Schematics / Saw Animator By Yves Usson
< Serge Triple Wave Shaper | Schematics | this is a circuit i accidentally breadboarded > DIY | Wave Shaping | Saw | Yves Usson | Bernie Hutchins | Scott Bernardi From the description given by Yves : The Saw Animator module is a very interesting module when you whish to get that FAT sound, usually obtained with two or more sawtooth VCOs, but you are short of VCOs. You can get this typical sound with only one sawtooth VCO, thanks to Bernie Hutchins (JAES, 1981). The Digisound 80 has this wonderful module and Scott Bernardi designed a version of its own. The present module is a somehow simplified but yet efficient version. To get the best of this module, it must be used in conjunction with a mixer. I chose not to integrate a mixer within the module in order to benefit from the dry outputs which are very useful when used with a LFO instead of a VCO. When used with a sawtooth LFO and inputing fixed CVs in the MOD inputs, one can achieve some interesting phase shifted modulators such as quadrature modulation. Well the possibilities are numerous and it's up to your imagination... ![]() ![]() ![]()
< Serge Triple Wave Shaper | Schematics | this is a circuit i accidentally breadboarded > |
Edit - History - Print - Recent Changes - Search Page last modified on 2013-02-24 14:36 [UTC-7] - 5862 views
