2019/2020 BUILD PHOTOS
Page 2 of 6 [139 Posts]
PostPosted: Fri Mar 15, 2019 7:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
OMG I actually finished something! (well, for values of "finished" that mean "fully functional" not necessarily in any kind of ENCLOSURE)
 Filesize:  1.72 MB
 Viewed:  669 Time(s)
PostPosted: Fri Mar 15, 2019 8:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very nice looking! What does it do? Smile
PostPosted: Fri Mar 15, 2019 10:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's a 16n fader bank.
For *my* purposes, it just provides 16 CV sliders 0 - 5V. As you see it has a Teensy on it, it can also be used for USB or standard MIDI to generate CCs, and it also talks I2C to talk to Monome gear.
https://16n-faderbank.github.io/
vladosh
Audio files: 51
PostPosted: Sat Mar 16, 2019 9:39 am    Post subject: Reply with quote  Mark this post and the followings unread
added a few things in the new case ,had a vc echo pcb i made myself laying around almost populated ,then a mixer as in Serge schematic i just used TL071 and added an attenuated output ,added a NLC Neuron but i added a comparator from Yusynth schematic on neuron's output simply cause there was space on the panel and the stripboard ,left is the on off switch for the PSU ,ground connection and converters .
 Filesize:  1.08 MB
 Viewed:  617 Time(s)
cslammy
PostPosted: Thu Mar 21, 2019 8:04 am    Post subject: Reply with quote  Mark this post and the followings unread
finished an AD533 based balanced modulator. Based on EN preferred circuits design. Uses +/- 10V reference using LM329's. FPE front panel.
http://audiodiwhy.blogspot.com/2019/03/balanced-modulator-part-ii-nothing-like.html
http://audiodiwhy.blogspot.com/2019/02/electronotes-balanced-modulator-part-i.html
 Filesize:  2.99 MB
 Viewed:  397 Time(s)
JovianPyx
Audio files: 224
PostPosted: Thu Mar 21, 2019 9:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I love Marvin the Martian. I have a portable radio with a telescoping antenna and I put a Marvin car antenna ball on it.
Time flies like a banana.
corruptio optimi pessima
vladosh
Audio files: 51
PostPosted: Fri Mar 22, 2019 12:29 am    Post subject: Reply with quote  Mark this post and the followings unread
i made also the Dual Pulse Waveform Generator from Ian Fritz ,did also a small video showing the waveforms change ,you can see steady the action of the second pulse at the middle of the video
https://www.youtube.com/watch?v=fRjjLnH-Ros&t=59s
 Filesize:  932.36 KB
 Viewed:  572 Time(s)
MoonBase 69
PostPosted: Tue Apr 02, 2019 8:38 am    Post subject: Reply with quote  Mark this post and the followings unread
For a friends amplifier project and my key controller panel.
 Filesize:  363.39 KB
 Viewed:  561 Time(s)
 Filesize:  1.33 MB
 Viewed:  529 Time(s)
gabbagabi
PostPosted: Tue Apr 02, 2019 1:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
cool marshall is only going up to 11
PostPosted: Tue Apr 02, 2019 2:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks super nice!!! Thanks for sharing the information and the link for this project. When (and if) I ever get back to my Mega 256 based midi controller (also with sliders), I will look at this project more closely for possible ideas. Thanks for calling it to our attention. --Steve
elmegil wrote:
You can use the browser test page in Google Chrome to test the USB-MIDI output - useful for quick debugging.
Since the code the developers use relies on the WebMIDI API, several other browsers based on chrome should also work. I successfully tested some others, just don't ask me which ones (Opera, AVG, and possibly some others I might have tested with my own and others' web-based midi stuff).
2019-04-03: edited to reflect info from elmegil that he is a builder of the 16n, not the developer. Thanks for the clarification.
PostPosted: Tue Apr 02, 2019 5:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
The 16n is not mine Smile I'm just a builder on that project.
In other news I tried to get the panels for the 16n from Ponoko but I had to convert some colors to get it accepted; I used inkscape which is apparently a problem when dealing with vector art that came from somewhere else, the scale is ridiculously off (about 150% of the needed size, and when I look at it in inkscape to verify this, it is neither the size needed, nor the size that Ponoko lasered it at, so I have no clue what the deal is.
