2011 Build Pictures
Page 13 of 19 [453 Posts]
Goto page: Previous 1, 2, 3, ..., 11, 12, 13, 14, 15, 16, 17, 18, 19 Next
Audio files: 160
PostPosted: Wed Jul 20, 2011 11:19 am    Post subject: Reply with quote  Mark this post and the followings unread
i like the clear panel , great stuff.
Spacehardware
PostPosted: Wed Jul 20, 2011 11:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks rosch,
I'm intending to build and sell this as a ready made synth in small volumes (to supplement the meagre income from my day job ), so no plans to make the code available.
But happy to answer any questions, and grateful for the feedback received.
ericcoleridge
PostPosted: Thu Jul 21, 2011 11:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow, this looks and sounds beautiful. Great work.
Spacehardware wrote:
Another year, another synth...
Just completed a wavetable synth module.
And uploaded a couple of videos:
Enjoyed Synth DIY UK last weekend BTW Smile
(Crawls back into the woodwork for another year).
darkomen
PostPosted: Sat Jul 30, 2011 8:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Finished a MFOS Soundlab Minisynth!
Everything seems to be in working order except for the AR generator, which doesn't seem to act quite right.
 Filesize:  1010.99 KB
 Viewed:  2074 Time(s)
Audio files: 160
PostPosted: Sat Jul 30, 2011 8:45 am    Post subject: Reply with quote  Mark this post and the followings unread
You'll have hours of fun with this Smile http://www.electro-music.com/forum/topic-39555.html , and i heartily reccomend blue colours on diy synths & gold , heh Smile
Great work , hope you iron out the A/R fault , usually something simple.
MirlitronOne
PostPosted: Sun Jul 31, 2011 9:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Okay, high time I unveiled the project that has been keeping me occupied for the last 18 months - behold The Mightier Mirlitzer (I prematurely named my Sound Lab 'The Mighty Mirlitzer' and now have to go one better):
 Filesize:  82.58 KB
 Viewed:  2116 Time(s)
Life is like an analogue sequencer. Twiddle the knobs to avoid boredom.
MirlitronOne
PostPosted: Sun Jul 31, 2011 9:36 am    Post subject: Reply with quote  Mark this post and the followings unread
The design criteria for 'The Mightier Mirlitzer' are as follows:
1. Keep it simple. Some of the modules are primitive but effective.
2. Each cabinet is approximately two feet wide and accommodates 8.75" (5U) panels. Standard panel widths are in multiples of inches (2" is the norm).
3. Each cabinet contains its own individual power supply giving +/- 12V at 1A (12V transformers are easier to find surplus than 15V ones). A power supply failure will only take out one cabinet, and each supply is sufficiently overrated to power a second cabinet in an emergency. In a REAL emergency, two 12V gel cells will do the job.
4. Each cabinet can play autonomously, containing at least one 'player' module (sequencer, pattern generator, S&H etc.) and at least one oscillator. Thus, individual cabinets can be extracted for demonstration or live use.
5. The MM is DIY down to the component level. Each module is built on stripboard or homebrew PCB. You can see that the front panels are colour-coded and no expense has been spent.
6. I have a 2' 6" wide gap between desks in my tiny home studio, in which fits a cheap veneered TV table. The MM is being erected vertically upwards from there. I figure I have room for six or maybe seven cabinets at a pinch. Two-and-a-half are filled (see photos); one will be a big sequencer and another one will be a Lunetta, offering both sound and timing signals for the rest of the monster, as well as operating stand-alone.
7. Eventually, the MM will meet the definition of a 'monster synthesizer', namely, if it falls on me, it will cause death or at least serious injury. Twisted Evil
 Filesize:  80.72 KB
 Viewed:  2036 Time(s)
 Filesize:  73.74 KB
 Viewed:  2013 Time(s)
 Filesize:  83.7 KB
 Viewed:  2020 Time(s)
 Filesize:  78.19 KB
 Viewed:  2009 Time(s)
 Filesize:  66.03 KB
 Viewed:  2046 Time(s)
PostPosted: Sun Jul 31, 2011 10:39 am    Post subject: Reply with quote  Mark this post and the followings unread
MirlitronOne wrote:
...behold The Mightier Mirlitzer...
Love it! Very Happy
MirlitronOne
PostPosted: Sun Jul 31, 2011 12:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
I forgot to mention that I used quarter-inch jacks because they're cheap, robust, reliable, compatible with everything else in the studio, and you can buy ready-made patch cords cheaply in a variety of lengths and colours. After all, who would want a black synthesizer? Wink
On the other hand, the Lunetta will use phono connectors. They're cheap, robust, small and can be connected with a bare wire and a matchstick in an emergency...
diablojoy
PostPosted: Sun Jul 31, 2011 2:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
that sure is puurty!
yes , wish i had thought of using those first up.
bod
PostPosted: Sun Jul 31, 2011 3:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
not technically finished as such, but i'm proud of my efforts so far and just got the prototype pcb's back from the fab house.
and populated it today.
its an analogue dub siren i built for a few friends, based around the amdek PCK-100 and the DS7. resettable LFO, Tri/Sqr wave VCO, decay envelope generator and VCA. i used the other half of the lm13700 to use as a voltage control for the VCO instead of it going to waste. the strip board version worked a treat so i'm keen to finish this to see how it holds up!
