today> Twyndyllyngs Chez Mosc
Dual Purpose Klee
Page 4 of 5 [112 Posts]
THeff
Audio files: 33
PostPosted: Mon Aug 27, 2007 9:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
All,
I have modified the original Klee Patch sheet to provide more space between the Klee and the objects at the bottom. I also "hardwired" the envelope generators to the VCAs, and the audio connections to the mixer. I think these connections will pretty much always be the default.
Let me know what you think, like, or dislike.
Regards,
Tim
 Filesize:  578.38 KB
 Viewed:  618 Time(s)
Randaleem
PostPosted: Mon Aug 27, 2007 11:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Tim,
I liked the old layout better. But with more space between as already mentioned. Trade the bottom margin for the betweeen space. I also prefer the blank slate patch sheet of the first version you posted to this semi-hard wired one.
Randal
THeff
Audio files: 33
PostPosted: Tue Aug 28, 2007 9:35 am    Post subject: Reply with quote  Mark this post and the followings unread
OK Randal, How's this?
Tim
 Filesize:  516.17 KB
 Viewed:  626 Time(s)
Scott Stites
Audio files: 96
PostPosted: Tue Aug 28, 2007 11:16 am    Post subject: Reply with quote  Mark this post and the followings unread
I like it. I like it a lot Very Happy
I'm going to start using it and see how it works out. That is, if I can start using it again after I'm done putting these Klee Kables together (see, now you've got me started on the Klee alliteration) Very Happy
Scott
My Site
Randaleem
PostPosted: Tue Aug 28, 2007 11:59 am    Post subject: Reply with quote  Mark this post and the followings unread
THeff wrote:
OK Randal, How's this? Tim
I think you have done an excellent job on all of these. I do like this one best.
Kind regards,Randal
THeff
Audio files: 33
PostPosted: Tue Aug 28, 2007 3:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Scott & Randal,
Thanks for the feedback and glad you like it.
I have posted the Excel version of the v1_1 sheet. It will print out better and anyone can tweak it if they want to. I'm sure there will be further changes once we all start playing with. It's a lot of information to fit on one sheet!
Regards,
Tim
Klee Patch Sheet v1_1 Excel.zip
 Filename:  Klee Patch Sheet v1_1 Excel.zip
 Filesize:  11.78 KB
 Downloaded:  620 Time(s)
THeff
Audio files: 33
PostPosted: Wed Aug 29, 2007 8:48 pm    Post subject:  Hard at work... Reply with quote  Mark this post and the followings unread
Just another little noodle from deep in the industrial section of Kleevland.
Enjoy,
Tim
Kleevland Factory.mp3
 Filename:  Kleevland Factory.mp3
 Filesize:  2.39 MB
 Downloaded:  1111 Time(s)
Scott Stites
Audio files: 96
PostPosted: Wed Aug 29, 2007 10:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, never mind the state or country, but on which planet is Kleevland located?
That's my favorite yet. Is that all one take (IE, did you mix the voices as the sequence progressed, or did you multi-track)? I tend to think it's all one take because the timing is so tight. It sounds like there are more voices there than I've ever been able to squeeze into a single take, and again I'm impressed with how you sequence and arrange the voices. And you've got to be changing the pattern? Or the gate bus switches? Damn! I should know this stuff. Very Happy
Great work, indeed! Keep'em coming. Cool
My Site
mono-poly
PostPosted: Wed Aug 29, 2007 10:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice sample!
THeff
Audio files: 33
PostPosted: Thu Aug 30, 2007 6:20 am    Post subject:  Kleevage Reply with quote  Mark this post and the followings unread
Thanks Scott & mono-poly,
The "Kleevland Factory" was made in one pass and the only thing I did was to twitch the 8x2/16x1 switch about 3/4 of the way through and adjust the audio mix(OK, I played with the filters too!).
Scott has not divulged the gender of the Klee yet, but I think it must be a female with all the knobs and sensitive adjustments. It can also change it's mind and attitude very quickly.
Enjoy,
Tim
Scott Stites
Audio files: 96
PostPosted: Thu Aug 30, 2007 12:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Def female. If it were male, it would only have one switch. Laughing
My Site
THeff
Audio files: 33
PostPosted: Thu Aug 30, 2007 5:22 pm    Post subject:  Attachment function not working? Reply with quote  Mark this post and the followings unread
Anyone know why attachment is not working?
Tim
Audio files: 316
PostPosted: Thu Aug 30, 2007 5:30 pm    Post subject: Re: Attachment function not working? Reply with quote  Mark this post and the followings unread
Your last one? It seems OK now and here - Howard is working on the site I guess, causing occasional hiccups.
