JLS
G2 patch files: 316
Joined: Apr 03, 2004 Posts: 24670 Location: The Netherlands, Enschede
Posted: Tue May 12, 2015 11:45 am Post subject:
I can not find the error location you gave (0081B57)
Could you try to rename the file wren.ini to see if it will then start? _________________ Jan
JLS
G2 patch files: 316
Posted: Tue May 12, 2015 12:52 pm Post subject:
ok .. address was not 0081b75 but 00801b75 .. thats in my code .. seems to be in UpdateLights .. working on it now ... _________________ Jan
Posted: Tue May 12, 2015 1:52 pm Post subject:
I made a new release 2015.5.12.0 ... some new code was trying to access a synth patch that did not exist yet ... http://bluehell.electro-music.com/wren/forums.html I think this will fix it.
Thanks for the heads up
Made a new source code release for this as well.
edit : url update. _________________ Jan
9 3 4 .. erm .. not 13 then? .. hmm, ah eight! .. yeah yeah as in 8647 .. 47 is an 88 .. pwew .. numbles! Last edited by blue hell on Thu May 25, 2017 10:38 am; edited 1 time in total |
JLS
G2 patch files: 316
Posted: Tue May 12, 2015 2:10 pm Post subject:
Great :-) _________________ Jan
Posted: Sat May 30, 2015 6:46 pm Post subject:
New release 2015.5.31.0 ... http://bluehell.electro-music.com/wren/forums.html#changes ... mostly clean up stuff .. but click link for details .. may have introduced some bugs .. changed the memory managment .. please let me know when its broken.
9 3 4 .. erm .. not 13 then? .. hmm, ah eight! .. yeah yeah as in 8647 .. 47 is an 88 .. pwew .. numbles! Last edited by blue hell on Thu May 25, 2017 10:39 am; edited 1 time in total |
Posted: Thu Jun 18, 2015 4:26 pm Post subject:
A couple of fractal thingies and some wave warpers, wire colors can be changed, please see http://bluehell.electro-music.com/wren/forums.html#changes for the full story.
Source code updated too.
9 3 4 .. erm .. not 13 then? .. hmm, ah eight! .. yeah yeah as in 8647 .. 47 is an 88 .. pwew .. numbles! Last edited by blue hell on Thu May 25, 2017 10:40 am; edited 1 time in total |
JLS
G2 patch files: 316
Posted: Fri Jun 19, 2015 9:41 am Post subject:
| PHOBoS wrote: | instant crash here :cry:
old versions still run fine. |
Did it male a log file in the application directory? And if so .. can I please see that?
It is called wren.log when you did not change the exe name. _________________ Jan
9 3 4 .. erm .. not 13 then? .. hmm, ah eight! .. yeah yeah as in 8647 .. 47 is an 88 .. pwew .. numbles! Last edited by blue hell on Fri Jun 19, 2015 9:46 am; edited 1 time in total |
Posted: Fri Jun 19, 2015 9:44 am Post subject:
| JLS wrote: |
- 1D and 2D cellular automata sequencer
- markov chain sequencer
- game of life sequencer |
Will add those to the wish list .. thanks :-) _________________ Jan
Posted: Fri Jun 19, 2015 10:21 am Post subject:
Yup, that looks all fine .. is there any error message? _________________ Jan
Posted: Fri Jun 19, 2015 10:58 am Post subject:
I did find a bug in the audio handling .. when it ever happens that there is no compiled patch and the audio stream runs the audio I/O processing will write out of the array bounds of the audio out buffer .. seems likely to be that .. on a slower system audio I/O may run before the patch got compiled. Also it would be worse with largish audio buffers, seeing your buffer size is 4096, using 512 or so here. _________________ Jan
Posted: Fri Jun 19, 2015 11:07 am Post subject:
Posted a fix for that one as version 2015.6.19.0. _________________ Jan
Posted: Fri Jun 19, 2015 12:04 pm Post subject:
Yes, you can change the ini file. _________________ Jan
Posted: Fri Jun 19, 2015 12:12 pm Post subject:
Posted: Sun Jun 21, 2015 3:49 pm Post subject:
New version 2015.6.21.0
Mostly cosmetics, a lil bug in envelope shape displays and updated some help text.
Posted: Sat Jun 27, 2015 12:16 pm Post subject:
Some more cosmetics in 2015.6.27.0 and also removed some clicks from the basic envelope generator.
9 3 4 .. erm .. not 13 then? .. hmm, ah eight! .. yeah yeah as in 8647 .. 47 is an 88 .. pwew .. numbles! Last edited by blue hell on Thu May 25, 2017 10:41 am; edited 1 time in total |
