andrewF
Posted: Sat Nov 03, 2007 12:36 am Post subject:
Vosim Subject description: anyone got some samples? |
Hi
Probably this should be in diy, but searching for 'Vosim' brings me to this forum and I see some people have implemented the Vosim design on their Nords.
I have found an analog design for the Vosim in Electronotes, and am thinking of building it .... eventually.
in the meantime, I am curious to have a listen to some MP3s
to see if it does what I hope it does.
If anyone can upload or direct me to some samples of this, I would really appreciate it.
cheers |
Wout Blommers
Audio files: 123
G2 patch files: 12
andrewF
Posted: Sat Nov 03, 2007 12:55 am Post subject:
thanks for the link - never knew you could do so much with a Nord.....so i don't need a synth that takes up an entire wall in my study?...oh yes I do  |
G2 patch files: 626
Posted: Sat Nov 03, 2007 1:22 am Post subject:
Based on a quick read of Rob's text.
Included the prf in case you have the G2 demo.
| Description: |
| Filesize: |
47.57 KB |
| Viewed: |
18701 Time(s) |
| Description: |
 Download (listen) |
| Filename: |
vosim.pch2 |
| Filesize: |
1.09 KB |
| Downloaded: |
2320 Time(s) |
| Description: |
 Download (listen) |
| Filename: |
vosim.mp3 |
| Filesize: |
54.24 KB |
| Downloaded: |
1887 Time(s) |
jksuperstar
G2 patch files: 18
Posted: Sat Nov 03, 2007 9:19 am Post subject:
| (andrewF -- you can get a "demo" of the G2 that runs on PC at the clavia.com website) (it's somewhat limited, in that only 1 patch can be loaded, monophonic, and a few features such as the MIDI modules and some of the heavy DSP ones are all disabled. But it's still very useful none the less, and it's still real time). |
andrewF
Posted: Sat Nov 03, 2007 8:40 pm Post subject:
Thanks jksuperstar and g2ian
i have seen the demo before but have tended to avoid softsynths.
i can see from how quickly you can put together a patch, it has some advantages.
as i understand it, the sine^2 wave (sine wave multiplied by itself) results in a 'squared' sine wave, the shape is changed, not the frequency.
would it be simpler to use other waveforms such as trapezoid? (eyeing off my Till trapezoid generating thru0 VCO) |
Joined: Apr 03, 2004 Posts: 24673 Location: The Netherlands, Enschede
Posted: Sat Nov 03, 2007 9:12 pm Post subject:
| andrewF wrote: | | as i understand it, the sine^2 wave (sine wave multiplied by itself) results in a 'squared' sine wave, the shape is changed, not the frequency. |
Not quite
Squaring a sine yields another (co)sine with double the frequency, a DC shift and amplitude reduction. So basically it generates the 2nd harmonic.
See http://en.wikipedia.org/wiki/Trigonometry. _________________ Jan
electroboz
Joined: Nov 29, 2006 Posts: 25 Location: Lyndonville VT USA
G2 patch files: 6
electroboz
G2 patch files: 6
