Posted: Mon Nov 11, 2013 8:06 am Post subject:
Octomod Ho! |
Finally finished this up so I could get some plastic case work to brush up before attacking my x0xb0x case...
1.51 MB |
| Viewed: |
519 Time(s) |
1.43 MB |
| Viewed: |
509 Time(s) |
Joined: Jan 15, 2011 Posts: 428 Location: Montreal, Canada
Joined: Jan 07, 2009 Posts: 1220 Location: Scottish Borders
Posted: Wed Nov 13, 2013 10:07 am Post subject:
Hi elmegil
What does your octamod box do ?
Dave. |
Posted: Wed Nov 13, 2013 10:12 am Post subject:
Hi James , nice chamber of led's , looks like you could get your arm in up to the shoulder , nice sounds on the vid.
Dave. |
Posted: Wed Nov 13, 2013 11:37 am Post subject:
| Quote: | After the TTSH got postponed, I decided to start this thing. It's been a while - I took the summer off while job and financial insecurity took its toll.
This is either the J3RK Dual Mirror Core VCO or the Stroh Modular Dual Complex VCO. I'm not really sure which. Originally the thread was labeled as per the former, but as things progressed the name morphed to the latter. Either way, it's a really cool collection of vcos and utility modules, with which you can build the complex vco of your choice!
I tried out Front Panel Express's new standoff utility thing, and it worked well, mostly - I had one break off soon after transporting it from my heated studio area to my unheated garage where the soldering happens. No problem though - a little JB Weld and we're back in business. |
sduck
I am very impressed with this build. This Dual VCO looks extremely versatile to ! Lots of luck with this one. Too bad about the standoff issue but looks like you had the quick fix at hand. I have seen the new versions of FPE software with added manufacturing options. Will have to check these out
Bill |
Posted: Wed Nov 13, 2013 12:26 pm Post subject:
Ah , that's great , i can imagine some alternative cv's going to filters & wave shapers , great  |
bearblock
Zodiak
Joined: May 20, 2007 Posts: 249 Location: Gillingham, Kent UK
Posted: Tue Dec 03, 2013 5:24 pm Post subject:
Eurorack MFOS SoundLab (72h) with some extras, like inverted outputs on LFO and AR, triangle outputs for both VCOs and exponential voltage control for VCF and VCA.
The skirts round the switches are there because I drilled the wrong sized holes. They are made from some screw hole covers I had left over from a flat pack bookcase.
The Stig sticker is not staying, and the sellotape on the corners is just there to protect them while I work on it.
The yellow blobs are two transistors and a tempco, glued together and coated with heat sink compound, then encased in heat shrink sleeving. This has given an improvement over having them separately, but in practice the de-tune is still noticeable as my room warms up.
Some of the pots are damaged and I am going to replace the lot. I think it was because I was working on it face down and the shafts have been pushed it, so I have ordered a different type to replace it them. _________________ Stephen
www.Rainsbury.Net |
Posted: Tue Dec 03, 2013 9:33 pm Post subject:
Very nice work.
I once had tracking issues with a SLMS and contacted Ray about it, and he basically said you're lucky to get much of anything. Turns out I was able to find a subtle error later that made my problem much less, but I never did a temp test, and I wouldn't be surprised if it still drifted some. |
sonicwarrior
Joined: Dec 22, 2005 Posts: 266 Location: Cologne, Germany
Posted: Wed Dec 04, 2013 12:35 am Post subject:
Finally finished my Jürgen Haible Tau Phaser with THAT 300 chips (using self made converter sockets):
And a detail shot of the THAT 300s (can't find the solo pics of the converter sockets on my hard drive):
Uploaded with ImageShack.us |
Zodiak
Posted: Wed Dec 04, 2013 4:33 am Post subject:
| elmegil wrote: | | I once had tracking issues with a SLMS and contacted Ray about it, and he basically said you're lucky to get much of anything. | I am starting to agree and although that's not a major issue it is disappointing. I wanted to use it as a sequencer voice, but it still drifts and doesn't track too well, so I have pretty much given up on that idea and will have to build a couple of VCO modules.
All is not lost though, I had originally planned to build one of Rays sawtooth to triangle circuits as an external module, but as they are so simple I decided to build one onto each VCO and I am glad that I did, because now I can use them a VCLFOs.
I haven't built that bit yet, and I am going to have to modify it to make it DC coupled, and that will required a bit of fiddling, but it shouldn't be that difficult.
And just to be a heretic, I use a PIC to control my sequencer... <GASPS> and that has a spare timer output which is just begging to be used as a sound source and I think that is going to be my solution there. Yes I know its only square out, but put it through 4 stages of dividing and sum them together with the right resistors and it can produce a barely passable triangle and ramp if you squint.  _________________ Stephen
www.Rainsbury.Net |
dougseidel
sduck
Zodiak
Posted: Fri Dec 13, 2013 3:52 pm Post subject:
I like the front panel sduck, how did you make it? _________________ Stephen
www.Rainsbury.Net |
sduck
Posted: Fri Dec 13, 2013 5:39 pm Post subject:
| It's from Front Panel Express in Seattle. |
Posted: Sat Dec 14, 2013 5:48 am Post subject:
Wow , nice reverbs Steve , does the black boxes contain the long springs ?
very nice build.
Dave. |
sduck
Posted: Sun Dec 15, 2013 9:48 pm Post subject:
| The black boxes are the digital pt2399 based spring emulators - the brick selection on the switches - the springs are mounted in my cabinet, and connect through those minijacks hanging out in the back. |
bubzy
Joined: Oct 27, 2010 Posts: 594 Location: United Kingdom
Audio files: 64
synchroma
Posted: Tue Dec 31, 2013 3:39 pm Post subject:
the Moon Base Xplorer Subject description: my last finished build for 2013 |
I got the Moon Base Xplorer finished just before the end of the year
more info here
(I will upload more pics and demo's next year )
140.05 KB |
| Viewed: |
347 Time(s) |
122.1 KB |
| Viewed: |
304 Time(s) |
94.55 KB |
| Viewed: |
308 Time(s) |
Posted: Tue Dec 31, 2013 6:04 pm Post subject:
| Beautiful! |
Joined: Apr 03, 2004 Posts: 24493 Location: The Netherlands, Enschede
Posted: Tue Dec 31, 2013 6:21 pm Post subject:
That's one fokking hell of a lovely looking game machinery thing PHOBos
erm .. I mean .. heard some samples of it too I guess lately on you stream?
anyways, looks great! _________________ Jan
DES
Posted: Wed Jan 01, 2014 7:38 pm Post subject:
That's sharp looking! _________________ Dave
www.davesneed.com |
