Snailis Spiralis
Page 1 of 2 [35 Posts]
PostPosted: Mon Dec 19, 2016 1:05 pm    Post subject: Snailis Spiralis
Subject description: "vacuum tube" effect
my vacuum cleaner broke and while I was disposing of it I noticed the sound the tube (or rather hose, but vacuum tube sounds nicer Wink) made.
Being the professional scrap collector that I am I couldn't just get rid of it without trying something with it first. So inspired by the cooper time
cube I wondered what it would sound like with a speaker on one end and a microphone on the other and that's what I am working on now.
Unlike the time cube my goal is not a delay but rather the resonating sound you get when sounds travels through a tube
I started by mounting a small speaker on a piece of wood and adding the tube to the other side. I glued part of a rubber band on the end,
which was quite a challenge, for a snug airtight fit. After that I breadboarded an amplifier for the speaker and a small microphone amp
to do the first test. That actually worked quite well, the sound isn't very profound but it does definitely add something and I thing it could
work great for drums.
 Filesize:  127.78 KB
 Viewed:  798 Time(s)
 Filesize:  146.89 KB
 Viewed:  845 Time(s)
 Filesize:  109.87 KB
 Viewed:  813 Time(s)
PostPosted: Mon Dec 19, 2016 1:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
here are some photos from the mic and preamp (will post schematics later). the microphone is an electret type
which I rolled up into some foam which fits loosely in the tube but just tight enough so it doesn't move.
 Filesize:  178.99 KB
 Viewed:  797 Time(s)
 Filesize:  202.96 KB
 Viewed:  828 Time(s)
 Filesize:  213.1 KB
 Viewed:  818 Time(s)
PostPosted: Mon Dec 19, 2016 2:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah! a vacuum tube filter Cool
PostPosted: Mon Dec 19, 2016 2:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
to hold the vacuum tube in place I mounted a carboard tube on the board by screwing it to a wooden disc. I used a hole saw to cut out the
disc and it was a bit too small but with the help of some tape and a ring of another cardboard tube (which fit right in the other one)
I got it mounted to the board. The microphone end of the tube is held in place by some thick foam and I used part of a measuring
spoon to cover that end up. I painted it yellow because the pink head at the end of the tube just looked, well, VERY WRONG Embarassed
so now I have some more testing and soldering to do. I did already solder up the amp though but haven't tested it yet, so that's next.
 Filesize:  147.68 KB
 Viewed:  775 Time(s)
 Filesize:  166.27 KB
 Viewed:  783 Time(s)
 Filesize:  157.81 KB
 Viewed:  772 Time(s)
 Filesize:  197.01 KB
 Viewed:  781 Time(s)
 Filesize:  199.12 KB
 Viewed:  807 Time(s)
dougseidel
PostPosted: Tue Dec 20, 2016 12:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
you are the coolest
PostPosted: Tue Dec 20, 2016 1:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked Wow...
PostPosted: Tue Dec 20, 2016 5:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't get it, where does the 400VDC go? Wink
Audio files: 500
PostPosted: Wed Dec 21, 2016 6:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool! I love the sounds you get out of those hoses.
I wonder if stretching it will create a similar effect like you get in an LFO'ed flanger...? Not that it's that easy when curled up...
Also another idea is to have a speaker at each end and put the mic somewhere in the middle. You can get some strange ringmodulated sounds out of that.
PostPosted: Wed Dec 21, 2016 6:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
oh 2 speakers Razz I think I might have another hose somewhere, unless I actually threw it out, will check tomorrow but first have to finish this one.
Could indeed be very nice!
PostPosted: Wed Dec 21, 2016 6:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
soldered up some more circuits, from left to right: input buffer/amp, speaker amp with resonance control (feedback from the mic), output mixer/amp.
The output mixer hasn't been tested but it worked on breadboard, the rest works ok. Cool I have an idea for the design but for that I'd probably have
to temporarily remove the hose and I am not sure if that will be very easy because of the rubber band, but I will give it a try.
