Post Your KLEE Panels Designs Here
Page 6 of 16 [399 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7, 8, ..., 14, 15, 16 Next
a.b.o.z.
G2 patch files: 4
PostPosted: Tue Feb 19, 2008 2:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
almost there!!!
this was painful.
I printed image on gray paper with ink jet..clear-coated aluminum and stick paper onto that so it sticks to aluminum. then applyed two layers of clear-coat onto that.
drilling was painful. huh. glad it's over finally.
 Filesize:  139.9 KB
 Viewed:  442 Time(s)
Coriolis
PostPosted: Tue Feb 19, 2008 3:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow a.b.o.z - that is a great looking panel! Shocked Shocked
Are those bananajacks the cheap ones from futurlec? Are you having trouble with them coming loose from the panel, I mean you tighten the nuts, but after plugging and unplugging for a while, the nuts on the jacks start to come loose. I have that problem...
Man, I really need to start thinking about my Klee as well...
c
a.b.o.z.
G2 patch files: 4
PostPosted: Tue Feb 19, 2008 3:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
thnx Coriolis.
yes those are futurlec cheapest bananas. but I don't have that problem.
got patchbay on SK-1 for a while now and there's no problem..
maybe you could try and put a bit of solder on joint of nut and jack??? just a tought...didn't try this...
RF
Audio files: 28
PostPosted: Tue Feb 19, 2008 6:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
a.b.o.z - That is great!
Love the layout - Great job.
bruce
PostPosted: Tue Feb 19, 2008 11:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked that's quite fantastic!
Coriolis
PostPosted: Wed Feb 20, 2008 1:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah...gotta do something about those jacks, might try solder.
C
PostPosted: Wed Feb 20, 2008 2:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmmmm,...
Absolutely beautiful! Very Happy
seraph
Editor
Editor
Audio files: 33
PostPosted: Wed Feb 20, 2008 3:35 am    Post subject: Reply with quote  Mark this post and the followings unread
is there a missing knob on the "manual level" Question
a.b.o.z.
G2 patch files: 4
PostPosted: Wed Feb 20, 2008 4:19 am    Post subject: Reply with quote  Mark this post and the followings unread
jep, i forgot to drill it Very Happy
Scott Stites
Audio files: 96
PostPosted: Wed Feb 20, 2008 9:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Freaking awesome!!!!!!!!!!!!
My Site
zthee
PostPosted: Wed Feb 20, 2008 10:22 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm not really sure what I'm doing. But I love to design front panels.. Smile
It's designed to fit onto 2 pieces of 42HP eurorack frontpanels. I realize after looking at the awsome panel designs here that mine has a few flaws (Some places I didn't know if there was a pot, led or a swtich.. but I figured I'd get to know that eventually, and redesign afterwards..). And the double rows of LEDs come from me being tired and watching youtube (I thought I saw 2 rows of LEDs, but apparently not). Anyway I thought it could be cool to have the lower row just show the actuall step of the sequence, and the upper row the active bits.
Anyway - I'll probablt remake it once I get the whole project started.. Can't wait Cool
a.b.o.z.
G2 patch files: 4
PostPosted: Wed Feb 20, 2008 10:30 am    Post subject: Reply with quote  Mark this post and the followings unread
cool, it looks liquid
RF
Audio files: 28
PostPosted: Wed Feb 20, 2008 10:35 am    Post subject: Reply with quote  Mark this post and the followings unread
That is really nice - very unique look.
loss1234
PostPosted: Sun Mar 09, 2008 6:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
is there a basic template any of you used to start with? or a program for designing panels that already has all the knob and jack holes as templates?
i ask because i will be wanting to start this in the spring and i figure i shoud learn a good klee design program.
Scott Stites
Audio files: 96
PostPosted: Sun Mar 09, 2008 7:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I drew mine with Visio, and it's rather plain at that - maybe someone here has an FPD or something along those lines?
My Site
Sound
PostPosted: Sat Mar 15, 2008 6:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I was designing the front panel as a module of 84 hp. 3U.
I see, eg, fonik, is also 3U but for stand alone in the rack. What there is behind the front panel? Any standard case?
PostPosted: Mon Mar 17, 2008 6:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Zthee .... I really like that panel design and the graphics you use ..... Very unique and the groupings are logical Wink What are you plans to turn this into a real panel Very Happy
Bill
PostPosted: Mon Mar 17, 2008 6:51 am    Post subject: Reply with quote  Mark this post and the followings unread
i am using a schroff multipac pro rack enclosure, i bought it from rs-components (order number 469-1105). i used such an enclosure for the baby10 as well. you can use more panel space than using an eurorack frame (no srew rails on top and bottom of the enclosure).
Sound
PostPosted: Mon Mar 17, 2008 7:24 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks Fonik, Have this eclousere frontpanel? Do you do the front panel with Schaeffer?
PostPosted: Mon Mar 17, 2008 7:43 am    Post subject: Reply with quote  Mark this post and the followings unread
the enclosure consists of the frontpanel, a back panel and two side panels. one will have to order additional top and bottom covers and a mounting panel as well.
schaeffer would engrave a panel you send them. since i wanted a green anodized panel for the klee it was easier for me to let them do a new panel (the old is now resting in the drawer waiting for a future project). so i'd say i had to pay about 200.-EUR for the complete klee enclosure Shocked
vtl5c3
PostPosted: Mon Mar 17, 2008 9:38 am    Post subject: Reply with quote  Mark this post and the followings unread
After browsing through this thread, I have to say that there's some really creative panel designs for Klee.
I'm posting mine, which I laid out in Illustrator. It's not terribly special, but I got the layout to fit into some sheet-metal panels that I already had on hand. Nothing's labeled as per usual, but the flow is left to right, top to bottom.
1 big step closer to birthing a pair of Klees!
 Filesize:  133.43 KB
 Viewed:  255 Time(s)
Scott Stites
Audio files: 96
PostPosted: Mon Mar 17, 2008 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Pericles? Laughing
My Site
seraph
Editor
Editor
Audio files: 33
PostPosted: Mon Mar 17, 2008 1:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Scott Stites wrote:
Pericles? Laughing
PeriKlees maybe Question Cool
PostPosted: Mon Mar 17, 2008 4:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
C
You should try some of this stuff (usually found at auto supply stores):
http://www.loctiteproducts.com/products/detail.asp?catid=10&subid=48&plid=695
Threadlockers
Loctite® Threadlocker Green
# Prevents vibration loosening of pre-assembled fasteners
# For use on electrical connectors, instrumentation, screws, and set screws
# Ideal for fasterners #2 - 1/2"
Also comes in "red" (hi-temp), or "blue" (not sure what it's strength is).
PostPosted: Mon Mar 17, 2008 5:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Pericles?
Laughing There's that zany Stites humor again ..............
Thanks for the laugh Scott ....... as always, you put a smile on my face dude!
Bill
