Will there be a new os soon?
Page 3 of 4 [91 Posts]
3phase
G2 patch files: 141
PostPosted: Fri Dec 01, 2006 8:43 am    Post subject: Reply with quote  Mark this post and the followings unread
one thing regarding the musical quality of a fixed filter bank...
The one that was implemented in the NM1 sounded really crap in my opinion... it was a rarely used module by that reason i guess.
Probably clavia dropped it beecause a good sounding one would have been a 40% module...
If such a thing like a fixed filter bank comes it should do way more than just filtering on specific frequencies... The moog filterbank isnt academic at all..
i only once had the ability to try it and it was on any band an exiting boost for the musikcal signal...
something that wont happen on a simple digtal filter.
If you look for goodsounding digital Eq´s you anway have problems finding one...
However i would like to see an expensiv filter bank module... can have an own dsp when its giving true exitement... like the vocoder on the NM1..
super expensiv module there..but often used never the less.
A filter bank in the g2 should be a sonic enhancer not an academic module.
maybe thats the problem clavia has with it...they tend to like it academic..but they maybe oversee that something like max msp is as academic it can get..The advantage of the nords is that they have a more realworld feeling to them..a non academic feeling..
wouldnt weaken the concept if there would be one module that grabs a few analog modeling tricks...
The did it in theire stage piano...so they have the knowledge to do it.
3phase
G2 patch files: 141
PostPosted: Fri Dec 01, 2006 8:51 am    Post subject: Reply with quote  Mark this post and the followings unread
But...
is there a schematics of the moog filterbank availible elswhere on the net?
maybe a little rebuild version szised as a micromodular to sit on the right corner of a G2 ?
intoxicat
PostPosted: Fri Dec 01, 2006 10:28 am    Post subject: Reply with quote  Mark this post and the followings unread
[quote="mosc"]
Robby wrote:
Beginning synthesists seem overly concerned about the waveform of the oscillators - thinking this is the most important aspect of synthesis. IMHO, waveforms aren't very important, it's the changing of the waveform over the range of the instrument that gives it it's character. Consider a violin, or clarinet for example. The body of the instrument acts to filter the sound differently for each pitch - so every note has a different waveform - even though the excitation doesn't change too much (stings are saws - brass are squares - generally speaking). The body resonance is often referred to as a formant. The formant filter is traditionally implemented with a fixed filter bank on modular synthesizers.
I totally agree with this. Custom waveforms have never been important to me and I am not a particularly experienced synthesist
Audio files: 235
PostPosted: Fri Dec 01, 2006 6:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://www.physicsenterprises.andrews.edu/diy_archive/manuals/moog/modular/mod_22.gif
3phase
G2 patch files: 141
PostPosted: Sun Dec 03, 2006 11:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok...thanks...
explains on the first look why this thing sounds good..
a coil eq with class a circuit... thats alone enough to sound good on a eq..
But we have that on the famous vermona filter bank aswell
(the one you can get for 20 euros from time to time because nobody knows..ups...
shit..i probably just destroid the price Wink
But... the moog one is sounding better than the vermona...(which is allready very good)...
Thats for sure the special moog selection but also some tricks he developed that look rather for sound quality than scientivic correctness..
I for example heard the rumour that moog artificial noisend up the power supply to make the synth in general sound thicker... ???
Can anybody back that rumour up?
I see in the chematics a +12/-6 V supply that is rather unusual...
Why he done it that way and not the usual +15/-15 or alike supplys?
The vermona fixed filterbank (stereo) is powerd with just +12 V...
dont make it to a pro mastering equalizer but a wonderfull shaper and distorter for synthsounds...
A friend from me from Air Liquide claims that a 303 without a Vermona distortion is no 303 Wink
However..has Moogs choice to power things this halfsymetrical way something to do with distortion propertys?
monobass
G2 patch files: 12
PostPosted: Mon Dec 04, 2006 5:55 am    Post subject: Reply with quote  Mark this post and the followings unread
[quote="intoxicat"]
I think it totally depends how you want to use the G2. Sometimes I like patching for hours and hours.. sometimes I want to get something unique up and running in a few minutes and custom waveforms would definitely be good for that kind of situation.