 Filesize:  195.28 KB
 Viewed:  666 Time(s)
wackelpeter
Audio files: 10
PostPosted: Thu Dec 22, 2016 12:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Where are the sounds? I'd like to hear this too. Aint i'm blind or deaf? I can't find them.
PostPosted: Thu Dec 22, 2016 3:22 am    Post subject: Reply with quote  Mark this post and the followings unread
patience young grasshopper, the ride isn't over yet.
(or get a vacuum tube, hold it up to a speaker and listen at the other end to get an idea)
Audio files: 500
PostPosted: Thu Dec 22, 2016 8:24 am    Post subject: Reply with quote  Mark this post and the followings unread
I should have said "I love the sounds I got out of those hoses in the past."
They sound kinda flangey, resonated. Whenever I have the chance, I listen through them. Many years ago I used to work in a place where they had very long industrial type hoses and they sounded magical.
PostPosted: Thu Dec 22, 2016 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Industrial type hoses probably sound great if you put some nine inch nails through them.
PostPosted: Thu Dec 22, 2016 11:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Haha, looks like fun!
This is basically the same idea as the Pipe Bomb, a distortion/tone thing by Jamie Heilman, which was a PVC tube with a speaker on one end and a mic on the other.
I found it on some site years ago, but never got around to building it.
However, I thought of a variation... the waterpipe bomb... wherein the pipe is filled with water and the speakers/mic are waterproof... sound travels differently in water, which could be interesting?
.:James:.
PostPosted: Thu Dec 22, 2016 6:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Or possibly a vacuum jar, and experiment with gasses?
Cfish
PostPosted: Thu Dec 22, 2016 7:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hay Alanp
I almost threw away some canning jars I had made modified lids for while doing a home made vacuum tube experiment.
That would be a great experiment to do with them.
Awesome project PhoBos
Cfish
PostPosted: Wed Dec 28, 2016 4:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
PostPosted: Wed Dec 28, 2016 4:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
some interesting ideas there. Not sure what water would do but hydrophone recordings can be interesting. It would be a tricky built though,
maybe an aquarium would be fun to experiment in. When I looked up some information about the time cube I came across the mention
of using different gasses and I think there was a comment that it would probably not have any effect. I don't exactly remember why,
either it was because of it being a closed system or too small.
As for stretching the tube that would change the resonant frequency so it will have an effect. The vacuum cleaner hose I have doesn't
stretch a lot though but it could work. Of course you would have to find a way to do this without causing any vibrations which would be
picked up by the microhone.
In the meantime I made a base for it which is actually painted by now (but still drying). So maybe I can start putting it together a bit tomorrow.
I also did some other small things but you'll get to see that when it is done or at least in another photo.
 Filesize:  135.85 KB
 Viewed:  582 Time(s)
PostPosted: Fri Dec 30, 2016 12:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Finished it just before the end of the year Razz . Here are some snailgut photos and the schematic. I added a switch to change the polarity of the output for
the speaker and the result is that it actually seems to change the resonant frequency. I guess this has to with it being mixed with the original signal. For
power distribution I used a piece of stripboard as a busbar. I'll record some sounds too but I first have some other things to do before NYE.
 Filesize:  198.97 KB
 Viewed:  594 Time(s)
 Filesize:  236.89 KB
 Viewed:  578 Time(s)
 Filesize:  226.07 KB
 Viewed:  591 Time(s)
 Filesize:  39.53 KB
 Viewed:  657 Time(s)
PostPosted: Fri Dec 30, 2016 12:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
and some more photos Cool
 Filesize:  155.81 KB
 Viewed:  577 Time(s)
 Filesize:  143.69 KB
 Viewed:  604 Time(s)
 Filesize:  149.52 KB
 Viewed:  611 Time(s)
 Filesize:  208.15 KB
 Viewed:  615 Time(s)
PostPosted: Fri Dec 30, 2016 2:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh that looks great!
Audio files: 500
PostPosted: Fri Dec 30, 2016 2:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah that is beautiful. Very Happy
PostPosted: Fri Dec 30, 2016 3:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
nice! Shocked
PostPosted: Fri Dec 30, 2016 3:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Haha love it! Especially the little mushroom. Smile
