The Thomas Henry Mega Percussive Synthesizer
Page 29 of 31 [763 Posts]
Goto page: Previous 1, 2, 3, ..., 27, 28, 29, 30, 31 Next
JoeMorris
PostPosted: Mon Jul 08, 2013 12:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow, thanks - I can't believe I didn't know that! For some reason I made the assumption the pinout would be standardised on these. Knew it had to do be something simple I was missing. This has surely got to be the answer.
JoeMorris
PostPosted: Mon Jul 08, 2013 8:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Well that certainly helped!
The LMs no longer die and I have a perfectly working impact section - sounds coooool. However, I am getting nothing from the noise section (tracing it it seems to be very low level noise all the way through, never getting amplified), and the shell section seems too quiet, with a short decay and a rather distorted sound. Also the ring modulator signal bleeds through all the time, though that may just be because I have it turned right up due to the low shell volume, I dont know. Now where do I start is my question! Wink
PostPosted: Mon Jul 08, 2013 9:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Two things. That sounds almost exactly like what I was experiencing. Here was my first finding:
So the discovery of the evening (so far) is that setting the ring mod balance seems to be affecting the level regardless of whether the ring mod depth is set to zero. The level is still significantly lower (it seems to me) than the other sounds, but it's much better with the balance set either all the way down, and best with the balance set all the way up. As in closer to 3Vpp better at J2.
Second:
I just verified all my resistors and pots are correct; only one exception, the CV range pot R85 is 10k instead of 100k. Since I'm not trying to CV this yet, I don't see that being my problem (and the pot is one of a couple that are entirely surrounded by panel wires, so I will not be fixing it right away).
I did recently hear of someone who was having problems with a completely different module until they put in an input attenuator (they were doing bananas and didn't want one). So I'm reconsidering whether that 10k mistake might have some relevance as well.
What I did though was to just run through a 4 line submixer that effectively acted as a preamp.
JoeMorris
PostPosted: Mon Jul 08, 2013 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks so much again for getting back - yes - I too have noticed the ring balance affects the shell volume which is strange, no? The shell volume is OK at max for now but would be good to understand why this is happening. I don't even have the cv pot attached as of yet so don't see how that can be affecting it?
Re noise, where in the chain should it first be reaching audio volumes? After the Envelope?
PostPosted: Mon Jul 08, 2013 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'll have to look at the circuit when I'm at home, which will be many hours from now. The system I was talking about was an MOTM-440, and apparently the input would not work without the (very simple) input attenuator. I haven't grasped why that was either, but figured it might be worth checking.
One thing could be--is the CV supposed to be normalled to ground? Or if you're using bananas, maybe it can't be that way and needs something to pull it to ground when there's no input? Dunno....
I'll see if I can find time to look at it tonight (which is in doubt) or tomorrow night at the latest.
JoeMorris
PostPosted: Mon Jul 08, 2013 1:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your input....Really keen to get this thing nailed! The other thing I have noticed - should the shell output be a pure triangle wave? mine seems rough and noisy, especially at low pitches, sounds quite cool for snares etc but not sure if it is right...
NoizeToyz
PostPosted: Tue Jul 09, 2013 1:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Joe, nice to meet another modular DIYer from Brighton! I've built two of these, and both have the same thing you mention about the balance control affecting the Shell volume even with no ring mod dialled in.
The Shell is loudest when balance hard-right, quietest when centred, and medium loud when hard-left. When the ring mod is turned up you get the strongest effect with balance centre. I think it might be part of the circuit design, and can be quite good to get different tones from the Shell. The Shell is very much quiter than the Impact and noise, not sure how it could be boosted to get it to equal power.
PostPosted: Tue Jul 09, 2013 6:53 am    Post subject: Reply with quote  Mark this post and the followings unread
What's weird is the docs say it should be 10Vpp, so loudness should not be an issue. I wonder what's different about our components that is leading to this. Have to re-read again and see if I overlooked something.
JoeMorris
PostPosted: Sun Jul 21, 2013 9:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey NoiseToyz, I'm up in London now actually but am a regular return visitor to btown (should update my profile!). Your video was useful! Threw in the towel and got myself another MPS board and gonna rebuild it, hopefully if I get the new one working it will be a lot easier to work out where the other one is going wrong and I can end up with a two voice.
For now replaced the XR chip with a new one from cricklewood and that solved the noisy shell section, but it is still quiet, also still have ring mod bleed.
peng
PostPosted: Thu Jul 25, 2013 5:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
kkissinger wrote:
jumunius wrote:
kkissinger wrote:
Incidentally, I added pitch CV in two places:
Cool, thanks Kevin. I remember reading somewhere that Thomas was concerned about "large or negative" voltages being used for CV and blowing an IC -- is that an issue here? Anything I'd want to avoid patching in?
