2009 Build Pictures
Page 11 of 16 [399 Posts]
Goto page: Previous 1, 2, 3, ..., 9, 10, 11, 12, 13, 14, 15, 16 Next
sndbyte
PostPosted: Wed Sep 23, 2009 7:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is the Soundlab I just finished. I built a case just like the WSG shown next to it in the first photo (sorry about the flash).
 Filesize:  118.82 KB
 Viewed:  284 Time(s)
 Filesize:  127.72 KB
 Viewed:  303 Time(s)
synthmonger
PostPosted: Wed Sep 23, 2009 8:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
This post deserves being sticky'ed! Smile Smile Smile
Youtube!
modular demos!
Whacky tunes!
fadeddata
PostPosted: Thu Oct 01, 2009 5:29 pm    Post subject: 2xBuchla LPG and Dual Serge Processor and others... Reply with quote  Mark this post and the followings unread
More DIY Modcan 2009
 Filesize:  2.04 MB
 Viewed:  304 Time(s)
numbertalk
PostPosted: Thu Oct 01, 2009 6:27 pm    Post subject: Re: 2xBuchla LPG and Dual Serge Processor and others... Reply with quote  Mark this post and the followings unread
Sorry for the dumb question but how do you DIY Modcan? Just because I'd love to be able to but was under the impression they only sold built modules. Did you simply replace the panels?
neandrewthal
PostPosted: Fri Oct 02, 2009 12:39 am    Post subject: Re: 2xBuchla LPG and Dual Serge Processor and others... Reply with quote  Mark this post and the followings unread
He built DIY modules in Modcan style Smile
TekniK
PostPosted: Fri Oct 02, 2009 2:13 am    Post subject: Re: 2xBuchla LPG and Dual Serge Processor and others... Reply with quote  Mark this post and the followings unread
U mean, u ask for PCB layouts of modcan modules?
numbertalk
PostPosted: Fri Oct 02, 2009 5:29 am    Post subject: Re: 2xBuchla LPG and Dual Serge Processor and others... Reply with quote  Mark this post and the followings unread
I asked I'd he'd sell a PCB and provide a BOM.
Also realized he was probably building in the format rather than exact Modcan modules. I've mainly looked at the Modcan B modules which are basically in MOTM format and forgot about the A series probably being its own thing.
frijitz
Audio files: 54
PostPosted: Sun Oct 04, 2009 2:25 pm    Post subject: handle with care Reply with quote  Mark this post and the followings unread
About all of my building this year has been putting prototype boards for the new modules behind panels. The first photo is a 3u rack panel with a Teezer, two Threelers and a 4-input VCA.
The second is a small project box with a Teezer and a DoubleDeka. When prototype testing I usually have long leads to all the pots/jacks, and for the little box I just stuffed them all in. Quite messy inside, but I checked to make sure the two oscillators don't self sync, and they seem fine. So the extensive PS decoupling used on both boards has paid off well.
Behind the box you can see my "Sprott Box" chaos generator (built a couple of years ago) including dedicated gate and trigger generators, plus a Sin VCO for external drive and modulation.
Ian
 Filesize:  85.21 KB
 Viewed:  251 Time(s)
 Filesize:  168.58 KB
 Viewed:  257 Time(s)
RF
Audio files: 28
PostPosted: Sun Oct 04, 2009 3:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Those look great, Ian.
What is your method for labeling?
bruce
www.sdiy.org/rfeng
frijitz
Audio files: 54
PostPosted: Sun Oct 04, 2009 3:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, Bruce. The labels are water slide decals (Bel). Quite difficult to work with, and they always show through a bit. The decals are followed by coating with acrylic then sanding with a block, over and over until the surface is flat. For the litttle box I sprayed the final acrylic from a distance to get a matte finish.
Ian
andrewF
PostPosted: Sun Oct 04, 2009 4:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd like to come over and play with that Sprott panel!
Are those clock-faced knobs multi-turns?
frijitz
Audio files: 54
PostPosted: Sun Oct 04, 2009 5:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shure, come over anytime! Laughing
Yeah, they're Bourns knobpots. 10 turns and very linear. Like instrumentation grade. They stopped making them a few years ago, in favor of the ones with "digital" readouts. I managed to collect a bunch from a salvage yard and my dad found some too where he worked. Before they stopped selling them they were going for ~$90, so I'm very lucky to have a bunch.
