Electro-Music Klee Sequencer Build and Applications Thread
Page 7 of 54 [1348 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7, 8, 9, ..., 52, 53, 54 Next
Scott Stites
Audio files: 96
PostPosted: Fri Aug 10, 2007 10:33 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll put you on the list, Fred.
Scott
My Site
Scott Stites
Audio files: 96
PostPosted: Fri Aug 10, 2007 10:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I've told Andy privately that I'd *love* to have sliders, but I just don't have the beans to make a panel that would take sliders. I think they'd be perfect for the job (I'd prefer sliders on any sequencer, I think).
Be that as it may, I've started circling my own proto-panel. I'm using the usual little Alpha's from Mouser, because I've got a ton of my stock el-cheapo, tiny knobs for them already.
I'm thinking of a 5" tall rack panel, with the pots on .909" centers, or something like that. A little wider than my module pot dimensions. Expect my panel to be a bland, utilitarian sort of thing (as usual).
The main controls (those in groups of sixteen) will occupy four horizontal rows. Top to bottom on that section: Pattern LED's, Pattern Switches, Programming Pots, Gate Bus Switches. The rest of the controls/connectors/indicators still have to be sorted.
Scott
My Site
Funky40
G2 patch files: 5
PostPosted: Fri Aug 10, 2007 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
mosc wrote:
Scott Stites wrote:
See? The Klee plays nice with the other instruments. Very Happy
http://electro-music.com/forum/download.php?id=7597
This is fine music; not just a fine demo. thumb up
I'm just listen to this while surfing the Klee Thread.
Great music !
thanks Scott
most music crossing my way is not harmonious in itself in my opinion.
so it's allways a pleasure when a good piece is coming to my ears.
PostPosted: Fri Aug 10, 2007 5:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
The plan sounds good Scott. I am planning a 5U 19" style rack which ends up slightly taller than yours weighing in at 8.75". I too plan the controls that are in groups of 16 in four major rows from top to bottom in that very same order. Seems most logical. The stage LED's will be RED while the BUS LED's shall be YELLOW. The rest will be green and blue.
I have given the groupings some thought and here is what I have planned:
Group 1 - GATE BUS
Consists of all BUS outputs, Activity LED's, TRIGGER outputs, and MERGE switches.
Group 2 - CV OUTPUTS
CV Range Select Rotary switch, GLIDE pots, A, B and A+B CV outputs
Group 3 - MODE CONTROL
8x2, 16x1 select toggle switch, PATTERN/RANDOM select switch, INVERT "B" DATA ON/OFF switch
Group 4 - SEQUENCER CONTROL
CLOCK IN, MANUAL STEP, CLOCK ENABLE, CLOCK ACTIVITY LED
EXTERNAL LOAD, BUS 1 LOAD input jacks, MANUAL LOAD pushbutton
RANDOM IN, RANDOM LEVEL, RANDOM THRESHOLD, ACTIVITY LED
Group 5 - Power rocker switch and blue LED indicator
The finish shall be blue anodized, 2.5 MM thickness with in-filled engravings of various colors to delineate each control grouping. I will be working like a mad man to get it all laid out so I can send it of to Schaeffer for manufacture. While that is in manufacture, I will construct the two prototype boards and wire harnesses.
The rear of the panel will have the two circuit boards (analog and digital) mounted onto it with hinged standoffs on one side of each so they can each swing out for repairs and troubleshooting. Both boards shall be completely connectorized. A small open frame split 15 volt switching power supply shall be used for power. The power supply will also swing out on hinged standoffs. Not much power is needed as all the LEDS are low current and the rest of the circuits are all low power CMOS type stuff.
So anyways, that's my big plan .......... Shocked Shocked
Bill
fluxmonkey
PostPosted: Fri Aug 10, 2007 7:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
cutting slots for slide pots by hand is a royal pain, but if you're gonna shell out for a shaeffer panel, the extra cost for slotted holes is not that much more (tho shaeffer is never cheap)...
b
PostPosted: Sat Aug 11, 2007 7:33 am    Post subject: Reply with quote  Mark this post and the followings unread
sorry for that cross post. below is the panel sketch i made once upon a time for the original klee thread. i thought it could be helpful for all who chimed in lately.
not just the way i would do it today, but almost.
 Filesize:  556.64 KB
 Viewed:  11207 Time(s)
Scott Stites
Audio files: 96
PostPosted: Sat Aug 11, 2007 4:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tanks Funky40!
I've always thought Fonik's panel design comes the closest to how I've always envisioned the Klee.
Don't y'all forget the Klee boards will allow you to have either a single rotary switch to set max voltage range (intervals) for the pots, or you can have the rotary, with one position of the rotary pointing to a pot that allows you to set your own custom range. Just an option, there, in case you didn't have enough controls to juggle Laughing
Oh, he laughs as he wrestles with his own panel layout.....
Scott
My Site
EdisonRex
Audio files: 172
PostPosted: Sat Aug 11, 2007 4:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm. Maybe 4 high is going to be necessary. I will need to get my fingers into the spaces between the controls somehow.
Garret: It's so retro.
Scott Stites
Audio files: 96
PostPosted: Sat Aug 11, 2007 4:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, yes, and the PCBs provide three optional outputs - A, A+B, and B that are tapped before the glide controls (like Ray does with his sequencer, IIRC).
Time to duck?
My Site
EdisonRex
Audio files: 172
PostPosted: Sat Aug 11, 2007 4:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, definitely 4U high then. Cool
Scott Stites
Audio files: 96
Yeah, I'm going with five inches tall. Probably the four rows of pattern switches, LEDs, gate bus switches and pots will be in the upper portion and the rest will be arranged in the lower portion.
