Posted: Fri Mar 15, 2019 8:29 pm Post subject:
Very nice looking! What does it do?  |
Posted: Fri Mar 15, 2019 10:01 pm Post subject:
It's a 16n fader bank.
For *my* purposes, it just provides 16 CV sliders 0 - 5V. As you see it has a Teensy on it, it can also be used for USB or standard MIDI to generate CCs, and it also talks I2C to talk to Monome gear.
https://16n-faderbank.github.io/ |
vladosh
Audio files: 51
cslammy
JovianPyx
Audio files: 224
Posted: Thu Mar 21, 2019 9:59 am Post subject:
I love Marvin the Martian. I have a portable radio with a telescoping antenna and I put a Marvin car antenna ball on it. _________________ FPGA, dsPIC and Fatman Synth Stuff
vladosh
Audio files: 51
MoonBase 69
Joined: Sep 16, 2014 Posts: 19 Location: Outpost 7, Florida
Posted: Tue Apr 02, 2019 8:38 am Post subject:
For a friends amplifier project and my key controller panel.
363.39 KB |
| Viewed: |
569 Time(s) |
1.33 MB |
| Viewed: |
537 Time(s) |
gabbagabi
Posted: Tue Apr 02, 2019 1:24 pm Post subject:
| cool marshall is only going up to 11 |
Joined: Aug 08, 2009 Posts: 1082 Location: Out scouting . . .
Posted: Tue Apr 02, 2019 2:52 pm Post subject:
| elmegil wrote: | It's a 16n fader bank.
Looks super nice!!! Thanks for sharing the information and the link for this project. When (and if) I ever get back to my Mega 256 based midi controller (also with sliders), I will look at this project more closely for possible ideas. Thanks for calling it to our attention. --Steve
| elmegil wrote: | | You can use the browser test page in Google Chrome to test the USB-MIDI output - useful for quick debugging. |
Since the code the developers use relies on the WebMIDI API, several other browsers based on chrome should also work. I successfully tested some others, just don't ask me which ones (Opera, AVG, and possibly some others I might have tested with my own and others' web-based midi stuff).
2019-04-03: edited to reflect info from elmegil that he is a builder of the 16n, not the developer. Thanks for the clarification. Last edited by MusicMan11712 on Wed Apr 03, 2019 8:05 am; edited 1 time in total |
Posted: Tue Apr 02, 2019 5:08 pm Post subject:
The 16n is not mine I'm just a builder on that project.
In other news I tried to get the panels for the 16n from Ponoko but I had to convert some colors to get it accepted; I used inkscape which is apparently a problem when dealing with vector art that came from somewhere else, the scale is ridiculously off (about 150% of the needed size, and when I look at it in inkscape to verify this, it is neither the size needed, nor the size that Ponoko lasered it at, so I have no clue what the deal is. |
Posted: Fri Apr 05, 2019 6:10 pm Post subject:
This module is INSANELY fun. You would not believe how fun it is. I'm glad I didn't just go with the simplest controller I could find.
The socketed TO-92 is a jfet -- I didn't have a MPF102 on hand, so socketed a J112 in, instead. Seems to go okay.
This is what I have my touch strip mounted to. It looks stupid, but it works. |
Posted: Fri Apr 05, 2019 6:51 pm Post subject:
Panel stuff ready for the Appendage? Please?  |
Posted: Sat Apr 06, 2019 5:42 pm Post subject:
Phobos sent me this, and it's weirdly fun. I don't think I could get away with playing with it out loud for a long time, at least while other people are in the house. (ALAN, TURN IT DOWN!)
Went together very nicely. I mucked up with the pin headers (one is not flush with the board), but it works! |
Posted: Sat Apr 13, 2019 10:11 am Post subject:
Thanks to AlanP for pointing out the appendage panel PCB, and Bill for making it! Calibrated and ready for a maiden run....
2.15 MB |
| Viewed: |
456 Time(s) |
993.73 KB |
| Viewed: |
438 Time(s) |
vladosh
Audio files: 51
Posted: Thu Apr 18, 2019 10:46 am Post subject:
6 Stage Programmer from Synapse Magazine by Serge with additional 1 or 2 octave switch on two rows .
1.22 MB |
| Viewed: |
435 Time(s) |
1021.48 KB |
| Viewed: |
438 Time(s) |
_________________ http://synthacks.blogspot.com/ шематикс |
vladosh
Audio files: 51
kaputtpanzer
Audio files: 15
Posted: Thu May 30, 2019 12:03 pm Post subject:
I built a little unipolar lfo to use with my (semi-)modular synths. it has a ramp/triangle and a pulse/square output and also attenuators to tweak the levels. It works like a charm!
2.02 MB |
| Viewed: |
491 Time(s) |
| unipolar lfo modulating vcf resonance and delay time |
 Download (listen) |
| Filename: |
neutron_drone_a_ms70cdr_lfo_01.mp3 |
9.51 MB |
| Downloaded: |
799 Time(s) |
Posted: Sat Jun 08, 2019 12:39 am Post subject:
Six voice polysynth, all DIY
The only problem so far is that my only MIDI controller is a full size digital piano that takes up loads of space. |
Posted: Sat Jun 08, 2019 7:25 am Post subject:
| AlanP wrote: | Six voice polysynth, all DIY
Looks super nice!!! As for the MIDI controller, if (as a total novice when it comes to circuits and enclosures) I can breadboard midi controller stuff with my limited skills, from what I have seen, it should be child's play for someone with your DIY talents.
Steve |
Posted: Sat Jun 08, 2019 12:18 pm Post subject:
| AlanP wrote: | | The only problem so far is that my only MIDI controller is a full size digital piano that takes up loads of space. |
Find yourself a rock band keyboard. typically $20 - $30 .... very nice very portable MIDI controller. |
Posted: Mon Jun 17, 2019 1:04 am Post subject:
I made a Tap Tempi Eurorack Module.
Its inputs are a Momentary Tap Switch and a Tempo input square(pulse) signal.
The (simultaneous) outputs are: A pulse each time the Tap switch is pressed or when a leading edge of the input signal is detected, two pulses, three pulses, four pulses and an output where you can chose from the other outputs by pressing a small switch next to the other 4 outputs which tempo you want.
Short demo HERE
4.73 MB |
| Viewed: |
401 Time(s) |
4.73 MB |
| Viewed: |
394 Time(s) |
4.64 MB |
| Viewed: |
409 Time(s) |
_________________ my synth |
Posted: Mon Jun 17, 2019 1:20 am Post subject:
| Wow, that is seriously nice. |
Posted: Mon Jun 17, 2019 2:02 pm Post subject:
I actually finished something too
can't say much about it (yet) but it creates some nice patterns.
(it doesn't create the sounds)
252.24 KB |
| Viewed: |
373 Time(s) |
232.37 KB |
| Viewed: |
376 Time(s) |
253.78 KB |
| Viewed: |
362 Time(s) |
