PCB layout for Ian Fritz' AD/AR EG
Page 3 of 4 [78 Posts]
LFLab
PostPosted: Mon Dec 12, 2011 1:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm building a quad of these using the dual Bugbrand layout. Stuffed the boards but haven't tested them yet. I was wondering about these caps as well, used 3u3 filmcaps. If it works with electrolytics it'll work with flmcaps. I think the envelope generators are unipolar so electrolytics should be ok, i put in film just to be shure.
frijitz
Audio files: 54
PostPosted: Mon Dec 12, 2011 1:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
furio wrote:
My pots are 100KA and 500KA.
I have some difficulty to choose the cap values Sad
With the first attempt I used C1 4u7 and C1x 470nF and now C1 1uF and C1x 1nF. But I think there is no end, the envelope is still running non-stop! Should I have used polarized caps for both?
First, C1 is for the shorter times and C1+C1x is for the longer times. So you would want C1x to be larger than C1.
What exactly do you mean by running nonstop?
Ian
furio
PostPosted: Mon Dec 12, 2011 2:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks to all!
I've used a bigger C1x (sorry my post above was written the opposite way C1/C1x)
non-stop meaning it just start without Attack/Decay curves, running without end Wink
maybe I am having difficultie finding some short on the PCB, but I have mixed Electrolytic and Film caps for the timing scratch
I am sorry for being such a bother... but I certainly need advise! I feel I have a better chance of repairing the problem with more help and insight from the outside!
 Filesize:  463.44 KB
 Viewed:  408 Time(s)
furio
PostPosted: Tue Dec 13, 2011 2:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi to all!
I have solved the problem, it was the MFB MIDI_2_CV or the Doepfer A-140 ADSR connected on the same Gate BUS. For some strange reason it crashed the gate on this interface Smile
With the A-190-3 USB_2_CV 5V Gate or the MIDIMPLAT 15V Gate by Roman Sowa using C1 470n and C1x 4u7 timing caps works fine for me.
The only problem is a too high CV ground sound with my VCA's using the fastest Attack/Decay. Which is the better way to reduce this glitch/click produced by the envelope output to control a VCA_CV?
furio
PostPosted: Thu Dec 15, 2011 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I would like to apologize to Mr. Fritz be it that I have made a modification that is without any style! I have only followed my own intuition.. and this is the result thereof... seeing that my knowledge of the electronic world is rather limited! This is what I did.
I cut the trace between the potentiometers and C1 and then jumped with a 8K2 resistor. If I should need to modify another envelope, I'll try some lower values.
Now I have one of the four envelopes which I assembled and found it to be compatible to control all my VCA's.
If someone could help, I attached the drawings for the euro modification to the PCB and my euro panel. I have used Musikding's 5x10cm PCB's, 16 HE/TE (8cm) Euro Panel and Lazertran.
 Filesize:  507.23 KB
 Viewed:  405 Time(s)
FritzQuadADAR.pdf
 Filename:  FritzQuadADAR.pdf
 Filesize:  490.8 KB
 Downloaded:  552 Time(s)
frijitz
Audio files: 54
PostPosted: Thu Dec 15, 2011 2:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's a good idea. The Bridechamber version has 1k resistors in series with each pot. The Elby version has 270R in series with the A pot and 1k in series with the D pot. Using a larger value makes sense for your version with the switched cap.
Ian
Silesius
PostPosted: Thu Feb 21, 2013 9:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi, I'm building a dual AD/AR following Bugbrand layout. I'm testing it and it's working fine. However, I have a question regarding this circuit. I would like to make it retrigger itself, to use it as an LFO as well. My knowledge of electronics is very limited, so I think I'm missing something.
The idea is to use Ken Stone's slope detector circuit. I think that's what I need for the job.
http://www.cgs.synth.net/modules/cgs62_sd.html
I'm using just the fall out portion and it's working nice as well; it outputs a pulse when the envelope falls without problems. Now, I though it would be just a matter of routing this pulse back into the envelope's input, but that's not working. Sometimes everything stops, sometimes it works but very fast, almost in audio range. Too much for using it as LFO...
I know there must be a way for this to work, but I can't see it; any help will be very appreciated.[/img]
PostPosted: Thu Feb 21, 2013 1:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you're retriggering when it *starts* to fall, you never let the "D" portion of the envelope complete before you're retriggering.
You need to set a level below which it retriggers as well, something close to ground. So you need slope detection and also level detection and a way to combine them to generate the trigger.
Not sure HOW you'd do that off the top of my head though.
frijitz
Audio files: 54
PostPosted: Thu Feb 21, 2013 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
That early design has been supplanted by the 4x4 Envelope Generator:
http://home.comcast.net/~ijfritz/sy_cir12_4x4.htm
You can buy boards or a kit for this from Elby.
