Bug
Page 1 of 1 [11 Posts]
jamos
G2 patch files: 41
PostPosted: Fri Jan 07, 2005 10:32 am    Post subject: Bug Reply with quote  Mark this post and the followings unread
I just discovered something wierd..
If I'm editing a performance w. the editor (Win XP SP1), and have the G2 in Global mode, then pressing R kicks the synth out of Global mode (in addition to starting and stoppong the sequencer, as it should.)
Has anyone else seen this?
zynthetix
Audio files: 10
G2 patch files: 13
PostPosted: Fri Jan 07, 2005 1:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
It does it for me too (Win XP also). The hot keys list says that R is supposed to Toggle Master Clock (=run/stop & can send midi start/stop from G2). I am guessing that the G2 is not able to toggle the master clock this way in global mode.
Audio files: 229
PostPosted: Fri Jan 07, 2005 1:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would be totally shocked if it didn't do the same for me. It does.
rnp
PostPosted: Sat Jan 08, 2005 3:33 am    Post subject: Reply with quote  Mark this post and the followings unread
the same thing happens when I hit "r" in the Mac OSX editor while in global mode.
http://www.regicide.org
deer music
offering temporary solutions
Audio files: 299
PostPosted: Sat Jan 08, 2005 6:33 am    Post subject: Reply with quote  Mark this post and the followings unread
What do you all mean with "global mode" ? "Global panel mode", "global parameter pages" or some MIDI global mode ?
My manual seems to know nothing about plain "global mode", yet you seem to have agreed on some meaning for this word combination. Or dou you mean "performance mode" ?
Sorry, I can be very stupid sometimes, and I really don't get it.
Jan.
jamos
G2 patch files: 41
PostPosted: Sat Jan 08, 2005 9:12 am    Post subject: Reply with quote  Mark this post and the followings unread
You're right, there is no "global mode" named as such by Clavia.. by that I mean when global parameter pages are selected. "Global mode" is less wordy ;').
Audio files: 299
PostPosted: Sat Jan 08, 2005 9:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, thanks jamos, that's clear now.
Does this (the mode toggle) happen on the synth, in the edotor, or both ?
Ehm some explanaion might be needed, I'm running a beta currently that seems to not reproduce the problem. But I have engines only, so things may be different.
Also the version 1.26 build 212 demo version (the soft synth) does not seem to have this problem.
This might indicate hope :-)
Jan.
zynthetix
Audio files: 10
G2 patch files: 13
PostPosted: Sat Jan 08, 2005 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
This would be a keyboard only G2 problem. R turns off the master clock in the editor and the synth while in global parameter pages. The undesired effect is that when you have the global pages selected for the keyboard screen displays, pressing R not only turns off the master clock but kicks you out of the global pages and displays the patch settings of the selected slot as well.
Audio files: 299
PostPosted: Sat Jan 08, 2005 2:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Does this mean that the editor's "parameter pages" (Ctrl+F) and "parameter overview" (Ctrl+L) dialogs (that both have a "global mode") do not change mode along with the synth ? I had expected these to be coupled.
Anyway in my editor pressing the R toglles the clock's running attribute, but it does not end the global mode in above mentioned dialogs.
Jan.
zynthetix
Audio files: 10
G2 patch files: 13
PostPosted: Sat Jan 08, 2005 2:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
this does not effect the parameter pages window in the editor. Although I have noticed that even toggling the master clock in the editor using the mouse kicks you out of the global pages display of the keyboard.
Audio files: 299
PostPosted: Sat Jan 08, 2005 3:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, I'll keep my big mouth shut then :-)
Jan.