Steve
dorremifasol
G2 patch files: 49
PostPosted: Mon Dec 04, 2006 6:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Aren't custom waveforms already available by using chained sequencers? I guess you are talking about BIG custom waveforms?
Albert
monobass
G2 patch files: 12
PostPosted: Mon Dec 04, 2006 6:20 am    Post subject: Reply with quote  Mark this post and the followings unread
I've never been able to find a good balance between the need to smooth chained sequencers for this technique and the obvious loss in high frequency content... if anyone has any tips let me know Smile
Steve
Audio files: 235
PostPosted: Mon Dec 04, 2006 10:09 am    Post subject: Reply with quote  Mark this post and the followings unread
The original Moog Modulars were designed before the availability of IC op amps. Moog used discrete bipolar transistors almost exclusively - an occasional discrete JFET. The +15/-15 supplies didn't become commonplace until the 1970s when the op amps hit the market.
As for intensional noisy power supplies, I don't think that is the case. When I got my Moog Modular in 1972 it had some power supply noise. Moog sent me a replacement. I scoped it before installing it and it was very clean even under load.
Moog generally tried to design circuits that were as clean and accurate as possible. He did select the frequencies of the filters in the fixed filter banks with a lot of thought. He studied the spectra of many classical instruments and tried to pick frequencies in the ranges where they would be the most musically useful.
I'm not so sure that if he would have designed the filter bank circuits a few years later he would not have dumped the coil designs and and used op amps.
cappy2112
PostPosted: Mon Dec 04, 2006 6:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
windchill wrote:
It's certainly time for an update of the OS - at least a bunch of bug-fixes should be added. Do any Clavia staff read this forum? Given that a lot of the G2 owners congregate here it would be nuts not to. I remember, during a time when there were complaints on the Reaktor forum, that no less than the MD of Native Instruments himself turned up and got involved.
Oh yes... and I'm one of those who thinks a small amount of audio ram is essential for the G2 - and quite harmless to those who don't want it!
Well they did release the version with the patch mutator, but I don't think it was as popular as they had hoped. I think they really poured a lot of resoruces into it, instead of the many requests we had wished for.
3phase
G2 patch files: 141
PostPosted: Mon Dec 04, 2006 9:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
maybe..but maybe you wouldnt love the filterbank so much than...
And it probably wouldnt have been a fixed filter bank than..thats the big disadvantage in coil designs..they are fixed to a band...but so much more musical in the sound quality.
I never came along some good explanations why this is the case but it seems to be a complex issue. Otherwise we would have seen better digital emulations yet.
3phase
G2 patch files: 141
PostPosted: Mon Dec 04, 2006 9:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
I agree but my guess is that the patchmutator might be involved in theire next product aswell and they push it therefore with the G2.
The bit lousy but popular demand for keyboards that just bring good sounds without the need to go deep into patching might have motivated that.
I know many people that still just use presets..This just dont is so easy to hear anymore because of the huge amount of plugins used this days... 3 plugs with 3 presets in a row give a new sound.
However...within the next 3 month we will see what clavia is up to...and maybe than we will know if they give the G2 the last push we probably all hope for
windchill
PostPosted: Tue Dec 05, 2006 2:36 am    Post subject: Reply with quote  Mark this post and the followings unread
I cracked ... and emailed Clavia to ask them if a new version of the os, including bug-fixes, is underway ... and when it might be available.
They replied really quickly:
"Our development department has not yet issued a release date on the next update. There is one planned though, but as to when it is not possible to say."
Mmmmmm ........
monobass
G2 patch files: 12
PostPosted: Tue Dec 05, 2006 6:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Exactly what they kept saying when we were waiting for the update on the original nord mod... not that it means they WON'T update.
I really like the patch mutator, I was very glad to have it.. but you can't get away from the fact that the overall reception was lukewarm.
