A clean laptop power supply?
Page 1 of 1 [22 Posts]
jamos
G2 patch files: 41
PostPosted: Mon Dec 05, 2005 11:28 pm    Post subject: A clean laptop power supply? Reply with quote  Mark this post and the followings unread
I'm playing with a couple of laptoppers these days. Onne of them is running a Dell laptop; when he plugs in his external power supply there is all sort of noise in his audio output. I've had similar problems with my Dell laptop - different model but a similar power supply - which is one reason I don't use it anymore. Running on batteries, both sound fine.
Does anyone know of a source for _clean_ power supplies for laptops? If not, I think I've just discovered a market niche.
Mohoyoho
PostPosted: Tue Dec 06, 2005 6:56 am    Post subject: Reply with quote  Mark this post and the followings unread
What I've had to do is get a two prong adaptor to lift the ground. Also a better audio out improves performance markedly. I use the Echo card which has made an amazing difference.
PostPosted: Tue Dec 06, 2005 7:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Seconded. Lift that ground. You'll soon be joining the people for whom conversations go like;
"My laptop's sound makes a...."
"Yeah, lift the ground, get a two prong adapter".
Just do it, ignore those types who say it's for safety; your adapter and case are plastic; you can't electrocute yourself touching plastic. Keep the adapter out of reach of beer glasses though. If you are still scared take a long grounded cable and put it on a grounded group that's not the group the rest of your gear is on, that can help too.
I keep a U.S. and a European two prong adapter in my laptop bag at all times.
jamos
G2 patch files: 41
PostPosted: Tue Dec 06, 2005 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks - we've actually done both of those things with mixed results.. sometimes we get noise, sometimes not. It's nasty, whatever the cause.
deknow
PostPosted: Tue Dec 06, 2005 8:38 am    Post subject: Reply with quote  Mark this post and the followings unread
jamos, i have written about this a few times on the forum. i install/train speech recognition systems, and this is a common problem. it can happen under any (or all) of the following circumstances:
plugged in and battery is fully charged
plugged in and the battery is charging
running on battery
so there are a few obvious solutions (like if it only happens when the battery is charging, then plug the laptop in with the battery fully charged). you might also try removing the battery and running on ac
if none of this works, you can also try grounding the laptop (probably a good idea to use a multimeter to make sure there isn't a large current first). you can use any of the shields on any connector in the back printer port, etc), or what i've done is cut the end off a usb connector, and soldered a ground wire to the shield only.
deknow
deknow
PostPosted: Tue Dec 06, 2005 8:40 am    Post subject: Reply with quote  Mark this post and the followings unread
btw, i'm not convinced that it's the "power brick" that is at fault, so an aftermarket "clean" one might not help. the power supply (in the laptop) has to decide when to charge the battery, and i expect this is a large part of the problem.
deknow
jamos
G2 patch files: 41
PostPosted: Tue Dec 06, 2005 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
What we've found is that the noise is present any time the block is plugged in, regardless of whether the battery is fully charged or not. I think. We will need to do some experiementation. Thanks for all the suggestions.
I've always associated grounding problems with hum, not the high frequency hash noise that we hear, which I'm pretty sure is a result of the switching power supply.
deknow
PostPosted: Tue Dec 06, 2005 9:40 am    Post subject: Reply with quote  Mark this post and the followings unread
you might want to read the following:
http://www.rme-audio.com/english/techinfo/hdsp_notebase.htm
again, i'd try grounding the laptop, i think you will find this noise will reduce considerably.
deknow
deknow
PostPosted: Tue Dec 06, 2005 10:22 am    Post subject: Reply with quote  Mark this post and the followings unread
...one other suggestion. make sure all of the audio devices (cd, line, mic, wave,) that are not needed are muted in the system's mixer, i've seen these bring in tons of noise.
deknow
Mohoyoho
PostPosted: Tue Dec 06, 2005 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Try the Echo Indigo sound card. That really makes a difference. The sound cards that come with laptops are terrible, and there is something about them or the way they are wired that makes them noisey. When I installed my Echo, it was night and day (and that is no exagerration). I use the standard Echo Indigo because the I/O wasn't available at the time.
Mark Mahoney
Kingsport, Tennessee
www.cdbaby.com/cd/markmahoney
Audio files: 235
PostPosted: Tue Dec 06, 2005 11:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Kassen. Your post about lifting the grounds brought tears of joy to my eyes. You are wise beyond your years...
PostPosted: Tue Dec 06, 2005 12:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
My laptop gets crazy crap coinciding with what's displayed on the screen...I can actually *hear* my mouse moving! Not using the laptop's sound (an Emu 1616m PCMCIA card) changed everything.
However, once in a blue moon, I can faintly hear the same crap coming through into my speakers. The DAC's on my system are the outboard kind, and the mechanism to communicate between PCMCIA and external box is differential, with no ground. I can only guess it's electro-magnetically transmitted. Odd, even from an LCD.