Those nodes appear to be ok -- note that they are fed from the front panel control that swings to 15v. I haven't blown anything from these mods... but I say this with the disclaimer that your results may vary. Smile
I implemented the Noise Filter external CV like this -
diode in the feedback loop of IC6b:
anode to pin 7 (output pin) and cathode to pin 6 (inv input).
This protects against negative voltages.
Kludged in a 33K resistor. This goes from IC6b pin 6 (or the junction of R64 and R65, same thing). The other end is wired and heat shrunk and soldered to the J13 header (this is for pcb REV 107).
33K seems to give near the full swing of the Noise filter cutoff.
I used the input to impose LFO rhythms over the Noise while playing. You can also hook a voltage pedal here to change the character of the Noise as you play.
That portion of the circuit is like the "Improved Linear Current Source" from the TH 3080 book.
Another change I made was to increase the levels. I replaced the R40, R91, and R92 200k resistors with 100K. I also replaced C29 with a 3.3uF bipolar cap.
I've been playing these with piezo drum pad triggers.
The MPS has good dynamic response and is so much fun to play.
Oh Mr James
PostPosted: Thu Jul 25, 2013 6:51 pm    Post subject:  MPS Rev 107
Subject description: Team Document- Assemble!
Hello electro-music Smile
I have recently purchased a pair of MPS PCBs, rev 107.
After reading through this thread
I still find myself slightly unsure of which are
the most current schematics and front panel requirements.
I was wondering if someone could repost them?
Perhaps other people would find it useful too, especially if there's a new batch of PCBs out Smile
Or if there's a link to this info, it would be much appreciated.
First post, but I've been studying this site for about a year.
It's a fantastic resource , you've taught me so much!
Thank you to all the kind inventors for sharing their knowledge.
jumunius
PostPosted: Thu Jul 25, 2013 10:18 pm    Post subject: Re: MPS Rev 107
This thread is so long it's a wonder anyone actually figures out how to build these things.
Firstly, get the most official docs from Birth of a Synth. "MPS Theory" is worth a read but "MPS build" is where you'll find schematics, BOM, etc.
Here's a very useful reference graphic for figuring out where the board wiring goes.
The most thorough and digestable front panel realization of the MPS design is at Bridechamber. And of course if you happen to use MOTM format or are building this into a box, you might even consider buying a panel.
Maybe a year or so back, someone did a great wiring diagram that conforms to the Bridechamber panel but it appears to have disappeared. If you scroll back somewhere between pages 10 and 20 you'll find Bugbrand's wiring diagram, but be aware that his layout doesn't quite conform to every aspect of the schematics. (Different implementation of the Impact/Noise CV switch, no Line Level Out, no individual send/receives, etc.)
-Jim
Oh Mr James
PostPosted: Mon Aug 12, 2013 6:20 am    Post subject: MPS Rev 107
Subject description: A few simple questions
Thank you for the near instant and detailed reply to my last question
I have my PCBs populated ,less the Capacitors and jumpers-
Which leads me to my question
What are the recommended Jumpers for this PCB?
(as in header pins type of thing)
I know they are not essential, but sure help tidy things up!- and I can't mention how many wrong types I have ordered!
Also, there are specific types of Cap mentioned in the parts list.
Can anyone recommend some suitable Disk and Mylar Caps?
I can't wait to get these Drum Beasts going- Thanks electro-music Smile
James
01012k7
PostPosted: Sun Oct 13, 2013 1:29 am    Post subject: Reply with quote  Mark this post and the followings unread
hi guys me and a friend have been working this project we had the nomal problem with the XR 2206 batch 0919 the version I have now is the 0918 not shure if any one had this batch version I got it form littlediode was a round 7 pounds we tested it with a oscilloscope well a friend did as I am such a newbie Smile here a picture we are going to add midi to it I made the case and the box and the oak panels he did the wiring as it was very confusing Sad because he been into electronics for years and is a cad designer he done a cad drawing of the wiring. I try and get him to give me a copy also if we done any thing wrong it would be good to have feedback ..
 Filesize:  2.43 MB
 Viewed:  839 Time(s)
NoizeToyz
PostPosted: Thu Oct 24, 2013 4:36 pm    Post subject: Shell Pitch Control suddenly not working Reply with quote  Mark this post and the followings unread
Hi All,
The shell pitch control has stopped working on one of my MPS's. It's just outputting a very hi pitched triangle wave. I checked with a scope and the output pin 2 of the XR2206 is still giving a pure triangle so the chip must be working.
The noise and impact generators are also working as normal, so it must be something to do with the voltage control circuit going to pin 7 of the XR2206. CV Range, Sweep, and Pitch controls all have no effect on the Shell section.
