today> Bill Fox solo tonight! Chez Mosc
Cross-Modulation
Page 1 of 2 [33 Posts]
paul e.
PostPosted: Wed Jul 27, 2005 2:59 pm    Post subject: Cross-Modulation Reply with quote  Mark this post and the followings unread
i have run into a few patches on soft-synths that i am really finding inspiring and useful that seem to use 'cross modulation' or 'inter-modulation'
can anyone shed light on the general principles and procedures for 'cross-modulation'
i would love to learn how to apply this to other patches that do not have this snazzy 'cross modulate' action
Spiral Recordings
deknow
PostPosted: Wed Jul 27, 2005 3:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
i believe cross modulation is just another name for vocoding...but i'm sure someone will correct me if i'm wrong.
deknow
paul e.
PostPosted: Wed Jul 27, 2005 3:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
i could be using the wrong term...but these siunds are not vocoded that i can say for sure
it sounds like 2 oscilators beating against each other and then somehow that is also modulated...or something like that hehe
maybe i should post a quick example
Spiral Recordings
deknow
PostPosted: Wed Jul 27, 2005 3:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
according to this:
http://www.soundonsound.com/sos/may00/articles/synth.htm
cross modulation is just another term for fm, but i'm pretty sure i've heard it used as term for vocoding (not necessarily correctly).
deknow
paul e.
here's an exmplae of what i mean...
you can hear a kind of 'warbling' effect ... has a 'longing' or sad kind of effect
this is from the Pro-53 patch 'inter-modulate pad'
inter-modulate.mp3
 Filename:  inter-modulate.mp3
 Filesize:  167.76 KB
 Downloaded:  2063 Time(s)
Spiral Recordings
deknow
PostPosted: Wed Jul 27, 2005 3:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
here's a quickie
crossmod.pch2
 Filename:  crossmod.pch2
 Filesize:  1012 Bytes
 Downloaded:  2558 Time(s)
Audio files: 235
PostPosted: Wed Jul 27, 2005 3:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cross modulation is a great technique. GREAT.
Take two voltage controlled oscillators - called A and B.
Take the output of A and plug it into the FM input of B and plug the output of B into the FM input of A. That's cross modulation. too much coffee
Run each modulation input through an attenuator or an amplifier. The important thing is that these are modulation index controls for the two oscillators.
Mix A and B and send to the output (could go through filters, envelope generators, effects, etd).
If you use a keyboard, you can connect one or both to the keyboard.
Controls are the 2 freq knobs, 2 modulation indexes, waveforms and the mix of the two oscillators.
For two years, this was just about the only patch I used on the NM1. I use it on the Moog Modular - wonderful. It makes beautiful harmonics. It is also a chaotic system - very difficult to predict what will happen with the modulation indexes are cranked up. Depending on your temperment, you will either love or hate this. Can you tell how I feel?
Laughing
DrJustice
PostPosted: Wed Jul 27, 2005 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Mosc, I was deeply into cross modulation patches on my Digisound 80 modular. The wonderful long equillibriums, the surprises and pure madness of it - yes, I can tell how you feel Smile
While, I'm here: the "Modular Synthesis" section is a great idea!
May I respectfully suggest that we post MP3 files for examples, not product specific ones?
DJ
paul e.
PostPosted: Wed Jul 27, 2005 3:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
ah, mosc, wonderful THANKS !
this will go into my wee knowledge bank for future reference
i will now experiment with this technique myself see what happens...
this is indeed something special about the sounds resulting from cross modulation
Spiral Recordings
DrJustice
PostPosted: Wed Jul 27, 2005 3:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Don't forget that you can connect more than two oscillators. For example by chaining them ouput to input in a ring. Then you can tap the signal in many places. By carefull tweaking you can get extremely complex and pleasing sounds.
DJ
paul e.
PostPosted: Wed Jul 27, 2005 4:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
i am intrigued..can you please elaborate on this....
DJ
Spiral Recordings
DrJustice
PostPosted: Wed Jul 27, 2005 5:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Soemething like the below may be a starting point. Some of the cv inputs could be from a keyobard or they could be static - or anything, its a modular!
Code:
  |    |  OSC 1 |      | OSC 2  |          | OSC N  |  |
  | ..>|cv      |   ..>|cv      |       ..>|cv      |  |
  +--->|fm   out+--+-->|fm   out+--+-...-->|fm   out+--+
                 tap 1           tap 2               tap N
More complexity can be had by setting up further fm routings in interesting arrangements. Adding a bit of delay in some of the fm paths is interesting. Using low frequencies (LFO range) and perhaps some processing modules can result in interesting patterns.
Now think further, think noodles, you may know them?
