LFLab
Joined: Dec 17, 2009 Posts: 497 Location: Rosmalen, Netherlands
Posted: Sat Feb 20, 2016 6:45 am Post subject:
+1 great panels.
On laserprinters, i have a samsung ml1640, and that was 65 euro new, a couple of years ago. |
Joined: Mar 28, 2006 Posts: 1472 Location: Kansas City, Mo USA
Posted: Fri Feb 26, 2016 7:44 am Post subject:
Enhanced foot controllers |
I just finished a redo of my foot controllers.
When I first built the controllers (back in the late 1970s) they were passive circuits. Each controller has a corresponding switch to select an upper or lower threshold (more on this later). The result was not so good because the switches were not isolated from each other and if all the switches were not in the same position the pedals didn't work correctly.
The solution was to create active circuitry.
For each pedal, there is a corresponding signal path -- just an op-amp inverter pair connected in series. The input signal is inverted then sent to the next inverter. The foot-pedal, which uses a light source and cadmium cell, is configured as a shunt to ground from the input bus of the second inverter. This isolates the shunting action from the input and output jacks and isolates the switches, pots, and pedals from each other.
The threshold switches control the shunt: For the "upper" threshold, the (panel mounted pot) is connected in parallel with the pedal -- in the "lower" position, the pot is connected in series with it. Note that the cadmium cells are at their minimum resistance when the pedals are in the "back" (soft) position.
As a result, when the threshold switch is in the "upper" position, the pot controls the "loudness". When the threshold switch is in the "lower" position, the pot controls the "softness" -- that is, how much the signal will be attenuated.
The circuit works for both audio and control voltages.
| These are the corresponding front panel controls (not shown are the four pairs of input/output jacks) from the existing panel that I built back in the 1970s. |
422.35 KB |
| Viewed: |
533 Time(s) |
| A look at the installed PCB. This board contains two TL074 (quad) op-amps. Thus, this board provides eight inverters. |
512.87 KB |
| Viewed: |
536 Time(s) |
| The foot pedals. A friend of mine helped me build these back in the 1970s. Attached to each pedal is a lightbulb -- when one moves the pedal, the light swings in front of a stationary cadmium cell. This system prevents any problems from scratchy pots a |
580.53 KB |
| Viewed: |
498 Time(s) |
| Close up of one of the cadmium cell/light source pairs. The light source's holder is connected to the back of the pedal. |
1.01 MB |
| Viewed: |
539 Time(s) |
_________________ -- Kevin
http://kevinkissinger.com |
isak
Posted: Sat Mar 12, 2016 3:03 pm Post subject:
Hi guys.
I build studio passive volume controls with monitors control.
Usually i build 3 in and 3 outs till one day i got this cool order from someone that haves 6 pares of studio monitors and he wanted a passive unit with volume to control them all.
So i did
4.28 MB |
| Viewed: |
513 Time(s) |
4.01 MB |
| Viewed: |
523 Time(s) |
_________________ http://www.myspace.com/mgmtrance |
sduck
Posted: Wed Mar 16, 2016 6:41 pm Post subject:
Not as beautiful as sduck's, but...
(also have a Haible design very close to being done, so that will come along soon)
2.04 MB |
| Viewed: |
501 Time(s) |
1.19 MB |
| Viewed: |
502 Time(s) |
LFLab
Posted: Thu Mar 17, 2016 3:01 am Post subject:
| That's nice! I did a PCB for the 5-pulser as well, and built it recently. It is a lot of fun, run audio through it or an LFO for weird rhythms. |
Posted: Thu Mar 17, 2016 4:26 am Post subject:
All these nice boards and frontplates, I am hesitant to show my "prototypes"...  |
Posted: Thu Mar 17, 2016 5:21 am Post subject:
It worked! It looks terrible
One question though: How are the connectors you use called? (and then especially the one on the bottom?) |
Posted: Thu Mar 17, 2016 7:37 am Post subject:
Those are MTA-100 headers, and I use the crimp style sockets (I crimp the pins onto the wire and then solder them, and then insert them into the shroud).
