Recent Changes - Search:
go to the forum
Contents
Site
Help
« sep 2025 · jan 2026 »
    add a calendar item
    Schematics / VCA-Inverter-Overdrive
    < Buchla 1110 Ring modulator | Schematics | Voltage Controlled OpAmp RingMod by >
    < CMOS based VCA | Listbytype | SSM2164 Based VCA's >
    DIY | VCA | Inverter | Distortion | Jürgen Haible
    VCA/Inverter/Overdrive by Jürgen Haible .Visit his page for various schematics http://www.jhaible.de/additional_schemos.html ,on this module he wrote :
    One input is routed to the output via two separate paths: One VCA with zero to positive unity gain (approx.), and one manually adjustable path with zero to rather high negative gain. The output voltage is clipped by a set of zener diodes, so the module can also act as Overdrive / Distortion device.
    Edit - History - Print - Recent Changes - Search Page last modified on 2013-02-24 16:37 [UTC-7] - 1243 views
