Electro-Music Klee Sequencer Build and Applications Thread
Page 41 of 54 [1348 Posts]
Goto page: Previous 1, 2, 3, ..., 39, 40, 41, 42, 43, ..., 52, 53, 54 Next
loopcycle
PostPosted: Wed Mar 19, 2008 8:18 am    Post subject: Re: Mouser Switch Recommendation? Reply with quote  Mark this post and the followings unread
vtl5c3 wrote:
I kinda went ape this weekend and drilled out two panels for my two forthcoming Klees. In preparation for stuffing parts onto the panels, I need to order switches. If anyone has has ordered theirs from Mouser, which part numbers did you order?
i used NKK switches. they were expensive.
633-M201101-RO
633-M201301-RO
633-M201201-RO
the nice thing about these is that the bat handles all match. small consolation.
you can save some money if you get mountain switches instead.
Scott Stites
Audio files: 96
PostPosted: Wed Mar 19, 2008 8:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Romeo,
Here is the section of my Mouser project for the Klee - however, I ordered the really small toggles (and LEDs for that matter).
Cheerio,
Scott
Mouser Klee stuff......
 Filesize:  17.39 KB
 Viewed:  407 Time(s)
My Site
PostPosted: Wed Mar 19, 2008 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
jep you got it.
unplugged resistance +12/ground is 1K26
plugged goes crazy and freez psu
bridged with 1K works ok
Well, maybe not the most scientific fix but I would do this:
1) Remove the wire from the lead into the MANUAL STEP switch, not the ground side.
2) Connect one end of a 1K resistor to the switch terminal you removed the lead wire.
3) Connect the other end of the 1K resistor to the lead removed from the switch.
This will put the 1K in series with ground, the value that worked when bridging the switch.
Bill
a.b.o.z.
G2 patch files: 4
PostPosted: Wed Mar 19, 2008 9:50 am    Post subject:   Reply with quote  Mark this post and the followings unread
i did that already. ic wrkin Smile
thnx all
ivan
PostPosted: Wed Mar 19, 2008 4:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
thnx all
party time!
Bill
vtl5c3
PostPosted: Mon Mar 24, 2008 2:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Loopcycle and Scott!
That's what I needed.
Romeo
Photon
PostPosted: Mon Mar 24, 2008 3:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's a photo of where things are at with my desktop Klee console:
nothing is wired as of yet.
p.
don't look too close, eh
 Filesize:  298.37 KB
 Viewed:  390 Time(s)
a.b.o.z.
G2 patch files: 4
PostPosted: Mon Mar 24, 2008 4:26 pm    Post subject:   Reply with quote  Mark this post and the followings unread
OMG OMG OMG Shocked Shocked Shocked
totally awesome
Danno Gee Ray
PostPosted: Mon Mar 24, 2008 5:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
That does look gorgeous! Excellent work.
vtl5c3
PostPosted: Mon Mar 24, 2008 8:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's like the Arp sequencer's mutant cousin.
Scott Stites
Audio files: 96
PostPosted: Mon Mar 24, 2008 8:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Friggin' awesome!
My Site
Photon
PostPosted: Tue Mar 25, 2008 6:11 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks everyone!
I'll post more as progress is made. Hopefully a video at some point. I'll probably also put a build diary on the blog as time permits.
thanks again
pete
PostPosted: Tue Mar 25, 2008 6:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Photon ........ I REALLY think that is beautiful. Fine work and if we were face to face with you, I would be shaking your hand dude !!!!! Very Happy
DIY is alive and well guys !!!!! This stuff really makes my day !
Bill
Photon
PostPosted: Tue Mar 25, 2008 7:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Very Happy Thanks a lot, Bill. Very Happy
perhaps at Analog Heaven North East? I'm going to try and get myself out there. Mostly because I wanted to meet you and see your demo.
peter
Sound
PostPosted: Tue Mar 25, 2008 9:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi guys, I wanted to order the mountain switches ON-OFF 108-0001-EVX and a similar ON-OFF-ON but I did a mistake : I ordered the ON-OFF mountain switches 1055-TA1120-EVX and the ON/OFF/ON 1055-TA1135-EVX.
In my opinion they are worse than the 108-0001-EVX. It's more hard and rude to move the switch, and the stick dance to the sides (sorry my English). Also I opened both the 108-0001 and the 1055-TA1120. They are similar but the 108-0001 is better built.
So, I don't recommend the 1055-TA11... moutain switches. Also they are more expensive than the 108-....
One question:
What difference is within ON-OFF-ON switch and ON-OFF-(ON) switch?
PostPosted: Tue Mar 25, 2008 4:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe one side is momentary and returns to center OFF and the other is not ??? Thats the only thing I get from that ... Anyone else take a crack ??
Bill
Danno Gee Ray
PostPosted: Tue Mar 25, 2008 4:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would agree with you Bill. The selection in parentheses is momentary.
PostPosted: Wed Mar 26, 2008 6:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Great Klee Photon! Very original. Looks like it would be really fun to play as well. Very Happy
Photon
PostPosted: Wed Mar 26, 2008 7:51 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks Unc.!
Quick question while I have you on the line...whats the mounting hole spacing on the 2 boards?
Neither metric or inch seems to line up evenly.
peter
Photon
PostPosted: Wed Mar 26, 2008 3:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
nevermind....PCBs are mounted. Very Happy
 Filesize:  96.48 KB
 Viewed:  238 Time(s)
PostPosted: Wed Mar 26, 2008 4:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
o.
Pete,
Thanks, that sounds great !!! Hope I see you there. Wink
Bill
janvanvolt
PostPosted: Fri Mar 28, 2008 5:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
What case is this ? You got ordering info ?
My dIY - http://diy.czmok.de
Film/Music - http://gfm.me
Photon
PostPosted: Fri Mar 28, 2008 5:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Its made by Hammond, model # 1456PL3WHCWW. I got it at Allied Electronics
https://www.alliedelec.com/Search/ProductDetail.asp?SKU=806-1456&SEARCH=&MPN=1456PL3WHCWW&DESC=1456PL3WHCWW&R=806%2D1456&sid=47EC35001180E17F#
Sound
PostPosted: Fri Apr 11, 2008 9:22 am    Post subject: Reply with quote  Mark this post and the followings unread
I have two questions Very Happy
1) Say that you have the rotary switch range at 5 position. The step potentiometers are limited at 1V that means one octave. So , if one step pot is at 12h Is it an exactly half octave?
2) Why the Klee sequencer is designed without a Clock?
Scott Stites
Audio files: 96
PostPosted: Fri Apr 11, 2008 10:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Pretty much so, yeah.
I figured there was no room left for the spring and gears. Laughing
No, actually it was to break the paradigm of thinking it needed to be rhythmically clocked. You'll notice it can be triggered by nearly anything. I figured if one wanted to put a clock in it, one could be added with little trouble. Later, when doing the PCBs, it just never occurred to us to put one in. Woulda been convenient.
Cheerio,
Scott
My Site
