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice built,one remark: use other screws to fix your modulles
TheAncientOne
PostPosted: Fri Nov 05, 2010 10:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Just finished a few 'Noisemakers' as a present for my ward Ollie - it was his 10th birthday, and the family were only in the UK for a few days. I had zero debug time, so I missed a minor assembly fault on the PIC synth's display. I'll sort it when I see them at Christmas - it works fine. The controls on the PIC synth are miniature sealed cermets, with integral knob. I got a batch virtually free in some scrap, (they cost over £5 each in normal quantities), otherwise I'd have gone for Alpha pots and ReAn knobs. The box is transparent red, so I just put a window in the panel overlay to let the display show through. Ollie had a hand in the panel design for the Cacaphonator, He wanted handles like my WSG, fortunately I found some old ones just the right size in the scrap box.
 Filesize:  387.99 KB
 Viewed:  403 Time(s)
 Filesize:  443.64 KB
 Viewed:  377 Time(s)
Mike
loydb
PostPosted: Sat Nov 06, 2010 8:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I bet he really likes that, nice build.
TheAncientOne
PostPosted: Sat Nov 06, 2010 9:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks: I think my next project for him may have to be a mixer, with a headphone output - his mum and sister are getting a bit of an ear-bashing at the moment.
I'm hoping to get an external audio interface to work on his net book, then he can do some recording.
Mike
PostPosted: Tue Nov 09, 2010 4:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
working on my backlog: after almost one year after i had this geat circuit on my breadboard the first time, i finally finished my dual thomas henry X-4046 VCO module.
TheAncientOne
PostPosted: Tue Nov 09, 2010 6:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very nice design Fonik, and very compact too.
Are you going to try an SMT version?
Really like your panel work as well.
Mike
adambee7
PostPosted: Tue Nov 09, 2010 11:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice matthias. Are you going to do a vid for it? got to get around doing that myself but got too much on. Very Happy Very Happy
dingebre
PostPosted: Thu Nov 11, 2010 2:07 am    Post subject: Start of my Synthasystem! Reply with quote  Mark this post and the followings unread
Thought I'd share these here, too. My Steiner Synthasystem resurrection is well under way. VCO, VCF, and Triple EG pictured here. I don't have a photo of the VCA. Also tested, Sequencer, Peak Selector, and Frequency Divider. I've got prototypes for a VC Trigger Generator, and Sample & Hold on order.
Triple EG
 Filesize:  256.03 KB
 Viewed:  240 Time(s)
Triple EG backside
 Filesize:  265.7 KB
 Viewed:  243 Time(s)
VCO
 Filesize:  237.13 KB
 Viewed:  243 Time(s)
VCF
 Filesize:  485.83 KB
 Viewed:  240 Time(s)
VCF backside
 Filesize:  250.06 KB
 Viewed:  238 Time(s)
dingebre@3dphysics.net
sndbyte
PostPosted: Sun Nov 14, 2010 9:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just finished a portable digital logic noise maker with 6 CMOS chips. I posted more photos and a description in the Lunetta section.
mini lunetta patched
zthee
PostPosted: Mon Nov 15, 2010 2:33 am    Post subject: Reply with quote  Mark this post and the followings unread
J. Haible frequency shifter.
PostPosted: Mon Nov 15, 2010 3:05 am    Post subject: Reply with quote  Mark this post and the followings unread
what a nice and neat work! so you made yourself a board for the front panel components? great.
zthee
PostPosted: Mon Nov 15, 2010 3:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you! Yes, made a board to mount switches and LEDs. It was easier that way... The pots are still hole mounted though. But that way I didn't have to have the ugly nut on the front panel. And just the pot shaft goes through the panel.
TheAncientOne
PostPosted: Tue Nov 16, 2010 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think that's great work - the panel layout is really good, Buchla himself could have designed it - it has that very functional look.
Nice and compact too.
Mike
bubzy
Audio files: 64
PostPosted: Tue Nov 16, 2010 5:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
apc with switchable caps and killswitch mods. cv in's on board but not wired up yet. built for a friend.
 Filesize:  119.43 KB
 Viewed:  221 Time(s)
mush
PostPosted: Mon Nov 22, 2010 12:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Built this controller:
More info at CDM:
http://createdigitalmusic.com/2010/11/alternative-musical-expression-a-diy-pressure-sensitive-multi-ribbon-controller/
TekniK
PostPosted: Mon Nov 22, 2010 1:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey thats damn awesome Shocked
PostPosted: Mon Nov 22, 2010 3:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
loydb wrote:
Finally completed my MFOS combo mini-controller and v/oct calibrator. Padauk, bloodwood and ebony carcase with a custom MFOS glass marble as a knob. For the full build blog, see my sig below.
Oh man! That's a thing of beauty! I sincerely apologise to Ray for not liking the design in the first place- as this has clearly proved me wrong!
ACHTUNG!
frijitz
Audio files: 54
PostPosted: Mon Nov 22, 2010 4:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
More info at CDM:
wow!
Are there any more details avaible on the sandwich construction? I wonder why you didn't need a fancy interface for deglitching like Scott Stites' ribbon controller?
Ian
mush
PostPosted: Mon Nov 22, 2010 11:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
frijitz wrote:
More info at CDM:
wow!
Ian
I did some de-glitching. I skipped the ground-pin on the hotpots and put a 10K ohm resistor between signal and ground instead. Not a fancy solution, but working great.
The sandwich is like this:
Front:
Middle:
Back:
I have some pictures of the construction, but I think you get the point from the screen-dumps above.
loydb
PostPosted: Tue Nov 23, 2010 9:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! I'm trying to get out in the shop this week to work on the Ultimate case.