Even the one that's not connected at the bottom is an MTA-100, they are just different sizes (3 position vs 5 position). I use the 5 pin ones for power connection when I'm using stripboard and small protoboards, since you can't get the standard MOTM power header (MTA-156) into the holes.... |
Posted: Thu Mar 17, 2016 8:16 am Post subject:
| Thanks! |
Posted: Thu Mar 17, 2016 8:53 am Post subject:
| Grumble wrote: | All these nice boards and frontplates, I am hesitant to show my "prototypes"...  |
it is not a contest, there are no winners or losers, it is just to show what you built which can be an inspiration for others.
And of course how much money you are willing and able to spend can make a big difference in how something looks.
Profesionally fabricated boards and fronts often just look, well.. more professional than DIY ones. That doesn't
mean they are better. On the contrary, I personally love to see some creative designs. _________________ "My perf, it's full of holes!"
Posted: Thu Mar 17, 2016 9:04 am Post subject:
| PHOBoS wrote: | it is not a contest, there are no winners or losers, it is just to show what you built which can be an inspiration for others.
mean they are better. On the contrary, I personally love to see some creative designs. |
rhdf
Posted: Sat Mar 19, 2016 7:20 pm Post subject:
I have a whole bunch of stuff at the edge of the hopper, just needing panels. This one I was lucky enough to be able to get a bridechamber panel for, so it's a tiny bit less work and therefore higher in the queue
1.1 MB |
| Viewed: |
288 Time(s) |
1.64 MB |
| Viewed: |
299 Time(s) |
Posted: Sun Mar 20, 2016 12:45 pm Post subject:
My next build is a quad generator made with an Arduino with 4x AD9833 DDS, not oscillators, because the waveform is generated as opposed to the result of oscillations.
All 4 AD9833 are capable of putting out sine, triangle or square wave, not simultaneous though, but I have made 4 simple discriminators to convert the sine or triangle wave into a square wave with variable pulse-width.
So now I have 4 sine or triangle waves (selectable with switches) and 4 pulses.
The 4 switches on the left choose between midi and free, when in free mode the generators act as if middle A is pressed.
2.12 MB |
| Viewed: |
358 Time(s) |
2.26 MB |
| Viewed: |
336 Time(s) |
2.08 MB |
| Viewed: |
318 Time(s) |
Posted: Sun Mar 20, 2016 10:22 pm Post subject:
Verra nice perf job!  |
Posted: Mon Mar 21, 2016 12:13 am Post subject:
thnx  |
Posted: Wed Mar 23, 2016 12:23 am Post subject:
A Quad Voltage Controlled Attenuator.
When there is analog circuitry involved, it always tends to get messy
2.31 MB |
| Viewed: |
304 Time(s) |
2.46 MB |
| Viewed: |
282 Time(s) |
2.08 MB |
| Viewed: |
332 Time(s) |
Posted: Thu Mar 24, 2016 10:16 pm Post subject:
I have a big list of builds that have been languishing for ages. All of them waiting on panels.
I made 6 panels this week, so I'm going to look like I'm mega fast; reality is I'm reasonably fast at panelling once I sit down and do it. Builds have been done for months in some cases.
This one is not my best panel finish, had a mishap after spraying it with clear coat. Since it's for me, it's not worth the time and material to do it over....
1.19 MB |
| Viewed: |
291 Time(s) |
831.98 KB |
| Viewed: |
287 Time(s) |
helge-h
micromusic
richardc64
Audio files: 26
Posted: Sun Mar 27, 2016 8:38 am Post subject:
Great looking and some extensive projects from our multi-skilled and creatively-minded members. In comparison my progress for 2016 has been small, starting with
1] One of the smallest assemblies I've ever made. 1/8" TRS jack, trimpot & npn transistor. (I'm still not ready for surface mount, though.) Purpose is to adjust the sensitivity of an expression pedal (actually a rewired sewing machine speed control) to function as an Off/On HiHat Open/Close switch.
2] A box for a project I hope to complete in time to BE a 2016 build. (Doesn't seem likely at this point.)
125.04 KB |
| Viewed: |
16828 Time(s) |
| with temporary cardboard panel |
99.26 KB |
| Viewed: |
295 Time(s) |
_________________ Revenge is a dish best served with a fork... to the eye |
