loydb
Joined: Feb 04, 2010 Posts: 393 Location: Providence, RI
frijitz
Audio files: 54
Posted: Tue Nov 23, 2010 11:32 am Post subject:
| mush wrote: | | I did some de-glitching. I skipped the ground-pin on the hotpots and put a 10K ohm resistor between signal and ground instead. Not a fancy solution, but working great. |
Thanks for all the info. Great project!
Ian |
Posted: Wed Nov 24, 2010 12:43 am Post subject:
and thank you for the inspiration (i still have the appendage to build). _________________
Tech Buddy at Random*Source |
Sound
Posted: Wed Nov 24, 2010 1:28 am Post subject:
@ Mush:
How are assambled the pressure resistors? from your site I understand that you used the " Standard 408 FSR"? Which are =~ 5mmX600mm and cut them? There is one pressure resistor for under each hotpot? |
haxster
Joined: Feb 01, 2006 Posts: 246 Location: MONTEREY PARK, CA 91754
Posted: Wed Nov 24, 2010 1:30 am Post subject:
I just finished this Serge Panel Format Modular Synth. No actual Serge circuits, I just like the Panel Size. The design is almost wire free. The VCO and VCF are the only items left with flying wires for the jacks. Next revision will finally rid me of the dreaded wire stripper chore.
This will fit on a Bud AC-423 Case.
[/img]
TekniK
Posted: Wed Nov 24, 2010 1:52 am Post subject:
wow all pcb mount pots,seems very clean inside.
looks to be 5u size serge is 4u
haxter i still wait for something from you,any news? |
haxster
Posted: Wed Nov 24, 2010 2:35 am Post subject:
| Sorry I have been busy designing this item. I just ordered another Midi converter pcb. But this is not like the acoupel version. I should get it next week. I still do have the item we talked about. From memory I believe the trimmers on the power supply need to be replaced. I have about 2 or 3 items i set aside that had something wrong with them (bad part or something). I just never got around to troubleshooting them. One thing I did not like about the acoupel converter was it did not have last key memory, meaning if you hold down 2 keys it will not return to the last key pressed. So it was not good for live playing but great for sequencer stuff. |
haxster
Posted: Wed Nov 24, 2010 2:44 am Post subject:
Yeah it is very clean.
The entire synth and power supply is on the panel. Yeah I was more into making sure it fit on those Bud Industy Boxes which is 7 inches High. But I remember I saw people mounting Serge panels on one. But perhaps it was not the actual format but just the look.
Check out this power supply:
TekniK
Posted: Wed Nov 24, 2010 4:23 am Post subject:
wow thats very pro haxster
You should let manufacture pro fronts and sell systems  |
alcofribas
Joined: Oct 03, 2008 Posts: 22 Location: Eastern France
Posted: Wed Nov 24, 2010 5:42 am Post subject:
@ mush
My head is flooded with questions. For now, just these three:
-- Since the FSRs are narrower than the hotpots, you had to put them on top, right? This is not ideal for precision, but then if it works...
-- You didn't need any special glue, just the provided adhesive backing?
-- How did you connect the FSRs electrically? The datasheet strongly discourages soldering. And you had to deal with strips you'd cut yourself.
This is mighty impressive. Technology on the march! |
mush
Joined: Jul 26, 2007 Posts: 56 Location: copenhagen noise lab, denmark
Posted: Wed Nov 24, 2010 7:31 am Post subject:
| alcofribas wrote: |
Nope, I put them underneath. Neither of them build much, so it the hotpots adhesive area reaches the bottom panel without any problem. So I just used the adhesive back on the hotpots and the FSRs:
I did solder the FSRs, it was no problem at all eventhough I haven't soldered anything for years. And I connected the FSRs like I did with the Hotpots. Show here below:
And yes I cut the FSRs down to size. You can actually use the left over parts like this guy did (first image):
https://ccrma.stanford.edu/~adam/250b/
| Sound wrote: |
Yepp, there is one FSR under each hotpot sending an separate CC. The other questions I've hoped I've answered above.
I have actually a patch in which I zone the strips in 8 zones, each zone is sending a separate CC, but you can only send one at a time per strip. But it gives 96 CCs from the controller. I can also make note on/off from these zones giving me a 96 key controller with polyphonic aftertouch from pressure and velocity from initial pressure... Soooo many applications for it, and I've just touch the surface (pun intended)! |
Sound
Posted: Wed Nov 24, 2010 12:16 pm Post subject:
| @mush thanks very much for the reply. This pressure resistor is very interesting, and your project awesome. |
Posted: Wed Nov 24, 2010 1:38 pm Post subject:
what a nice shot, man! _________________
LektroiD
Joined: Aug 23, 2008 Posts: 1019 Location: Scottish Borders
Joined: Mar 28, 2006 Posts: 1472 Location: Kansas City, Mo USA
Posted: Tue Nov 30, 2010 12:12 pm Post subject:
My 2nd Klee Sequencer is up and running! |
Unlike my first Klee Sequencer build, this one took quite a few evenings to troubleshoot.
I'm not sure why -- I just had quite a few wires reversed (nothing that damaged anything -- just switches and such. The worst thing was that I reversed SW40 and SW41 (the random switch and the pattern select switch) -- and as I tested the switches there was quite a bit of WTF??!!! before I found the error!
