Posted: Tue Mar 29, 2005 11:25 am Post subject:
| mosc wrote: | | most musicians aren't interested in developing and debugging code. |
This is true, but a dangerous train of thought since most musicians aren´t interested in synthesis either and certainly not in modular synthesis!
Even within modular synthesis there are schools of thought. If I would buy a hardware modular I´d never buy a Moog, for example. There is some retro-charm to the LP filter but aside from that Moog modulars simply don´t offer modules that hold apeal to me. I´m much more interested in systems like Serge´s or even the more experimental sides of the Doupfer. I feel using a modular to do a job normal synths could too (such as lowpass filtering oscilators or fm modulation) is a waste. This means that referencing to hardware modulars is a risky affair; there´s a lot of differenece between for example your Moog or the Serge I was using at the CEM with the added logic panels.
Your style of reasoning that there are already many programing languages out there that can be used with the G2 over midi leads to some interesting conclusions. You see; there are also many other static filter banks out there already too that can be used with the G2 over audio. Jack cables are a great tool too, you see :¬).
This will end up at the point where the only thing Clavia can do is add stuff nobody has ever added anywhere. I can only loudly aplaud such ideas. This is, however, directly at odd with your sugestion that we should add what most musicians want, I would counter there that we already have more then enough of that; we have a equaltempered keyboard (and you are stuck with that if you want any hardware interface at all), we have ready made polyphony, we have stack upon stack of oscilators and filters and so on and so forth, I think "most musicians" have what they need and should now be good for a while while we add some interesting stuff instead. _________________ Kassen |
jamos
Joined: Jun 01, 2004 Posts: 514 Location: Eugene, Oregon, USA
G2 patch files: 41
Posted: Tue Mar 29, 2005 11:42 am Post subject:
Mosc's reasoning is valid and dead-nuts-on.
The G2 is a modular synthesizer, not a general-pupose sound-modeling system.
In any instrument design effort, there needs to be a set of goals and constraints. Otherwise, the instrumen thas no focus, is hard to understand and use, etc. This discussion doesn't recognize that. The G2 engineers have done, IMO, a fantastic job of defining what the instrument should be, and implementing something that meets that definition.
To extend mosc's reasoning, I would say that most modular synthesists aren't interested in writing and debugging code. I know that I'm not (and I'm a software developer.)
Another thing that's not being considered, is the incredible amount of effort that would be necessary on Clavia's part to open up this system. That would probably require the full-time efforts of at least one engineer. I'd rather see them working on new modules, improving efficiency, etc. |
Posted: Tue Mar 29, 2005 11:43 am Post subject:
| Acidfever wrote: |
I will explain. As somebody in a earlier post mentioned his opinion was that the only advantage Clavia has over sollutions like Csound is the interface. And it is here that i have to disagree.
I have been working with reaktor for quite some time before i bought my G2 Engine. The reason i bought it is because i liked the sound, but also the fact that it was less hard to build own patches. With reaktor i spend hours or even days on making a patch and not making music. With the G2 i spend some time making a patch but not nearly as long as i would on Reaktor. This combined with the stable and trustworthy dedicated hardware environment is the real strenght of the Clavia modulars. If you combine this with the interface the G2 keyboard users get this is even better.
I said that, yes. More speciffically I think the interface is great as long as nothing resembling classes enters the equation because then the graphical paradigm breaks down, at least if we stick to 2d.
I never used reactor but I believe it has a graphical interface too, I also believe it is not known for it´s rich sound quality. In fact it´s not at all clear to me how you can disagree with my comparison between the G2 and Csound or comparable systems by comparing the G2 to reactor.
I should also clarify that me comparing the two was based on the assumtion that Csound would run on a computer that had a soundcard with better DAC´s then the G2 does. Conceivably soundcards exist that don´t fill these shoes, I´m unaware of any, but we can´t rule out the posibility. Quite possibly you ran Reactor on such a soundcard and now prefer the G2´s sound.
What exactly is it that you disagree with? _________________ Kassen |
cebec
G2 patch files: 31
Posted: Tue Mar 29, 2005 11:52 am Post subject:
Sorry for the OT rant, but:
Reaktor's sound quality is superb, in my opinion. Especially if you throw concern for 'analog emulation' etc. out the window. I don't know who's been telling you Reaktor doesn't sound good and that the Nord line is good for trance, only, but I'm inclined to disagree strongly. I don't think anyone here's really making trance and I don't think any of the artists I listen to who use the G2 or NM Classic, etc., make trance or anything closely resembling it.
