problem with Ray's Multi Noise and Random Gate/Trigger Gen.
Page 1 of 1 [7 Posts]
PostPosted: Thu Jun 02, 2011 4:35 am    Post subject: problem with Ray's Multi Noise and Random Gate/Trigger Gen.
Subject description: only 20% grainy adjustment
I just finished building the MFOS Multi Noise and Random Gate/Trigger
Generator and most of it seems to work correct. I did have some problems
with getting the amplitude of the initial noise generator stage high enough.
Tried several 2n3904's but I kept getting an average of only 2-3Vpp with a
6V peak. Breadboarded it with the same results so tried a BC547 and that
worked great.
White noise works, digital noise seems to be find too, roaring noise
sounds, well, roaring (and looks like a sort of triangle wave on my scope)
so no problems there.
But then I get to the grainy part which kinda works but only the first 20%
of the pot seems to be usefull, beyond that point it doesn't do anything.
(the gate ouput stays high/low). I measured the voltages on the pot going
to the inverting inputs of the opamps, and they are what I calculated they
should be. Also breadboarded it but get the same results, so I'm kinda
stuck right now. Hopefully someone is able to help me out Rolling Eyes
edit: oops, forgot to mention that I'm using a -/+ 15V PSU
[post #250]
PostPosted: Thu Jun 02, 2011 8:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I've tested a bunch of transistors and found a better one which pretty much
solved it. I found a 2n3904 that was better but not quite 'loud' enough, also
tried some BC547C's which gave a very high output but settled on a BC547B.
I still have to turn the 10K trimpot almost to GND to get the full range of the
100K pot but it works Smile
jordroid
PostPosted: Fri Jun 03, 2011 7:51 am    Post subject: Reply with quote  Mark this post and the followings unread
I think the explanation for the lack of resolution of R20 has to do with the +/-15 volt power supply. IC1-D and IC2-C are comparators, whose threshold is determined by the voltage appearing on their inverting inputs, since your power supply rails are 6 volts farther apart it makes sense that a potentiometer referencing those rails would act differently.
You could try making R17 and R22 bigger, or make a little sub regulated +/-12 volt supply for just that pot, or any other way you can think of to reduce the range of the voltage appearing at the inverting inputs of IC1-D and IC2-C. Messing with R17 and R22 is probably the easiest thing, a sub regulated supply that eliminates the need for R17 and R22 is probably the "best" solution, but maybe overkill for a noisemaker.
regards,
jordan
PostPosted: Fri Jun 03, 2011 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the info Smile
you are correct about the supply voltage/comparator but I did try it on
+/-12V and it only improved slightly so the transistor plays a part in it too.
I'm probably gonna add some 12V regulators anyway because I noticed that
it's very sensitive to noise . It does have some ferrite beads, though I
have no idea if the ones I'm using really have much of an effect. I tried
adding some 10 resistors followed by some 100uF caps, that seems to work
but it's still not enough. So I hope some regulators will do the trick.
Snaper
PostPosted: Fri Feb 26, 2016 8:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry about stealing this old thread, but just finished this board, home etched.
Everything works...but have a few issues :
- ground hum on every outputs
- gate and rigger outs are not working
Used 3904 for the noise tranny, 084s and 4013.
Gate and trigger are on bananas, everything else on banana and jack aswell.
Tips?
Snaper
PostPosted: Sat Feb 27, 2016 10:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, hum problem solved : noise transistors emitter to ground instead of -15V.
Gate and Trigger out still not working Sad
wackelpeter
Audio files: 10
PostPosted: Sun Feb 28, 2016 12:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Already tried boosting the noise Level? It schould be around +/-5V... Maybe exceed that Level a bit to see if it's working then...
Also ray suggests some changes in the passive filter before the comparator when it doesn'T work properly...
Had some issues too after i build this... mostly picking up noises from the power rails, which i only got solved by adding Regulators and further 100nF caps before the beads and caps of the original power Input of my module...
