Electronic Drums: TwinT around CMOS inverter?
Page 2 of 2 [35 Posts]
Goto page: Previous 1, 2
PostPosted: Tue Sep 15, 2015 6:27 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome party!
soundust
I see that cheshire Spock has already given some logic answers. As for the diodes, if they aren't marked
you can just use some general purpose diodes (no zeners).
soundust
PostPosted: Wed Sep 16, 2015 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your replies guys!
I was hoping to experiment with the circuits virtually before I start assembling them, but I reckon I will have to embrace the breadboard. wish I had a scope though..
gasboss775
PostPosted: Tue Feb 16, 2016 1:20 am    Post subject:   Reply with quote  Mark this post and the followings unread
I had another idea for a gate to trigger circuit here
gasboss775
PostPosted: Tue Feb 16, 2016 9:18 am    Post subject: Elektor Drum Reply with quote  Mark this post and the followings unread
I've been experimenting with that Elektor Drum circuit that YuSynth posted on: Wed Aug 27, 2008 11:57 pm
Have made some improvements.
1. Have increased the resonance of the twin T circuit which subsequently overdrives the amplification stage that follows. The resonance pot effectively determines the level of overdrive in the next stage.
2. Have created a second path for the impact part of the sound, the level of which can be adjusted by a pot
 Filesize:  56.9 KB
 Viewed:  370 Time(s)
gasboss775
PostPosted: Tue Feb 16, 2016 1:45 pm    Post subject:
Subject description: Further developments of the Elektor Drum
Have made further improvements to the Elektor bass drum. I'd hoped to build a VCA with one of the 4069 gates, tried using a vactrol to make a variable gain amplifier with the 4069, but attack time was just a bit too slow. In the end I conceded and used the trusty Roland VCA with npn transistor and an opamp.
 Filesize:  82.4 KB
 Viewed:  376 Time(s)
gabbagabi
PostPosted: Thu Feb 18, 2016 11:29 am    Post subject: Reply with quote  Mark this post and the followings unread
from the archive
edit
better scan quality in the attached pdf
 Filesize:  131.06 KB
 Viewed:  422 Time(s)
buch_scan_rythm.pdf
 Filename:  buch_scan_rythm.pdf
 Filesize:  1.87 MB
 Downloaded:  528 Time(s)
gasboss775
PostPosted: Fri Feb 19, 2016 3:07 am    Post subject: Reply with quote  Mark this post and the followings unread
@g.gabba thanks
4011 doesn't seem like the obvious choice. I wonder if there's any sonic difference when using a 4011 rather than an inverter like 4049 / 4069. Will probably try both and see if there is a difference.
What book did you get these from?
gabbagabi
PostPosted: Mon Feb 22, 2016 3:02 am    Post subject: Reply with quote  Mark this post and the followings unread
hi gasboss775,
its was german book from the library about repairing elektronic instruments, think it was from "FRANZIS",
may the 4011 was more common (= cheaper) in the time the book was written ?
cheers
gabbagabi
gasboss775
PostPosted: Thu Mar 03, 2016 12:13 pm    Post subject: Twin T Bass Drum Reply with quote  Mark this post and the followings unread
This is the latest version of a Twin T / Vactrol based Bass Drum that I have developed with Muff Wiggler user PWM.
 Filesize:  90.48 KB
 Viewed:  363 Time(s)
LFLab
PostPosted: Thu Mar 03, 2016 11:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
No more CMOS? Very Happy
Must give that vactrol vca a try, I wonder about the response.
Edit: o wait, that vactrol influences the resonant frequency, interesting, sound samples?
Any who, great work!
