jamos
Joined: Jun 01, 2004 Posts: 514 Location: Eugene, Oregon, USA
G2 patch files: 41
Posted: Fri Jan 07, 2005 10:32 am Post subject:
Bug |
I just discovered something wierd..
If I'm editing a performance w. the editor (Win XP SP1), and have the G2 in Global mode, then pressing R kicks the synth out of Global mode (in addition to starting and stoppong the sequencer, as it should.)
Has anyone else seen this? |
zynthetix
Audio files: 10
G2 patch files: 13
Posted: Fri Jan 07, 2005 1:37 pm Post subject:
| It does it for me too (Win XP also). The hot keys list says that R is supposed to Toggle Master Clock (=run/stop & can send midi start/stop from G2). I am guessing that the G2 is not able to toggle the master clock this way in global mode. |
Joined: Jan 31, 2003 Posts: 18276 Location: Durham, NC
Audio files: 233
Posted: Fri Jan 07, 2005 1:40 pm Post subject:
I would be totally shocked if it didn't do the same for me. It does. _________________ --Howard
my music and other stuff |
rnp
Posted: Sat Jan 08, 2005 3:33 am Post subject:
the same thing happens when I hit "r" in the Mac OSX editor while in global mode. _________________ http://www.regicide.org
deer music
offering temporary solutions |
Joined: Apr 03, 2004 Posts: 24584 Location: The Netherlands, Enschede
Audio files: 309
Posted: Sat Jan 08, 2005 6:33 am Post subject:
What do you all mean with "global mode" ? "Global panel mode", "global parameter pages" or some MIDI global mode ?
My manual seems to know nothing about plain "global mode", yet you seem to have agreed on some meaning for this word combination. Or dou you mean "performance mode" ?
Sorry, I can be very stupid sometimes, and I really don't get it.
Jan. |
jamos
G2 patch files: 41
Posted: Sat Jan 08, 2005 9:12 am Post subject:
| You're right, there is no "global mode" named as such by Clavia.. by that I mean when global parameter pages are selected. "Global mode" is less wordy ;'). |
Audio files: 309
Posted: Sat Jan 08, 2005 9:42 am Post subject:
Ok, thanks jamos, that's clear now.
Does this (the mode toggle) happen on the synth, in the edotor, or both ?
Ehm some explanaion might be needed, I'm running a beta currently that seems to not reproduce the problem. But I have engines only, so things may be different.
Also the version 1.26 build 212 demo version (the soft synth) does not seem to have this problem.
This might indicate hope :-)
Jan. |
zynthetix
Audio files: 10
G2 patch files: 13
Posted: Sat Jan 08, 2005 1:57 pm Post subject:
| This would be a keyboard only G2 problem. R turns off the master clock in the editor and the synth while in global parameter pages. The undesired effect is that when you have the global pages selected for the keyboard screen displays, pressing R not only turns off the master clock but kicks you out of the global pages and displays the patch settings of the selected slot as well. |
Audio files: 309
Posted: Sat Jan 08, 2005 2:48 pm Post subject:
Does this mean that the editor's "parameter pages" (Ctrl+F) and "parameter overview" (Ctrl+L) dialogs (that both have a "global mode") do not change mode along with the synth ? I had expected these to be coupled.
Anyway in my editor pressing the R toglles the clock's running attribute, but it does not end the global mode in above mentioned dialogs.
Jan. |
zynthetix
Audio files: 10
G2 patch files: 13
Posted: Sat Jan 08, 2005 2:59 pm Post subject:
| this does not effect the parameter pages window in the editor. Although I have noticed that even toggling the master clock in the editor using the mouse kicks you out of the global pages display of the keyboard. |
Audio files: 309
Posted: Sat Jan 08, 2005 3:12 pm Post subject:
Ok, I'll keep my big mouth shut then :-)
Jan. |