Furthermore, unless you are running the G2 or Reaktor directly to a pair of active monitors, your soundcard's DACs, your mixer, amps, etc., could be coloring the sound noticeably. I know you already know this, though...
Also, there are at least a half a dozen soundcards out there in the sub-$1000 range that have may have either inferior or superior DAC/implementations to the G2. I've heard/owned some and so have many of my friends. Currently, the EMU 1820M I own is one of the best I've used/heard under $1000. |
Acidfever
Posted: Tue Mar 29, 2005 12:10 pm Post subject:
| Kassen wrote: |
I said that, yes. More specifically I think the interface is great as long as nothing resembling classes enters the equation because then the graphical paradigm breaks down, at least if we stick to 2d.
What exactly is it that you disagree with? |
I disagreed with the statement you made about the only advantage for the G2 over comparable products being the interface. The G2 is also a dedicated platform that is reliable and stable (as i said before). This is an important isue for me as a musiscian.
I compared the G2 to reaktor because this is a product i know well and is also a modular synthesis product. Csound goes a lot further than that, i realise that but still.
I have used Reaktor with an Echoaudio Gina24. I would think this is a card with good enough DA conversion to rule out any quality loss in that area. And sure, i have heard great things coming from reaktor, but somehow the G2 has the edge on soundquality. Maybe because Native Instruments still has to make comprimises between audio quality and cpu ussage.
Besides this i agree with the other comment someone made. I would rather have Clavia optimise existing and develop new modules so we can use them. I noticed there are quite a few modules from the old modular still not available in the G2. I think this will need to change.
But then again, i cannot decide what Clavia does with their available hours. |
Posted: Tue Mar 29, 2005 12:17 pm Post subject:
Well, perhaps Reactor is a matter of taste, I mainly read it being compared to Tassman and there it apeared to be on the losing side, it was particularly implied that insufficient attention had been paid to matters related to aliassing. I never used it myself.
About the Nord line being for trance; I didn´t say that, I like the sound of the NM and the Lead1, I just dislike what comes afterwards. I never realised the difference and was always realy confused at the trance comments because I only know the NM and those people were talking about the Lead2 and the Lead3. Now that I have G2 here I realise what happened. I then spoke to some people with some insider knowledge and it turned out that indeed the DAC´s were changed after the NM and the Lead1.
This has nothing to do with people telling me things or with connecting directly to monitors, just with listening carefully. The huge mistake that was made in the design of the DAC´s from the G2, aside from the ringing that is still partially plaguing the anti-alias filter, is that for reasons unkown to me somebody thought it would be wise to make these DAC´s as linear as possible instead of as pleasant sounding as possible. Since "real" soundsources never sound linear due to interference by the air and so on this throws some psychacoustical clues in your hearing which I believe to be the largest objectively quanifyable side of this problem. There are other elements but those minly (imho) involve the evolution of our culturally shared aesthetics since the 60´s and soo are more subjective.
Either way, these things are either accidentally or intentianally shared by the type of mastering big trance productions receive in order to get that typical sense of "present space".
This is not just me going off on some tangent, I share this idea speciffically where the G2 is concerned with Rob and where overall changing aesthetics are concerned with one of my continent´s most senior mastering engineers.
Admittedly I by myself go a bit further and provocative stances like "Csound on a SoundBlaster16 OEM sounds better then a G2" are purely my own. Once the euphoria over current sample rates at the expense of actually listening has passed over I expect many who now look so surprised will agree. _________________ Kassen |
Acidfever
Posted: Tue Mar 29, 2005 12:43 pm Post subject:
So Kassen, basicly you are saying that the G2 is far inferior to other products? Do you own a G2 by the way?
Since you are so negative about it, i don't actually see why you even want to use it.
It's very tempting to constantly compare products with eachother i agree, but there is a time where you would better start using what you have instead of constantly being bothered by the differences between the different products on the market.
