Vosim
Page 1 of 1 [9 Posts]
andrewF
PostPosted: Sat Nov 03, 2007 12:36 am    Post subject: Vosim
Subject description: anyone got some samples?
Hi
Probably this should be in diy, but searching for 'Vosim' brings me to this forum and I see some people have implemented the Vosim design on their Nords.
I have found an analog design for the Vosim in Electronotes, and am thinking of building it .... eventually.
in the meantime, I am curious to have a listen to some MP3s
to see if it does what I hope it does.
If anyone can upload or direct me to some samples of this, I would really appreciate it.
cheers
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Nov 03, 2007 12:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Try http://nm-archives.electro-music.com/010_NordModular/015_Workshops/Hordijk1999-2000/VOSIM.html
It's a little bit scrambled by the internet (I think the text is twice on the page) and it's written to the NM Classic (Oscillator Bank doesn't exist in the G2), but it's usefull. The writer is participant on this forum BTW
Wout
Oh, sorry, no mp3s Sad
andrewF
PostPosted: Sat Nov 03, 2007 12:55 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for the link - never knew you could do so much with a Nord.....so i don't need a synth that takes up an entire wall in my study?...oh yes I do Very Happy
G2 patch files: 626
PostPosted: Sat Nov 03, 2007 1:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Based on a quick read of Rob's text.
Included the prf in case you have the G2 demo.
 Filesize:  47.57 KB
 Viewed:  18671 Time(s)
vosim.pch2
 Filename:  vosim.pch2
 Filesize:  1.09 KB
 Downloaded:  2312 Time(s)
vosim.mp3
 Filename:  vosim.mp3
 Filesize:  54.24 KB
 Downloaded:  1881 Time(s)
jksuperstar
G2 patch files: 18
PostPosted: Sat Nov 03, 2007 9:19 am    Post subject: Reply with quote  Mark this post and the followings unread
(andrewF -- you can get a "demo" of the G2 that runs on PC at the clavia.com website) (it's somewhat limited, in that only 1 patch can be loaded, monophonic, and a few features such as the MIDI modules and some of the heavy DSP ones are all disabled. But it's still very useful none the less, and it's still real time).
andrewF
PostPosted: Sat Nov 03, 2007 8:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks jksuperstar and g2ian
i have seen the demo before but have tended to avoid softsynths.
i can see from how quickly you can put together a patch, it has some advantages.
as i understand it, the sine^2 wave (sine wave multiplied by itself) results in a 'squared' sine wave, the shape is changed, not the frequency.
would it be simpler to use other waveforms such as trapezoid? (eyeing off my Till trapezoid generating thru0 VCO)
Audio files: 327
PostPosted: Sat Nov 03, 2007 9:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not quite Very Happy
Squaring a sine yields another (co)sine with double the frequency, a DC shift and amplitude reduction. So basically it generates the 2nd harmonic.
See http://en.wikipedia.org/wiki/Trigonometry.
electroboz
G2 patch files: 6
PostPosted: Fri Nov 23, 2007 5:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
I realise i am a little late on this.
but you inspired this lovely little patch.
vosim analog.pch2
 Filename:  vosim analog.pch2
 Filesize:  2.97 KB
 Downloaded:  1842 Time(s)
electroboz
G2 patch files: 6
PostPosted: Fri Nov 23, 2007 6:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
and an mp3 for those who can't run the patch.
fake subtractor.mp3
 Filename:  fake subtractor.mp3
 Filesize:  1.76 MB
 Downloaded:  1174 Time(s)
