Recent Changes - Search:
go to the forum
Contents
Site
Help
« sep 2025 · jan 2026 »
    add a calendar item
    Schematics / SMD 2040 Filter
    < ARP Quadra Phase Shifter | Schematics | Real Ring Modulator and Modem >
    < VCF by Phobos | Listbytype | ETI VCF design by Trevor Marshall >
    DIY | Filter | VCF | 2040 | René Schmitz | Jürgen Haible
    SMD 2040 filter by René Schmitz ,visit http://www.uni-bonn.de/~uzs159/index.html for more info on this circuit along with useful tips on Synthesizer DIY . From the notes on this filter by René :
    This VCF has been heavily influenced by Jürgen Haibles SSM 2040 filter clone. I constructed it using mostly SMD parts, hence the name. The circuit differs from Jürgens, in a few details. I operate the filter core with different supplies. (+15V,+5V,0V) Thus I didn't need to lower the ground of the expo convertor. I omitted the voltage controlled resonance, because it is easy enough to get. If you have a spare VCA you can patch it if you need it. I'll maybe add it later, when I do a board revision.
    Edit - History - Print - Recent Changes - Search Page last modified on 2013-02-24 17:59 [UTC-7] - 5201 views