Steve
Fozzie
G2 patch files: 49
PostPosted: Tue Dec 05, 2006 6:57 am    Post subject: Reply with quote  Mark this post and the followings unread
IMVHO this is great news!!!! Before, they refused to say whether there would be any update (they didn't say there wasn't going to be one either, it was kind of an 'we confirm nor deny' policy), so this is one step in the right direction.
I can be patient.....
Anyone heard any additional news already? Wink
cappy2112
PostPosted: Tue Dec 05, 2006 8:41 am    Post subject: Reply with quote  Mark this post and the followings unread
[quote="Fozzie"]
Yes- very encouraging!
windchill
PostPosted: Tue Dec 05, 2006 10:27 am    Post subject: Reply with quote  Mark this post and the followings unread
I wish I could share the enthusiasm. It's pretty much a year and a half since the last update (and that was mainly the mutator) - and the next update is merely a plan - not an ongoing project - merely a plan!
After this length of time I would have expected a reply more like "our development team have been working on the new upgrade for some months now ... a very provisional release date is ........"
dorremifasol
G2 patch files: 49
PostPosted: Tue Dec 05, 2006 10:38 am    Post subject: Reply with quote  Mark this post and the followings unread
I think that the plan they are referring to is the date, the planned date, not the update.
I bet that they have done at least some changes, they need to keep all of their few products alive, unless they release a sucessor which is unlikely for the G2 yet.
Remember that they have now only 5 product lines, and one of then is a re-release (nl2x).
Of course I'm only guessing...
Albert
Fozzie
G2 patch files: 49
PostPosted: Tue Dec 05, 2006 10:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Clavia is notoriously uncommunicative on their plans. Especially since the previous update got delayed and delayed, I am not surprised they won't name a date to prevent this from happening again.
If I remember correctly they said a while back that they weren't working on an update nor did they have one planned. That has changed apparently, therefore I am enthousiastic. Well, I guess I am the optimistic type Cool
cappy2112
PostPosted: Tue Dec 05, 2006 11:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Another thing to be aware of- from their point of view, any changes to the G2 OS probably won't make much money (if any) from them, but will cost them developer time. Even if they added every single item on our wish list, and fixed every bug, it is not likely that these efforst will generate lots of revenue.
Audio files: 235
PostPosted: Tue Dec 05, 2006 11:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Maybe we aren't looking in the right places for their communication. Check out this post. http://electro-music.com/forum/topic-14771.html Wink
windchill
PostPosted: Tue Dec 05, 2006 11:35 am    Post subject: Reply with quote  Mark this post and the followings unread
if it would make a difference they could charge me $50 for the update. I pay for Reaktor updates - and think that's fair enough. I would rather have a reliable, regular update at a small cost than nothing.
It's not right to say that Clavia will not get revenue from upgrades to the G2 OS. Failing to upgrade may have a negative impact because some users may choose not to buy a G2 - if they see that the feature set is lacking, or buggy. This would have a negative impact on revenue. In fact this whole thread was begun by someone who was unsure if they should buy a G2 or not.
dorremifasol
G2 patch files: 49
PostPosted: Tue Dec 05, 2006 11:49 am    Post subject: Reply with quote  Mark this post and the followings unread
I still think that an OS update announced at NAMM will make a "hey I'm here and now I'm better!" effect on the market for the G2. A good update may have a sort of re-launch effect which is always desirable for any company.
Wasn't the patch mutator released with the last winter NAMM?
(seems that my english is improving, I pass the SpellCheck test!) Very Happy
Albert
monobass
G2 patch files: 12
PostPosted: Tue Dec 05, 2006 12:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd happily pay for updates and continued support.
We all know this is never going to be a mass-market product..
I think the problem is that it would also put people off buying it in the first place... so we're left in the situation where Clavia basically will remain willfully mysterious about their intentions. It's pure politics and very frustrating.
Steve
intoxicat
PostPosted: Tue Dec 05, 2006 1:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
problem with paying for updates would be to restrict the users sharing the updated freely. protected sofware is just a pain the arse... might not even be possible on the g2 anyway