PostPosted: Fri Apr 05, 2019 6:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
This module is INSANELY fun. You would not believe how fun it is. I'm glad I didn't just go with the simplest controller I could find.
The socketed TO-92 is a jfet -- I didn't have a MPF102 on hand, so socketed a J112 in, instead. Seems to go okay.
This is what I have my touch strip mounted to. It looks stupid, but it works.
PostPosted: Fri Apr 05, 2019 6:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Panel stuff ready for the Appendage? Please? Smile
PostPosted: Sat Apr 06, 2019 5:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Phobos sent me this, and it's weirdly fun. I don't think I could get away with playing with it out loud for a long time, at least while other people are in the house. (ALAN, TURN IT DOWN!)
Went together very nicely. I mucked up with the pin headers (one is not flush with the board), but it works!
PostPosted: Sat Apr 13, 2019 10:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks to AlanP for pointing out the appendage panel PCB, and Bill for making it! Calibrated and ready for a maiden run....
 Filesize:  2.15 MB
 Viewed:  450 Time(s)
 Filesize:  993.73 KB
 Viewed:  425 Time(s)
vladosh
Audio files: 51
PostPosted: Thu Apr 18, 2019 10:46 am    Post subject: Reply with quote  Mark this post and the followings unread
6 Stage Programmer from Synapse Magazine by Serge with additional 1 or 2 octave switch on two rows .
 Filesize:  1.22 MB
 Viewed:  421 Time(s)
 Filesize:  1021.48 KB
 Viewed:  431 Time(s)
PostPosted: Thu Apr 18, 2019 1:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks great Vladko Very Happy
vladosh
Audio files: 51
PostPosted: Fri Apr 19, 2019 12:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks ,it's really fun to play bounce
kaputtpanzer
Audio files: 15
PostPosted: Thu May 30, 2019 12:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I built a little unipolar lfo to use with my (semi-)modular synths. it has a ramp/triangle and a pulse/square output and also attenuators to tweak the levels. It works like a charm! Cool
unipolar lfo
 Filesize:  2.02 MB
 Viewed:  482 Time(s)
neutron_drone_a_ms70cdr_lfo_01.mp3
unipolar lfo modulating vcf resonance and delay time
 Filename:  neutron_drone_a_ms70cdr_lfo_01.mp3
 Filesize:  9.51 MB
 Downloaded:  780 Time(s)
PostPosted: Sat Jun 08, 2019 12:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Six voice polysynth, all DIY Smile
The only problem so far is that my only MIDI controller is a full size digital piano that takes up loads of space.
PostPosted: Sat Jun 08, 2019 7:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks super nice!!! As for the MIDI controller, if (as a total novice when it comes to circuits and enclosures) I can breadboard midi controller stuff with my limited skills, from what I have seen, it should be child's play for someone with your DIY talents.
Steve
PostPosted: Sat Jun 08, 2019 12:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Find yourself a rock band keyboard. typically $20 - $30 .... very nice very portable MIDI controller.
PostPosted: Mon Jun 17, 2019 1:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I made a Tap Tempi Eurorack Module.
Its inputs are a Momentary Tap Switch and a Tempo input square(pulse) signal.
The (simultaneous) outputs are: A pulse each time the Tap switch is pressed or when a leading edge of the input signal is detected, two pulses, three pulses, four pulses and an output where you can chose from the other outputs by pressing a small switch next to the other 4 outputs which tempo you want.
Short demo HERE
 Filesize:  4.73 MB
 Viewed:  394 Time(s)
 Filesize:  4.73 MB
 Viewed:  382 Time(s)
 Filesize:  4.64 MB
 Viewed:  398 Time(s)
my synth
PostPosted: Mon Jun 17, 2019 1:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow, that is seriously nice.
PostPosted: Mon Jun 17, 2019 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
I actually finished something too Very Happy
can't say much about it (yet) but it creates some nice patterns.
(it doesn't create the sounds)
 Filesize:  252.24 KB
 Viewed:  365 Time(s)
 Filesize:  232.37 KB
 Viewed:  365 Time(s)
 Filesize:  253.78 KB
 Viewed:  355 Time(s)