Frankly, headers and I don't get along very well and I prefer point-to-point wiring. I spent a lot of time straightening out and replacing the fragile contacts. There may be an easy way to do it but I haven't figured it out yet.
The good news is that, as usual, the troubleshooting process forced me to go deeply into the schematics and really learn how it works. So, it's all good.
1.43 MB |
| Viewed: |
259 Time(s) |
1.36 MB |
| Viewed: |
263 Time(s) |
_________________ -- Kevin
http://kevinkissinger.com |
emdot_ambient
Joined: Nov 22, 2009 Posts: 667 Location: Frederick, MD
Posted: Tue Nov 30, 2010 1:19 pm Post subject:
Re: My 2nd Klee Sequencer is up and running! |
| kkissinger wrote: | | Unlike my first Klee Sequencer build, this one took quite a few evenings to troubleshoot. |
Thing of beauty!
Must feel really really good to get that done and working!
Re headers: I'd think that working with that kind of header and ribbon cable might be more difficult than some other types...more easily confused at least...but I've never tried it myself. |
Posted: Wed Dec 01, 2010 9:29 am Post subject:
| emdot_ambient wrote: | Thing of beauty!
Thank you!
| emdot_ambient wrote: | | Must feel really really good to get that done and working! |
The feeling one gets from a finished module -- after all the sourcing, building, and troubleshooting -- is something shared by DIY people.
The Klee is a particularly satisfying build due to the complexity of the panel wiring and the density of components (108 Pots, LEDs, switches, and jacks).
In fact, sequencers in general are among the toughest projects, I believe.
| emdot_ambient wrote: | | Re headers: I'd think that working with that kind of header and ribbon cable might be more difficult than some other types...more easily confused at least...but I've never tried it myself. |
Usually, I don't switch wires but maybe I stayed up a little too late when I built the cables. I plan to switch to color-coded ribbon cable after my current supply is exhausted. I like the narrow, braided wire, though -- very easy to solder and desolder.
The contacts are a bit fragile and I've found that they often need a little adjustment (with a narrow needlenose) to assure that they are straight and that the barb is at the correct angle.
If I were to build another Klee (I don't plan to, though) I would likely do point-to-point wiring with sufficient slack to allow the boards to be serviced. _________________ -- Kevin
Scott Stites
Audio files: 96
Posted: Wed Dec 01, 2010 1:53 pm Post subject:
Very nice indeed! I'd agree on the point-to-point, too. That's what I plan to do on the next one. _________________ My Site |
emdot_ambient
Posted: Wed Dec 01, 2010 2:54 pm Post subject:
| kkissinger wrote: | | The Klee is a particularly satisfying build due to the complexity of the panel wiring and the density of components (108 Pots, LEDs, switches, and jacks). |
I just counted. The first panel I'm building (basically 2 complete synth voices in a 5U X 19" wide panel) has something like 148 pots, LEDs, switches and jacks!
...almost ready to order the panel, too.
Me skeered! |
The Bad Producer
Joined: Mar 08, 2009 Posts: 282 Location: The Manhole
tommi
Posted: Thu Dec 02, 2010 3:34 am Post subject:
Fonik's sequential switches (minimal version with no manual step and reset) on a stripboard!
962.41 KB |
| Viewed: |
237 Time(s) |
884.57 KB |
| Viewed: |
249 Time(s) |
_________________ http://soundcloud.com/mister-vommi
http://tideofsound.net |
droffset
Joined: Feb 02, 2009 Posts: 515 Location: London area
AnalogCustom
Posted: Thu Dec 09, 2010 2:06 pm Post subject:
BSS Block II |
BSS II, Blue Sky Synth block 2, by AnalogCustom
UPPER PANEL
LFO:
wf: sqr, saw+, saw-, tri, sin, staircase - and +
range hi-lo
rate
delay time
reset
wf select
level
pre-router: to osc or to filter, off
OSC, Buchla type:
wf: sqr, tri, shape (saw-sin)
frec coarse and fine
control cv, fm and shape
level out
pre-router: to filter, off
FILTER, Sem type:
cv and audio input
lo-hi-bp-nf outputs
LOWER PANEL
NOISE (MFOS type):
graininess control
sw noise select
level out
white, roaring, digital, grainy, random gate, random trigger
pre-router: white noise to s&H in
S & H:
CV clock with sync
clock out
pre-router: s&h out to lag in
LAG:
rise, fall
lin and log mode
TRANSIENT:
attack-decay and attack-release mode
pos and neg sw select
level out
pre-router: to cv clock
miniMIX:
only 2 in and out.
Panel: natural "Al" and custom letraset (laser printer).
Power: 7815 and 1915 fixed regulators.
Marco. |
cloudscapes
Joined: Apr 03, 2004 Posts: 24632 Location: The Netherlands, Enschede
Audio files: 321
Posted: Sun Dec 12, 2010 6:15 pm Post subject:
| cloudscapes wrote: | | just finished my looper / sampler / granular glitcher / mangler / drone noise thing! |
That looks great! Got any recordings? _________________ Jan