I can't see any evidence of burn-outs but I'm wondering if it might be the transistors Q7 and/or Q14 that might have blown?
I set the mod switch to impact and turned up the CV range control to maximum and this signal appears at the one side of R75 - [8v p-p square], but on the other side of the resistor it's only just measuring on the scope, and pretty blurred and noisey.
Anyone super clever here that might know what's going on from my very basic description?
Cheers!
PostPosted: Thu Oct 24, 2013 6:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Have you checked the DC value on the far side of R75? I'd say your guess about the transistors is where I'd be looking first as well.
NoizeToyz
PostPosted: Fri Oct 25, 2013 9:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey elmegil!
No - what value should I look for here?
Testing and troubleshooting are the areas I need to put some work into. I've only got a basic working knowledge of electronics and need to widen my knowledge of circuit design to help inform my troubleshooting.
Do you recommend any good books as primers here? Ray Wilson's Make Analogue Synthesisers book seems a good place to start...
Ed
PostPosted: Fri Oct 25, 2013 10:52 am    Post subject: Reply with quote  Mark this post and the followings unread
I unfortunately have no complete references to recommend. I would say Ray's book is helpful, but still a bit basic.... a good place to start if you want to build skills.
The way I approach it generally is to think about how things should be, or failing that, compare them to a working version of the same (assuming one is available).
I was just working on a filter with bad integrator caps, but it was a filter type I've not worked on before so I got all wrapped up in "how does this part make that part behave" and 'are the chips any good' (which i tested them all and they were).
In the end, DC comparison between a working and non-working version led to a cap that was shorted, at which point I looked at all the caps and realize that both integrating caps were damaged.
What led me there was the realization that the cap had to be a dead short because I was getting the DC value on the other side passed through.
So my point in checking the DC: if you read -15V (or nearly so) at the base of Q14, it's a very likely thing that the transistor is bad, you won't just be guessing that it might be.
If I get a chance this weekend I will try to remember to post some DC readings from around that area, and maybe some scope shots as well.
NoizeToyz
PostPosted: Fri Oct 25, 2013 12:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes I see your logic - I just had a poke around with my multimeter and ran a comparison with my other working MPS and noticed that the collector of Q7 seems to be 'stuck' at 1.02v even when I move the shell pitch.
The reading on my working MPS changes voltages here, and everything else seems to be reading the same so I guess it must be Q7. I don't have any others around but will swap it out and see if it makes a difference...
Thanks for ya help!
PostPosted: Fri Oct 25, 2013 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Might be Q14 too. Not a lot of current would be going through Q7's base relative to the current that would be going through Q14.
Assuming you have a 15V system, 1.07V is 13.93V drop from the supply, across that 100k resistor, that means you're getting a constant 139.3uA through that resistor (give or take tolerances). Base->Emitter currents are very small relative to Collector->Emitter currents generally (the gain of a typical 2N390X BJT is around 200), so most of that seems likely to be going through Q14 rather than through Q7.... though if Q7 is busted that all breaks down too Smile
If it were me and I didn't care which was at fault, I'd replace both of them. If I did care, I'd do one at a time, but be prepared to do both.
01012k7
PostPosted: Sat Oct 26, 2013 2:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
still have a few things to sort out like some paint work , screws ad some words for midi learn and midi in and stuff here the insides
 Filesize:  3.16 MB
 Viewed:  780 Time(s)
 Filesize:  1.98 MB
 Viewed:  831 Time(s)
 Filesize:  3.49 MB
 Viewed:  775 Time(s)
 Filesize:  2.37 MB
 Viewed:  806 Time(s)
 Filesize:  3.36 MB
 Viewed:  768 Time(s)
01012k7
PostPosted: Sat Oct 26, 2013 2:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok I am using the mincv
 Filesize:  2.37 MB
 Viewed:  765 Time(s)
 Filesize:  4.63 MB
 Viewed:  787 Time(s)
NoizeToyz
PostPosted: Thu Oct 31, 2013 2:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
I swapped out Q7 and Q14 for new ones and happy to say it's all working nicely - thanks elmegil!
PostPosted: Thu Oct 31, 2013 6:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Glad to hear it Smile
Now if only I could get this Synthacon VCO working.... Wink
defog
PostPosted: Sat Dec 28, 2013 8:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Does the MPS absolutely need to be powered by +15v/-15V, or can I get away with using a +12v/-12v supply? I'd imagine there might be some resistor changes necessary. I only am asking because I have a 12v bipolar supply build from a previous synth that is currently unused. I could just get a larger transformer and swap out the regulators obviously but don't have a 15vAC supply on hand. Thanks.
The Phoenix Vertigo is my Electronic alias. Check out my songs on soundcloud : http://soundcloud.com/charles-stieg/