Ian
Tasmanian Alkaloid
PostPosted: Sun Oct 04, 2009 7:29 pm    Post subject: Re: handle with care Reply with quote  Mark this post and the followings unread
Ian
I like your panels Ian Smile
Do you have any samples of the Teezer/Double Dekka box, on its own?
I imagine that it would make some lovely sounds!
slacker
PostPosted: Mon Oct 05, 2009 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's a quick picture of my work in progress synth. I got fed up having to get everything out and patch it up with crocodile clips every time I wanted to play about with it so I strapped it all to a bit of cardboard Very Happy
Looks rubbish but makes it much easier to work on.
If anyone's interested top left is Rene Schmitz's 4069 VCO. Top right is a CMOS based VCF, basically a cross between the Wasp and the MXR envelope filter FX pedal. Bottom right is a Yusynth VCA and bottom left is Nicholas Woollaston's ADSR from this thread.
Hopefully one day it will all be hidden away behind a nice panel Smile
 Filesize:  212.91 KB
 Viewed:  243 Time(s)
DETOX
PostPosted: Sun Oct 11, 2009 7:16 am    Post subject: Reply with quote  Mark this post and the followings unread
whose design is that power supply?
Waldorf Pulse
slacker
PostPosted: Sun Oct 11, 2009 8:41 am    Post subject: Reply with quote  Mark this post and the followings unread
It's basically Ken Stone's CGS66 but powered by a 15 volt AC wallwart rather than a using a transformer. So it only uses one of the "18VAC" connections and "0V" and only 2 diodes.
sduck
PostPosted: Mon Oct 12, 2009 8:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's my Plague Bearer -
Plague Bearer Front
Plague Bearer Back
thundarr
PostPosted: Mon Oct 12, 2009 9:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very nice and neat as always, sduck Smile
By sharp contrast, my messy new modules... especially to the rear Wink
 Filesize:  188.84 KB
 Viewed:  193 Time(s)
 Filesize:  155.37 KB
 Viewed:  216 Time(s)
 Filesize:  145.16 KB
 Viewed:  207 Time(s)
Heavy psychedelic rock
http://www.myspace.com/landbong
Meandering ambient drone doom
http://www.myspace.com/trollmannavildtoppberg
TekniK
PostPosted: Mon Oct 12, 2009 11:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
cool sequencer panel
andrewF
PostPosted: Tue Oct 13, 2009 2:14 am    Post subject: Reply with quote  Mark this post and the followings unread
messy? no way
i like those little structures you have built to support the pcbs
here is messy (recycled pooter panel & wiring):
thundarr
PostPosted: Fri Oct 23, 2009 6:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I have something resembling a synth at last...
 Filesize:  175.12 KB
 Viewed:  12902 Time(s)
TekniK
PostPosted: Sat Oct 24, 2009 1:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
VCQ
TekniK
PostPosted: Sat Oct 24, 2009 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Lord of the rings!
Mooger5
PostPosted: Sat Oct 24, 2009 3:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Lots and lots of cool pictures here. Why didn´t I choose the 5u. I hope the Eurorack will not put me off and these boxes won´t end up in the ever growing "to do" list.
Currently toying with the (lack of?) ergonomics and ramdom Dymo labeling just to get the feel of the whole thing prior to erm... actually build circuits...
LetterBeacon
PostPosted: Wed Oct 28, 2009 3:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's taken about a year of toiling over a soldering iron, but I have finally finished my first row of modules! In lieu of decent photographs I have uploaded a video from my iPhone - the picture quality isn't great but the audio is pretty decent quality.
The modules from left to right are:
ARP Odyssey MKIII dual VCO
YuSynth ADSR (although it's not being used in this patch)
YuSynth Minimoog LPF
Buchla 208 Random Voltage Generator
MFOS Buffered Multiple
CGS Utility LFO - this is in a temporary panel made from perspex.
Thomas Henry VCA
A massive thanks to everyone who's helped me get this far with it!
I'll post some good quality photos up when I have access to a decent camera.
