Posted: Mon Jan 29, 2007 1:25 am Post subject:
bugbrand wrote: |
Oh damn the images are amazing.
& you can hear the sounds too - all sorts of harmonics.
Plus modulation.
I'm sure there's a lot of tweaks possible to mess with it.
I'm sorry for the extra parts- I must not have scanned that bit (It's just an on-board PSU, but you can always omit part of it. I think Oscillographics needs a +5v rail?), but anyway Tom, this is great! Thanks very, very much for posting this  |
bugbrand
Posted: Tue Jan 30, 2007 2:39 am Post subject:
I've put +/-5v regulators in now (kludge) and taken out all those extra bits and its working good! (still not used the Z though).
Nice to feed the X channel output into the Y mod input and vice versa for feedback goodness oh yes.
I could watch these all day but really have a lot of other work to do... _________________ http://www.bugbrand.co.uk
Joined: Apr 03, 2004 Posts: 24468 Location: The Netherlands, Enschede
Audio files: 297
Posted: Tue Jan 30, 2007 9:53 am Post subject:
bugbrand wrote: | II could watch these all day but really have a lot of other work to do... |
Is easy, just take a beamer and project onto the work to do ... sorry
Nice video you posted ! _________________ Jan
Photon
Posted: Fri May 11, 2007 12:12 pm Post subject:
Photon wrote: | I found this recently and thought it made sense to add it here. Another oscilliscope graphic generator project:
yes you AND all the rest!!
You have just posted that project that has already been posted here many times already- even in this thread I think?- err yes- just a few posts back!
Elektor Oscillographics has never been posted, and Elektor gave electro-music.com exclusive rights to post the schematics here.
So there!
 _________________ ACHTUNG!
doctorvague
Posted: Fri May 11, 2007 12:30 pm Post subject:
Great video!!
Thanks for the project. You're right that is a nice PCB layout.
I've got a cheap digital scope which is cool to save waveforms and stuff but seems like an analog scope is the right tool for the job with this, yes-no?
Phil |
Posted: Fri May 11, 2007 12:35 pm Post subject:
both should work fine  _________________ ACHTUNG!
Photon
Posted: Fri May 11, 2007 12:36 pm Post subject:
sorry! I thought I was being helpful. Its been a while since I had read this post...I guess I should have looked closer.
oh well.
p. |
Posted: Fri May 11, 2007 12:40 pm Post subject:
no problem We're only human after all- as the old cliche goes
Anyway, you are excused for having Linus as your avatar (it is Linus isn't it? I used to love Charlie Brown, until the Simpsons came along anyway ) _________________ ACHTUNG!
Photon
salamanderanagram
Posted: Thu Dec 13, 2007 3:20 pm Post subject:
none of the links in this thread work!!
i would appreciate it if someone could repost them...
thanks! |
TheAncientOne
Joined: Dec 26, 2006 Posts: 144 Location: United Kingdom
Posted: Thu Dec 13, 2007 7:34 pm Post subject:
Reposted as requested.
Description: |
Filesize: |
94.99 KB |
Viewed: |
475 Time(s) |
Description: |
Filesize: |
25.67 KB |
Viewed: |
487 Time(s) |
Description: |
Filesize: |
226.69 KB |
Viewed: |
676 Time(s) |
Description: |
Filesize: |
110.82 KB |
Viewed: |
662 Time(s) |
Description: |
Filesize: |
218.97 KB |
Viewed: |
525 Time(s) |
_________________ Mike |
TheAncientOne
Posted: Sun Dec 16, 2007 8:58 am Post subject:
Quote: | and the last bit reposted.
I can add that the design works well, and that I subsituted a 79L05 for the 741-plus-transistor negative regulator. I think Elektor only used this because 79L05's weren't made then, or were at least very rare. |
Thanks for the repost. I am wondering, is there a commercial PCB for this neat little gadget ???? I know it's been around a while.
Pardon me for not just doing some searching on my own as I thought maybe you would know right off and ave a bit of time.
Thanks,
Bill |
TheAncientOne
Posted: Sun Dec 16, 2007 12:40 pm Post subject:
State Machine wrote: |
I've never seen one, I just built mine on perfboard. I could tidy it up over the holiday, try some more modern op-amps, and post that, if it would help. I'm not posting the current perfboard layout - it was jack legged together straight from the diagram, in about an hour, and looks like it.... I bought Lochmaster a couple of months after I made it, after seeing some of Uncle K's layouts, so I could try that and get one worth boxing up.
By the way, if you are into 'scope graphics, here is a "must have":
http://www.dutchtronix.com/ScopeClock.htm. _________________ Mike |
Posted: Sun Dec 16, 2007 12:58 pm Post subject:
Hey Prof- thanks for the repost
I completely overlooked the fact that this project got lost in that server crash too
AND even more thanks for that 'must have' too! _________________ ACHTUNG!
