Joined: Apr 03, 2004 Posts: 24484 Location: The Netherlands, Enschede
Posted: Tue Jun 03, 2014 12:19 pm Post subject:
Added a file render option. _________________ Jan
Posted: Wed Jun 04, 2014 3:20 pm Post subject:
Changed render mode, and fixed a filter stability issue.
start of thread
wren page _________________ Jan
Posted: Sat Aug 23, 2014 11:21 am Post subject:
Had some unreleased stuff and some new things . thought it to be time for a new release.
Mainly the Euclidean Rhythms and the CSV data player, some changes on existing modules too. _________________ Jan
Posted: Sun Oct 19, 2014 10:47 am Post subject:
Some bug fixes, some new modules for version 2014.10.19.0 - see first post in thread for more info. _________________ Jan
Posted: Sun Dec 14, 2014 5:07 pm Post subject:
WREN is about one year old now!
Current version is 2014.12.12.0
http://bluehell.electro-music.com/wren/forums.html
I've added PortAudio support, this makes the program much nicer to work with.
When PortAudio is used the latencies are lower, the CPU load is lower too (for a CPU with more than one core), the audio artifacts on editing or touching the program's title bar are gone too.
Multi channel works when ASIO is being used, for me at least (with Asio4all and the RME ASIO drivers, although I had to install Asio4All to make the RME ASIO work ... ).
Device selection still works so so and it is needed occasionally to exit WREN and to restart it to get it all working, but once set and working on a next startup it is all OK. I'm working on that still.
The next release will have a button to call up the ASIO control panel. As of yet I'm not happy with how I implemented that, but soon ...
There were some more changes, for one it looks better and you can color modules, and there are 101 module types available now.
Also tons of stability issues were ironed out.
edit : url update. _________________ Jan
bubzy
Joined: Oct 27, 2010 Posts: 594 Location: United Kingdom
Audio files: 64
Posted: Sun Dec 14, 2014 5:47 pm Post subject:
i like it !  _________________ _Richard_  |
Posted: Sun Dec 14, 2014 5:56 pm Post subject:
bubzy wrote: | i like it !  |
thanks! _________________ Jan
BobTheDog
Posted: Thu Dec 18, 2014 2:33 pm Post subject:
101 modules
I might have to to install this on a VM now it is it's birthday. |
Posted: Sat Dec 20, 2014 6:32 pm Post subject:
Hmm .. I had some fuckups
Wren would not start without an ini file present and it would not store the channel selections properly either .. this got fixed in the 2014.12.20.1 release currently present at http://bluehell.electro-music.com/wren/forums.html
Sorry for for that .. but hey .. you never tried it anyway, or you would have told me about it
Posted: Sat Dec 20, 2014 8:45 pm Post subject:
You'll need to find sweet spots a bit for buffer sizes ( the default settings are not usable, usually).
When using PortAudio keep them shortish ... like 64 .. 512. For ASIO the size from the ASIO driver will be used, so pop up the ASIO control panel for that. For my RME thingie I needed to set 4096 and it still sucked .. so dunno about ASIO.
Latency will will be almost bearable, well for me it still sucks, but got a user quoting 4ms.
When using legacy mode use longish buffers, like 16384 .. 65536. latency will be awful .. like 1 .. 2s.
I never got it better than about 30ms here, MIDI to sound that is, 60ms on audio in to audio out.
I had high hopes on using PortAudio .. and yes it is like 20 or 30 times faster than legacy mode, but it is not quite like the 'couple of ms hey how bad can it be' idea I had in mind.
So .. might be usable for MIDI control, but as an FX device its still not nice .. yeah .. I played guitar trough it
Maybe WASAPI exclusive mode will help, did not try that yet. _________________ Jan
Posted: Sat Dec 20, 2014 8:59 pm Post subject:
But hey .. it did
for me  _________________ Jan
Posted: Mon Dec 29, 2014 7:42 pm Post subject:
Added a basic vocoder, basically :: http://bluehell.electro-music.com/wren/forums.html#dones
Posted: Sat Jan 03, 2015 7:56 pm Post subject:
New version : http://bluehell.electro-music.com/wren/forums.html#dones
forcefielder
Posted: Mon Jan 05, 2015 8:13 pm Post subject:
that demo track sounds great |
Posted: Tue Jan 06, 2015 1:09 pm Post subject:
Thank you :-) _________________ Jan
Posted: Sun Jan 18, 2015 11:26 am Post subject:
Some works on the sequencers .. chaining works better with the new SeqSeq module, step interpolation and reversal for chained sequences.
Added Talkie a retro style speech thingie with a list of about 1200 words it can say. You could make your own word lists for it too it seems, but I did not try that myself.
Also made a fresh source code release.
Posted: Thu Jan 22, 2015 6:01 pm Post subject:
Mostly the audio rate oscillators are band limited now. Some other small changes too, like Talkie got expo FM control and got a bit easier to control.
Anyways, tri, saw and square oscs are usable now, with a lot less aliasing. Anti-aliasing works on PM, FM and hard sync modes too.
Posted: Wed Feb 25, 2015 5:33 pm Post subject:
Some bug fixes, a clocked delay module, sped up some stuff ...
Posted: Sat Apr 25, 2015 4:59 pm Post subject:
2015.4.25.0 was just posted .. changes since 2015.2.26.0 :
- Logic selector module added
- Convoder module added
- Forth interpreter added - experimental only
- Euclidean scale module added
- Pattern module added
- Fixed MIDI modules
- New bitmaps for knobs, so they look a bit nicer on colored backgrounds
- Made peak and valey indiccators on VU meters
- Fixed the global tuning parameters
- Programmable Frequency divider added
- DigiMux and DigiDemux modules added, DigiDemux has a built in hold mode
- Changed 2to1 switcch to be 2to2 - it swaps the channels on a switch
- FreeVerb got some work to make it sound a bit better
- Made a version checker - available trough help menu or about page
- Added a new reverb module based on GVerb
- Various small bugs fixed
- Source code released for 2015.4.25.0 too
See http://bluehell.electro-music.com/wren/forums.html#dones for details and downloads.
Posted: Sun May 10, 2015 3:59 pm Post subject:
2015.5.10.0
Please read http://bluehell.electro-music.com/wren/forums.html#changes for changes.
A recent screen shot:
JLS
G2 patch files: 316
Posted: Mon May 11, 2015 2:14 pm Post subject:
ok .. at start up? or with a particular patch? _________________ Jan
JLS
G2 patch files: 316