THeff
Audio files: 33
PostPosted: Thu Aug 30, 2007 6:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
I tried to upload an MP3 file about 4 times this morning and 3 times tonight. There is the typical long delay and the progress bar at the bottom moves to 100% but it never gets attached.
Tim
Scott Stites
Audio files: 96
PostPosted: Thu Aug 30, 2007 7:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, give it a shot now - it should work. I wanna hear it!
My Site
THeff
Audio files: 33
PostPosted: Thu Aug 30, 2007 7:43 pm    Post subject:  Finally I am postiing a sample without the word Klee in it.. Reply with quote  Mark this post and the followings unread
Now it's working!
Not too much to say about this sample, I just thought it was kind of unique.
Tim
Strange Enough.mp3
 Filename:  Strange Enough.mp3
 Filesize:  2.1 MB
 Downloaded:  1034 Time(s)
Scott Stites
Audio files: 96
PostPosted: Fri Aug 31, 2007 10:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool
On the planet Kleetos, the third moon rises just as the second sun sets. The strange enough Klee call mournfully fills the air, and soon after a rustling is heard amongst the technicolor bullrushes of the latex marsh - a second Klee has heard the call. The intrepid interplanetary zoologist flips on the recorder just as a fine specimen of the spotted metaklee bursts into view. Sides heaving, this new presence slips into four volt range, and with four pots adjusted on its anterior dorsal area, bleats out its response.
klee_kall.mp3
 Filename:  klee_kall.mp3
 Filesize:  2.93 MB
 Downloaded:  2328 Time(s)
My Site
THeff
Audio files: 33
PostPosted: Fri Aug 31, 2007 11:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Scott,
When my Klee heard the Klee Kall it(she) ran to the window and looked outside!
Cool sound, thanks!
Tim
23isgood
PostPosted: Fri Aug 31, 2007 11:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Scott. Just wanted to say I love all these tunes you are making with the Klee. Especially "Ad Astra". How many voices can you control with the Klee?
Check out my music
23isgood
PostPosted: Fri Aug 31, 2007 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey THeff, love "Kleevland Factory" too! Very cool stuff.
Check out my music
Audio files: 316
PostPosted: Fri Aug 31, 2007 12:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice new tracks Tim and Scott, keep 'm coming !
And sorry for not understanding you Tim, glad it got fixed.
THeff
Audio files: 33
PostPosted: Fri Aug 31, 2007 1:43 pm    Post subject: Attachment Problem Reply with quote  Mark this post and the followings unread
No problem Jan!
Scott filled me in on what was going and resolved the problem very quickly. I have zero complaints about this forum, you guys do a great job!
Regards,
Tim
Scott Stites
Audio files: 96
PostPosted: Fri Aug 31, 2007 3:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, the Klee produces three control voltages, so three different patterns are available at the same time. The gate bus, and programming of the voices, however can make it many more.
More than one voice can be controlled by one of the voltage outputs, and the gate bus can "chop up" the distribution of those voices so they appear to be entirely disconnected, or loosely connected. If the voices are operating at different intervals and/or have entirely different timbres, it works pretty well. Also, how the gate bus is connected can provide more variation to a voice - for example, often I like to control the EG of a voice from a combination of outputs from different gate busses - Say the trigger from Bus 1 and the Gate from Bus 2, etc. This allows a greater variance of the timing among the voices. It also allows a simple gate bus setting change to have a greater effect on the overall picture of the sequence.
Any well equipped step sequencer can do all of that - Peter Grenader's excellent Milton or that awesome Modcan Sequencer provide a myriad of control signals as well. The Klee differs in that everything is inter-related - the patterns are generated from the same pot settings and gate bus settings, so a change in any parameter is more of a holistic change to the entire sequence. Therefore the method of programming for the Klee is almost the exact opposite of a more traditional step sequencer.
Oh, Jeez, I could go on and on, but that's about it - the number of perceived individiual voices is pretty much up to the patch and the programming.
Scott
My Site
THeff
Audio files: 33
PostPosted: Fri Aug 31, 2007 5:12 pm    Post subject:  Klee with Attitude... Reply with quote  Mark this post and the followings unread
Here is biker Klee with a leather jacket on! Cool
Enjoy,
Tim
Lead, Follow, or Get Out of the Way.mp3
 Filename:  Lead, Follow, or Get Out of the Way.mp3
 Filesize:  1.69 MB
 Downloaded:  1093 Time(s)
Scott Stites
Audio files: 96
PostPosted: Sun Sep 02, 2007 2:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
A very cool sample indeed, as usual. I picture a fruity Marlon Brando tooling down the road, cutting off Packards and old fruit trucks, while cheerfully flipping everyone, including the cops, the bird Laughing
My Site