Scott
My Site
goodrevdoc
PostPosted: Sat Aug 11, 2007 4:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Have you guys seen these for slide pots:
Alpha LED Slide Pots
Saves a lot of panel spce, IMHO. Great now I have to totally re-think my panel... Razz
-justin
Scott Stites
Audio files: 96
PostPosted: Sat Aug 11, 2007 4:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Way to go, Krunkus Laughing
My Site
Scott Stites
Audio files: 96
PostPosted: Sat Aug 11, 2007 4:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm....don't forget the electro-music Klee has the Invert B switch, which the Model 2 didn't have. Throw your beer cans at Jan, that was his doing Laughing
My Site
Scott Stites
Audio files: 96
PostPosted: Sat Aug 11, 2007 4:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
The Klee does have one superfluous third nipple that could be dropped if space becomes a problem. The Clock LED and the Master Gate Bus LED will essentially give the same indication. I like having both, because I always have pictured the Master Gate Bus LED to be grouped in with the other Gate Bus LEDs, and it tends to "blend in with the crowd", where the clock LED I've always envisioned as being somewhere near the clock input, so you get an instant feel for the frequency/duty cycle by looking at it.
scott
My Site
PostPosted: Sat Aug 11, 2007 4:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
full cans only please Very Happy
Scott Stites
Audio files: 96
PostPosted: Sat Aug 11, 2007 4:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
After the first few cans, he won't even feel it Very Happy
My Site
PostPosted: Sat Aug 11, 2007 5:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
As long as I can catch or dive I'll be OK Wink
It's good to see this develop into a real machine, especially the front panel design above makes it really come alive, looks great !
PostPosted: Sun Aug 12, 2007 5:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Fonik,
What's the "Bus 1 Reload" switch? Is that the invert/recycle that Jan came up with, or something else?
PostPosted: Sun Aug 12, 2007 6:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Holy crap batman !! Yes, Doh, !!! I will just whack you with a sack of resistors instead of a beer can Scott! I have to add one more pot Very Happy Very Happy Very Happy
Bill
Scott Stites
Audio files: 96
PostPosted: Sun Aug 12, 2007 6:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Andy,
Page 3 of the panel/interconnect (I have it labeled as Bus 1 Load). When a gate/trigger pair is detected on gate bus 1, it causes an instant reload of the pattern. It allows you to set the number of steps a particular pattern will provide. If you think of it in terms of a "normal" sequencer (IE, with only one high bit in the Klee pattern), it's more or less like the reset function. If your active bit is programmed at stage 1, you have Gate Bus Switch 5 set to gate 1, and Gate Bus Load is set to on, your pattern will have four steps.
Of course, the Klee will break the rules here if you'd like - you program a pattern with one bit, but, but the active bit is programmed at stage 6. In this case, (in 16X1 mode), the pattern will provide 15 steps, because the LED will slide from stage six through stage 16, then from 1 through 4, hit stage 5 and reload the bit at stage 6. So, with a bit of creative switch flipping, you can make it act as a "skip", because in this case, the overall effect is that it skips stage 5.
So, even with one bit (like a normal sequencer), the Klee allows you to decide where in the sequence you want to start, allows you to skip, or allows you to set the number of steps in the sequence. The sequence can have anywhere from 1 (one note repeating) to 16 steps (or 32 with invert B on).
When more than one bit is in the Klee pattern, the Gate Bus 1 load switch becomes more unpredictable, because any stage with an active 1 bit that's pointing its gate to gate Bus 1 will cause a reload - this tends to make for some fairly short sequences. It's great for on-the-fly switch flipping.
Bill, yeah. I think an optional manual range pot should probably go between 0 and 2V, otherwise it would be tricky to set where one wanted. I personally would replace the 8V range with it, meself. That's something we ought to determine during proto. Those resistors are pointy. Ouch! Just toss one of Jan's beers at me.....
Scott
My Site
Audio files: 235
PostPosted: Sun Aug 12, 2007 11:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Great work, Andy, Scott, everyone. This is something special. Very Happy
PostPosted: Mon Aug 13, 2007 6:56 am    Post subject: Reply with quote  Mark this post and the followings unread
This is just a rough idea of where things might go. Due to the sliders, it's quite different to Fonik's idea. It's a 4U * 19" version. Any ideas and/or suggestions are very welcome.
 Filesize:  84.27 KB
 Viewed:  11189 Time(s)
Scott Stites
Audio files: 96
PostPosted: Mon Aug 13, 2007 11:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Andy, it's really hard to tell - perhaps you should build one and send it here, and I can test it for you........ Very Happy
Seriously, that is sweet. I'd love to have sliders myself. Just looking at it gives me the impression that would make it more intuitive for programming.
There are a few things I've noticed with it:
1. I can't find the Invert B switch.
2. There doesn't seem to be a random input level control (one could survive without this, if one were able to control the level from the source of the signal).
3. (This is just a reminder to folks) - Manual Step and Reload (Load) are momentary switches - you've got toggle switches there. Not that that's wrong - I know there are momentary toggle switches, and they'd work fine, but just in case anyone was wondering....
Scott
My Site
PostPosted: Mon Aug 13, 2007 11:52 am    Post subject: Reply with quote  Mark this post and the followings unread
oh yes! sliders! they look beautiful and give one the overview in a second. maybe i should think about the frontpanel twice? mmmh. now you caused me to sway... 3U, 4U 5U, who cares?