DJ
Audio files: 327
PostPosted: Wed Jul 27, 2005 7:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes X modulated LFO's are fun for noodles. Often I quantize the modulations for that, mostly in "voltage", but time quantization (with (using clocked delays) or without (using s&h's) delay)) can be used as well.
Jan.
paul e.
PostPosted: Wed Jul 27, 2005 8:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
some great insights..thanks guys...just processing this
Spiral Recordings
Audio files: 235
PostPosted: Wed Jul 27, 2005 9:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good idea, Dr. J. Here's a composition I just did in honor of this topic.
Cross Modulation Nocturne arrow http://electro-music.com/forum/post-47047.html
I won't even say what equipment I used to keep it "not product specific". I will say that there was no delay used. This is a realtime improv made using just two socillators, two LFOs, multimode filter, one multiplier, two phase shifters and a touch of reverb.
deknow
PostPosted: Wed Jul 27, 2005 9:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
the thing i like about the nord patches is that they are generally understandable as a block diagram as well as being audiable. when i post little examples,i've been using the g2 demo software (free) so as to avoid using modules that those without the hardware version can't use. i would recomned that everyone who can possibly run the demo (and i've run it on very underpowered pc's) download it, it's very useful for testing small ideas quickly.
deknow
paul e.
PostPosted: Thu Jul 28, 2005 8:09 am    Post subject: Reply with quote  Mark this post and the followings unread
mosc...wow...that nocturn...stunning...and little mind-bending ...perfect way to start the day hehehe
Spiral Recordings
Audio files: 235
PostPosted: Thu Jul 28, 2005 8:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, Paul. A nocturn is art for the night. I guess it should be spelled nocturnE. An aubade is a piece for the morning. I've never written one of those. In fact, I just looked it up.
A good challenge to write an aubade using cross modulation. .
http://www.m-w.com/cgi-bin/dictionary?va=aubade
Dovdimus Prime
Audio files: 6
PostPosted: Thu Jul 28, 2005 9:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry to butt in! I just needed to say that this thread reads like some kind of technical conversation between Data and LaForge.
DATA: "Do you think cross-modulating the tachyon flow whilst discombobulating inverse phase frequency arrays using the fundamental wavetable output of the universe will thwart the evil Vocodions?"
DOVDER: "No. I think shooting them to death is probably the answer."
I know pseudo-science speak has been done before on this forum but I couldn't resist. Very Happy
This message was brought to you from Beyond The Grave.
Jason
PostPosted: Thu Jul 28, 2005 4:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great topic.
I have always loved the sound of Cross Modulation.
It took me years to find out what it was and how to achieve it.
Finally when I purchased my Roland Jupiter-6 I found what I was looking for. It has some very serious potential especially when used in conjunction with the oscillator sync function for those looking for such things.
PostPosted: Sun Oct 09, 2005 6:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Just a bit of extra info on Xmodulation.
It's the classic application of chaos theory in music.
By using the output of a linear system to control the second linear system which controls the first we create very complex patterns from two very predictable sources. The relative frequencies of each will determine the likelihood of true chaotic behaviour.
Also the 2 extra frquencies produced are F1-F2 and F1+F2. The F1-F2 bit is what a theramin uses to create an audible tone from 2 Radio fequencies Wink
See ya,
Andrew
Audio files: 235
PostPosted: Sun Oct 09, 2005 7:24 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't want to be nit pickey but that is a bit of an oversimplification. The sum and difference frequencies are generated when you use a multiplier circuit. The frequency components from frequency modulation are more complex. The results are different when you use linear (Chowning/DX7) exponential FM (used in most modular synths). FM is so complicated at large modulation indexes that it's very difficult to get an intuitive feel for it.
Mohoyoho
PostPosted: Sun Oct 09, 2005 8:22 am    Post subject: Reply with quote  Mark this post and the followings unread
I just tried this on my Moog Modular V2 vst. Cool effect! I never would have thought of this. It can get really crazy. I love putting it through the step sequencer. Thanks for the tip!
Mark Mahoney
Kingsport, Tennessee
www.cdbaby.com/cd/markmahoney
Mohoyoho
PostPosted: Fri Oct 21, 2005 8:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's a Moog Modular V2 sequence using the cross modulation method that Mosc describes. You can hear the distorted warbling.
CrossModSeq.mp3
Cross modulation sequence on Moog Modular V2
 Filename:  CrossModSeq.mp3
 Filesize:  292.65 KB
 Downloaded:  2371 Time(s)
Mark Mahoney
Stanley Pain
Audio files: 10
G2 patch files: 35
PostPosted: Mon Sep 04, 2006 2:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
i did this for another forum, just thought i might as well stick it in here too.
there's no I in TEAM, so let's all act as individuals instead