Lifting the ground on the power supply can definitely help though, or if your laptop supports it, using SPDIF out to an external piece of gear. (I've noticed lots of laptops supporting SPDIF out via the microphone plug & external dongle). (btw- this is my method of getting good audio out of Linux, sending SPDIF into an outboard reverb that has good DACs and SPDIF!).
Audio files: 235
PostPosted: Tue Dec 06, 2005 12:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would guess that Firewire and even USB (if you cut the ground) would provide the same isolation.
PostPosted: Tue Dec 06, 2005 12:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some IBM and Dell laptops will send a high frequency noise out on the audio line out in sync with mouse movements. In some cases this can also be solved by lifting the ground. On the 6 machines I have seen with this "problem" the high freq noise and the hum went away when an echo PC thingie was used instead of the PC audio line outs. Same thing with a Motu 896 firewire thingie.
Flickr
djfoxyfox
Audio files: 6
PostPosted: Tue Dec 06, 2005 3:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Last September at Different Skies, my laptop's power supply was also making noise. But the noise wasn't only in my mixer's audio output. Noise was going THROUGH THE POWER CABLE'S GROUND into someone else's synthesizer. This synthesizer's audio outputs were not going through my mixer but still had noise since its power cord was plugged into my power strip.
LIFT THE GROUND!!!! Smile
sheldonstv
PostPosted: Wed Dec 07, 2005 4:37 am    Post subject:  smps grounding Reply with quote  Mark this post and the followings unread
Very Happy The ground connection on the primary side of your laptop switch mode power supply is a saftey feature,but due to the way the power supply works (due to defective components-it is a fault!!!-but not a dangerouse one...) there can be a large amount of noise due to the earth connection.
UNDER NO CIRCUMSTANCES DO YOU CONNECT THE POWER SUPPLY - CONNECTION TO GROUND(THE SECONDARY SIDE NEGATIVE CONNECTION )!!!-THERE WILL BE A BANG!!
Due to the fact any smps doesnt supply mains isolation(switched mode power supply) any connection to mains earth will instantly kill it...
Have you access to a scope to check if there is any ripple on your power supply outputs?
regards mike
zyld crin
PostPosted: Fri Jun 13, 2008 10:30 pm    Post subject: A clean laptop power supply?
Subject description: It worked! You're a genius!
Very Happy Mohoyoho you are a life-saver, nay, a genius Idea - OK you're both!
I have a HP Pavilion that I have been using in my studio and the only way I could do a session is to unplug the brick power supply and run on batteries. The downside Crying or Very sad is that when the battery gets low I have to end my recording time and plug it back in. What a drag.
Idea I had determined that I was going to buy (1) 6-Volt and (1) 12-Volt Gel Cell or Zinc-Acid or some other suitable battery compliment, run them in series and operate my computer from them when in record mode. The batteries would probably last days between charges and I would be rid of the hum, but with a new problem: battery maintenance and charging regulation.
Your solution worked wonderfully and at 1/1000th the cost! Very Happy
Well done!
Mohoyoho
PostPosted: Fri Jun 13, 2008 11:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
You're welcome. I learned from experience and pass it on to anyone who comes by this thread.
Mark Mahoney
TheShaggyDA
PostPosted: Sat Jun 14, 2008 12:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
New terminology for me - how exactly does one "Lift the ground"?
PostPosted: Sat Jun 14, 2008 12:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Scaffolds tend to help ;¬)
In case this wasn't a word-joke; just make sure the ground pin of the adapter doesn't connect to the mains ground. The is most easily done by getting a two-prong adapter, any good electricity bits store should have one for a buck or two.
When in a pinch; on US plugs you can saw off the ground pin, on mainland EU ones you can use tape over the ground connectors.
factus10
PostPosted: Mon Jun 16, 2008 3:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have an Echo Indigo and it is a very good card for laptops that have PCMCIA slots. I also have a Lexicon Lamba. Neither eliminates ground noise completely, however.
I've tried lifting the PS ground with both my HP and MacBook laptops. Results were ok but not great.
The solution I use is two DI boxes and I lift the ground with those. They provide absolutely amazing ground noise elimination. I use a pair of inexpensive Behringer DI boxes because, frankly, the power amps in venues just aren't that amazing and the slight loss of bandwidth isn't very noticeable. If it's a problem for you, get more expensive DI boxes.
Nothing succeeds like excess.
Coriolis
PostPosted: Sun Jul 20, 2008 4:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I have one of those IBM-noise sources:
-Internal sound on batteries = tons of static/glitchy noise
-Internal sound on AC = somewhat less of the above
- My Focusrite Saffire LE card (firewire) = Nothing. Not a sound.
I have not lifted my ground, but mebbe I should, cause I use the internal card to listen to music a lot. Good thread this - answers some questions for me..
C