I am not even nearly an audioguru and i never noticed any problem with the G2's DAC's yet (i have only purchased it recently). this is why i cannot comment on this topic. You are almost making me feel i spend my money on a bad product. |
Posted: Tue Mar 29, 2005 1:08 pm Post subject:
| Acidfever wrote: | So Kassen, basicly you are saying that the G2 is far inferior to other products? Do you own a G2 by the way?
No, not at all, I feel the G2 is a marvelous thing for many purposes, I just feel some elements of the G2 are very wrong and below the standard of quality of the rest. For a long time I felt it was completely unsuitable for musical aplications because of it´s sound and only came to it´s own in prototyping, testing and eduction but lately I´ve found some tricks and strategies that I realy like. In fact this morning I recorded a piece that uses a lot of G2 in prominent places, particularly where digitally lo-fi sounds are concerned.
I have a engine here on a loan, it´s not my own. I still haven´t decided wether I should get my own and if so what model.
As I see it the G2 gets some stuff very right; I´ve always felt the interface was superior to comparable products, the module selection of the G2 is much more suitable to my current interests then the NM´s is and the Keyboard´s knobs and lcd´s are a masterstroke I deeply admire. I realy like the extra inputs compared to the NM.
I also think some things are very wrong; for one thing the DAC´s and I think the size and shape of the Keyboard are all wrong for touring. The keyboard is also way too light for my tastes which run far more in the piano direction. I also have a problem with it being unable to change patches while playing.
This makes me torn inbetween love and hate for it since both the positve and the negative sides weigh rather heavily for me.
You should judge for yourself how important any of these elements are for you personally. _________________ Kassen |
Acidfever
Posted: Tue Mar 29, 2005 1:20 pm Post subject:
| Kassen wrote: |
You should judge for yourself how important any of these elements are for you personally. |
Yea, i actually bought the G2 for processing audio and making digitalish sounds. For VA stuff i have different synths.
And for this i think the G2 is great indeed. I also needed a sollution i could carry with me without having to get an expensive laptop or carry a huge computer with me. I can just set this box up with patches and take it wit me as a filterbox, audioprocessing unit and sound source.
I haven't found any software sollution suitable enough for this purpose. I did some live stuff with reaktor and that worked out pretty well, but still i've had some troubles with it.
The re-calculation on loading patches is annoying i agree, but you learn to work with it and if you have another soundsource playing you can actually get away with loading a new patch without anyone noticing it.
I do think that 8 variations is just not enough. 16 or even 32 would be much better so you can save a few of those magic settings you find when playing around with your creations. |
zynthetix
Audio files: 10
G2 patch files: 13
Posted: Tue Mar 29, 2005 8:44 pm Post subject:
Reaktor 4 and the keyboard G2 are the modern synths I have. They both output from the same 96k m-audio firewire card and go to the same speakers. I don't really hear a difference when making a stagnant sine wave in each of them. If I compared the sound of the two, it would be like me comparing guitar tubes. I can't really hear the difference in either of these contexts. (I am not implying that there is no difference. It just does not strike me.)
I think the really important part is how these tools work. Yes you can patch the same thing in reaktor, the G2, even CSound. what it really comes down to is which interface you like. Personally, I find code, softsynths, and hardware synths each have an advantages. It is my belief that if each of these advantages and respective interfaces are used in a complimentary manner, the resulting working experience is more enjoyable than what would result from an "all in one" device.
Time will probably prove me wrong though. |
Posted: Tue Mar 29, 2005 8:49 pm Post subject:
I find Live does a nice job as a sound source, filter box and audioprocessing work horse for me, I´d just like something else next to it, preferably something that wouldn´t go silent while loading so it could double as a customisable mixer. Right now I use a NM and a couple of analogue effects with it but those take up too much weight and space compared to how usefull they are.
The G2 won´t keep playing non-stop (like the NM) but the G2 brings a nice interface to the party.... The main alternative I see is a second latop dedicatedly runnning supercolider (that would probably be on Linux). This is more expensive (asuming a RME card, otherwise it´s possibly cheaper), but not by *that* much. A second laptop could also still be "check in" while a G2 is too large for that meaning it needs a flightcase or hard suitcase, meaning weight, etc.
Perhaps I should start using grooveboxes to make "V.A." sounds like everybody else and be done with it.
:¬/ _________________ Kassen |
Posted: Tue Mar 29, 2005 9:16 pm Post subject:
| zynthetix wrote: |
:¬) _________________ Kassen |
