Posted: Tue Sep 20, 2011 7:34 am Post subject:
Appendage Ribbon Controller Build Documentation Subject description: a convenient place for all Appendage build documentation and build notices |
Here is where you can get ALL the latest build documentation for your Appendage Ribbon Controller. It includes the latest build document and BOM. It is also a place where I will be posting any changes or modifications to the build documents. the latest of any drawings will, from now on, be kept here.
NOTE: THERE IS CHANGE TO ALL PCB REVISION "H" OWNERS THAT ADDS 4 PROTECTION DIODES. IF ANYONE HAS BEEN EXPERIENCING ANY U21, CD4053, FAILURES, THIS WILL FIX THAT PROBLEM. THIS MODIFICATION IS EXPLAINED BELOW IN THE NEXT POST
THE LATEST ROUND OF APPENDAGE PC BOARDS ON ORDER, REVISION "J" WILL ALREADY HAVE THESE DIODES INCORPORATED. THESE REV "J" BOARDS ARE SHIPPING TO ALL NEW CUSTOMERS. PLEASE NOTE THAT THE CURRENT BUILD DOCUMENT FOR REV H PCB'S CAN BE USED BUT THE NEW REV J BOM ADDS 4 BAT85 DIODES. SEE BELOW FOR DETAILS OF PLACEMENT
LINKS ------------- LINKS --------------- LINKS ---------------- LINKS -----------
THIS TOPIC HAS BEEN LOCKED SO PLEASE POST YOUR CONCERNS AND BUILD EXPERIENCES HERE:
http://electro-music.com/forum/topic-41078.html
VIDEOS OF THE APPENDAGE IN ACTION:
http://www.youtube.com/user/ScottStites
APPENDAGE ORIGINAL THREAD
http://electro-music.com/forum/topic-28138.html&postorder=asc&highlight=appendage
SOFTPOT SPECIFICATION DATA SHEET:
http://www.mouser.com/catalog/specsheets/SOFTPOTDATASHEETREV%20F2.pdf
Description: |
BILL OF MATERIALS FOR REV "J" PCB'S |
 Download (listen) |
Filename: |
BOM_1.07J.pdf |
Filesize: |
51.93 KB |
Downloaded: |
1704 Time(s) |
Description: |
Lean all about the Appendage Ribbon Controller. This excellent document is a MUST READ if your at all interested in this controller. |
 Download (listen) |
Filename: |
Appendage_Exposed.pdf |
Filesize: |
398.71 KB |
Downloaded: |
1845 Time(s) |
Description: |
BUILD & CALIBRATION DOCUMENT FOR REV "H" PCB'S |
 Download (listen) |
Filename: |
Appendage_Build_Procedure_Issue_1_2_1_REV H PCB.pdf |
Filesize: |
12.18 MB |
Downloaded: |
1709 Time(s) |
Description: |
Parts Pick (Check) List for Rev. J PCB NOTE: Rev H Add (4) more BAT85 diodes D21-24 |
 Download (listen) |
Filename: |
PICKLIST_BOM_1.07J.doc |
Filesize: |
102 KB |
Downloaded: |
845 Time(s) |
Description: |
BUILD & CALIBRATION DOCUMENT FOR REV "J" PCB'S |
 Download (listen) |
Filename: |
Appendage_Build_Procedure_Issue_1_3_REV J PCB.pdf |
Filesize: |
8.39 MB |
Downloaded: |
712 Time(s) |
Last edited by State Machine on Sun Jul 01, 2018 8:17 am; edited 7 times in total |
Posted: Wed Sep 21, 2011 6:50 am Post subject:
PLACEMENT OF 4 NEW DIODES ON REV "J" PC BOARDS SHOWN BELOW.
Click on image to enlarge.
Thanks
Bill
Description: |
Filesize: |
73.04 KB |
Viewed: |
1327 Time(s) |
Description: |
Filesize: |
10.74 KB |
Viewed: |
1144 Time(s) |