inlifeindeath
PostPosted: Sun Jul 31, 2011 4:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Finished Scott Bernardi's VC Delay circuit. So much fun so far!
http://www.youtube.com/watch?v=W17-Z0nMmx4
 Filesize:  668.74 KB
 Viewed:  1906 Time(s)
 Filesize:  948.78 KB
 Viewed:  1888 Time(s)
PostPosted: Mon Aug 01, 2011 6:43 am    Post subject: Reply with quote  Mark this post and the followings unread
that's exactly what I love about it,. the colors. Not that I don't like black,
but there's something about the combination of the colors, incl the knobs,
that I really like. It's like it brings back some sort of memory but I don't
know what memory. Smile
umschmitt
PostPosted: Mon Aug 01, 2011 7:03 am    Post subject: Reply with quote  Mark this post and the followings unread
That looks splendid ! I'm at the moment trying to expand my ol'DS7 (adding sq. wave, filter w/ CV/LFO/EG, additional EG, routable audio modulation, tri/sq. LFO ao) but I'm definitely in another league :
(but it works !)
::U::N::S::C::H::N::E::L::L::
XCenter
PostPosted: Mon Aug 01, 2011 7:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Coooool artwork. How do you label the panel?
How may I be of disservice?
Music for conscious listening @ http://www.fmdelight.de/
inlifeindeath
PostPosted: Mon Aug 01, 2011 8:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! That's my dog Boris in the picture. I actually used the same toner transfer method that I use to etch circuit boards and panels. I just printed out the reverse image from a laser printer on to a piece of magazine paper. Then ironed it on the piece of sanded smooth aluminum. Threw on a couple layers of clear coat and it turned out pretty well. Not as deep of black as I wanted but I like it.
bod
PostPosted: Mon Aug 01, 2011 11:47 am    Post subject: Reply with quote  Mark this post and the followings unread
(but it works !)
thank you!! but we all start somewhere! i'm just a bit of a nerd who likes to design stuff, and your mods are easily accomplishable with the DS7. i just looked at your thread and reckon my changes would work pretty well for what you need for the envelope trigger section. i'll finish this prototype board and if it all works how the strip board did then i'll post the schematic for any one who wants it. everything i've learnt has been from here, and all the other synth freaks who are decent enough to share their work so i'm more than happy to do the same!
the gate to trigger circuit works nicely but the lfo reset might get a few questionable looks from folk... however it does what i want! Very Happy with a few component changes and jumpers it'll make a nice drum module as well.
should hopefully be done by the end of the week if i get time away from decorating the house and all the other things life throws in the way! Laughing
Audio files: 160
PostPosted: Mon Aug 01, 2011 12:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fritz D-well chaos & 5Pulser & multiples module.
Hello , here are some sounds from these great circuits from Ian Fritz, i use the 5Pulser alot in my recent music & the chaos sometimes for unusual lfo type modulations.
 Filesize:  89.81 KB
 Viewed:  1915 Time(s)
5Pulser & sequencer & lfos.mp3
 Filename:  5Pulser & sequencer & lfos.mp3
 Filesize:  4.27 MB
 Downloaded:  2901 Time(s)
d-well chaos & 2 vcos.mp3
 Filename:  d-well chaos & 2 vcos.mp3
 Filesize:  2.09 MB
 Downloaded:  2898 Time(s)
Audio files: 160
PostPosted: Mon Aug 01, 2011 12:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Impressive synth you have there , good work & nice and colorful .
Do you use lots of multiples or did you build mini mixers into the designs ??
bod
PostPosted: Mon Aug 01, 2011 1:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
skrog: that 5pulser sequener and lfo sampler is amazing! Shocked Very Happy
umschmitt
PostPosted: Mon Aug 01, 2011 2:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well THAT IS COOL.
I know what you mean. Today was mezzanine task force !
sneakthief
PostPosted: Thu Aug 04, 2011 12:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Finished my TR-808 clone after planning it on and off over the last 5 years. Took me a while to figure out what I wanted to do for the case.
First test, only one take:
http://soundcloud.com/sneakthief/first-mb-808-test
...all you hear is 808. The tones are from self-oscillating congas.
mods:
- white noise level
- snare decay
- snare filter
- clap offset
- clap reverb amount
- maraca filter
- rimshot filter
- cowbell tuning x2
- open hat filter
- closed hat filter
- white & pink noise input jacks (not used in this demo)
- schmitt trigger input jacks (not used in this demo)
- self-oscillation of congas when the decay is set all the way
Sneak-Thief - raw electrofunk
emdot_ambient
PostPosted: Thu Aug 04, 2011 1:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
sneakthief wrote:
Finished my TR-808 clone...
YOU WHAT?!
wow!
That's simply amazing looking...sounds pretty f--ing good, too!
sneakthief
PostPosted: Thu Aug 04, 2011 1:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
In 2007 a guy made a few dozen pcb's that married the original 808 sounds with a wicked MIDIbox sequencer: http://ucapps.de/midibox_808.html
...and http://eight-oh-eight.org/
People have been waiting for Batch 3 for a couple years now. It'll probably happen, but no guarantees!
frequencycentral
PostPosted: Mon Aug 08, 2011 5:42 am    Post subject: Reply with quote  Mark this post and the followings unread