Posted: Mon Dec 17, 2007 10:18 am Post subject:
Quote: | I've never seen one, I just built mine on perfboard. I could tidy it up over the holiday, try some more modern op-amps, and post that, if it would help. I'm not posting the current perfboard layout - it was jack legged together straight from the diagram, in about an hour, and looks like it.... I bought Lochmaster a couple of months after I made it, after seeing some of Uncle K's layouts, so I could try that and get one worth boxing up. |
Thanks for this reply. I did not think there was any PCB but it's a fairly small circuit so perfboarding it will not be a problem.
Lochmaster? Not sure I know what that is
Quote: | By the way, if you are into 'scope graphics, here is a "must have": |
Now, talk about snazzy vector graphics !!! I had designed a character generator about 20 years ago that did something similar but back then, my board had about 25 IC's !!! I really like this clock ! Some fancy coding going on in there also !
Thanks,
Bill |
Posted: Mon Dec 17, 2007 10:22 am Post subject:
Bill, Lochmaster is the CAD stripboard software that Unkle K did the original Klee and Soundlab layouts in. _________________ ACHTUNG!
Posted: Mon Dec 17, 2007 10:23 am Post subject:
State Machine wrote: | I really like this clock ! |
yeah me too!  _________________ ACHTUNG!
bugbrand
Posted: Fri Sep 16, 2011 3:44 am Post subject:
Just to drag this up from the void... As I finally got around to making up a test for another of these projects - the 'Scope Art / Oscilloscope Graphic Artist' from Practical Electronics Nov.1975
Here's a rough first demo play with drone-tones generated by the circuit
http://www.youtube.com/watch?v=Ypn9JJXSl7w
There's certainly scope for further development on it - I need to try out different sync'ing options, add fine-tune controls and perhaps skew (as the oscs are very much like the 'standard' LFO circuits) _________________ http://www.bugbrand.co.uk
TheAncientOne
Posted: Fri Sep 16, 2011 5:29 am Post subject:
Very nice work Tom!
I know I posted this elsewhere, but if you go to http://www.mitchwaite.com/ and follow the 'personal' link, his book 'Projects in sight, sound and sensation' is available for download.
IF you can afford a bunch of 8038's, there is a monster oscilloscope graphics machine deign there, and lots more, including a Kirlian Camera unit.
Mitchell Waite was founder of The Waite Group, and one of the great writers on computing. The story about Steve Jobs turning up in a VW camper van, to ask him to do the Apple ][ book is a classic. Also on the site. _________________ Mike |
bugbrand
Posted: Fri Sep 16, 2011 5:41 am Post subject:
Ok - great - thanks for the info & link.
Yes, I've looked through the Projects for Sight & Sound PDF before and actually have done some experiments with just a part of the circuitry - the phase shifters and ring-mods (using AD633).
I feel silly for not having realised the two projects were by the same guy.
Nice! _________________ http://www.bugbrand.co.uk
macumbista
Posted: Sun Sep 18, 2011 2:18 pm Post subject:
Just stumbled across this on YouTube. Thanks for sharing!
The Holy Grail I'm looking for is some kind of analog vector converter that could be fed images or video signals. Something like the Rutt-Etra machine.
http://www.youtube.com/watch?v=EZQiHuTbnes
This could take years to pin down!!!!!
EDIT: maybe this gets close. Ruby script converts images into o-scope ready audio files:
http://www.bigbucketblog.com/2008/02/16/oscillofy/ _________________ Esoteric drones and nonlinear distortion
macumbista.net |
bugbrand
Posted: Mon Sep 19, 2011 1:26 am Post subject:
Heya Derek,
I've been occasionally looking around such areas - at the moment I've got the beginnings of a vid-synth system from LZX in the workshop (but it is going off on tour with someone very soon unfortunately...)
A very interesting area is vector re-scanning and that's the initial purpose of the system I've been helping to put together. I've had some fun testing, but unfortunately the documentary pics/vids I've attempted have all looked crap.
This is how it is meant to look (if filmed well)::
http://www.youtube.com/watch?v=DmUSb1ptCNg
http://www.youtube.com/watch?v=-uA75dw9BJQ
[by the way - back over in Berlin early next month - hopefully we can hook up this time as I won't be going off to any spacey festivals!] _________________ http://www.bugbrand.co.uk
macumbista
Posted: Mon Sep 19, 2011 1:45 am Post subject:
Yeah, that's the good hood shit I'm after. Those LZX look nice, but in no way cheap! What's the minimum modules you can use to generate that? Can audio oscillators take place of the video ones they have in their line?
bugbrand wrote: | by the way - back over in Berlin early next month - hopefully we can hook up this time as I won't be going off to any spacey festivals! |
Yeah, except I'm in Denmark until the end of the year. Have fun in Das Kapital! _________________ Esoteric drones and nonlinear distortion
macumbista.net |