I don't know enough about the slope detector to say if it could be made to work as you desire.
Ian
diablojoy
PostPosted: Thu Feb 21, 2013 1:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
use a window comparator circuit with upper threshold near zero volts and lower threshold at zero volts
and then 'AND' that with the 'falling' output of the slope detector, the output of the AND gate will only output a signal when both its inputs are high
so you will only get a retrigger when the EG is near to completing its cycle
ask where the hell am I
as good an answer as any
sonicwarrior
PostPosted: Mon Mar 04, 2013 3:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
No documentation? Schematics?
frijitz
Audio files: 54
PostPosted: Mon Mar 04, 2013 7:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Schematics for all my commercial projects have been taken down because of theft. Operation of all the 4x4 features is in a doc at Elby's:
http://www.elby-designs.com/contents/en-us/ed114-guide.pdf
Ian
sonicwarrior
PostPosted: Tue Mar 05, 2013 2:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
For Oakley and MOTM modules I get at least the schematics when I order the corresponding boards. Sad
frijitz
Audio files: 54
PostPosted: Wed Mar 06, 2013 8:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Has either of them had circuits stolen and used for commercial purposes?
Anyway, I can work with builders on an individual basis, and anyone who is, let's say, a member in good standing around the forums can get circuits for boards they buy.
Ian
sonicwarrior
PostPosted: Sun Mar 31, 2013 1:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, I forgot to answer. Embarassed
I'll finish my two existing original All-In EG first before deciding whether to order the advanced one Elby is offering.
jmejia
PostPosted: Mon Jul 08, 2013 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Is the bridechamber version different/older than the current 4x4?
I'm not clear on what 4x4 indicates as the elby version looks like a single envelope on board... or am I mistaken?
I'd love to build a quad or at least dual version into my 5u system, but am not really sure what pcbs to use.
furio
PostPosted: Mon Jul 08, 2013 12:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
it seems similar to what was mentioned above!
I am very happy with this PCB's I've made... simply, these envelopes are very interesting to use slowly... I am beginning to have less consideration for the metal film restistors, they could be the cause of a malfunction of the CV and bad sound into the audio path, because comparing to carbon film the metal film reduces the bandwidth. With restricted bandwidth the CV looses the character and for example by controlling the VCA could become more noisy... up to accentuate pops & clicks.
sonicwarrior
PostPosted: Mon Jul 08, 2013 1:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Never heard of that. Aren't metal film resistors supposed to superior in every way to carbon film?
Never had any problems using metal film with CV so far. Confused Maybe your metal film resistor brand just sucks. Idea
furio
PostPosted: Mon Jul 08, 2013 1:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
there are different types, performances and prices of carbon and metal film... in the audio path, for example, prefer to use the Takman REX... as a minimum, if it would be a OPA2132 as OPAMP... OPA2134 also works fine with a cheaper metal film, though it tends to take an acidic direction rather than a musical.
frijitz
Audio files: 54
PostPosted: Mon Jul 08, 2013 5:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes. a one-pager on the 4x4 is attached. Also, there is a demo at my utube site:
http://www.youtube.com/user/frijitz001
Ian
4x4_1110.pdf
 Filename:  4x4_1110.pdf
 Filesize:  69.93 KB
 Downloaded:  830 Time(s)
Starspawn
PostPosted: Sun Jun 19, 2016 12:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Heres a stripboard version for those that dont etch.
5U spacing on pots.
Moosgummi
PostPosted: Tue Jun 21, 2016 7:49 am    Post subject: Reply with quote  Mark this post and the followings unread
I just wondered why my reply didn´t show up, then I noticed this was yet another IF stripboard layout. You´re on fire, man!!!
Starspawn
PostPosted: Tue Jun 21, 2016 8:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Ive had them finished a long while, as well as proper PCBs from uglysound of most other of Ians available circuits.
Whats holding it up is as usual panel design ... its going to be 2 full 5U panels.
Teezer - Wavolver 2 - Saw Core - 2X 5pulser - Single 2Q4Q+XOR - Threeler
and
TGTSH - 2XAD/R - 4X4 - Chaquo - DC mixer and Dual 2Q/4Q - Foniks VC panner as well as a mid side decoder as last stage.
wackelpeter
Audio files: 10
PostPosted: Fri Jun 24, 2016 10:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Neat little Circuit... I would like to suggest you to built this with the delayed pulser pulser... it's pretty much fun and useful...
Btw. Glad that Ian seems to be still with us... Thought he seperated somehow from the DIY scene as he was long time absent and also his homepage was unavailable as i wanted to check something a few months ago...
Still have some of his circuits i would like to build someday...
PostPosted: Fri Jun 24, 2016 11:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Ian moved to: http://ijfritz.byethost4.com/sy_over.htm
But unfortunately google still takes you to the old site which no longer exists.
