jamos
Joined: Jun 01, 2004 Posts: 514 Location: Eugene, Oregon, USA
G2 patch files: 41
Posted: Mon Dec 05, 2005 11:28 pm Post subject:
A clean laptop power supply? |
I'm playing with a couple of laptoppers these days. Onne of them is running a Dell laptop; when he plugs in his external power supply there is all sort of noise in his audio output. I've had similar problems with my Dell laptop - different model but a similar power supply - which is one reason I don't use it anymore. Running on batteries, both sound fine.
Does anyone know of a source for _clean_ power supplies for laptops? If not, I think I've just discovered a market niche. |
Mohoyoho
Posted: Tue Dec 06, 2005 6:56 am Post subject:
| What I've had to do is get a two prong adaptor to lift the ground. Also a better audio out improves performance markedly. I use the Echo card which has made an amazing difference. |
Posted: Tue Dec 06, 2005 7:41 am Post subject:
| Mohoyoho wrote: | | What I've had to do is get a two prong adaptor to lift the ground. Also a better audio out improves performance markedly. I use the Echo card which has made an amazing difference. |
Seconded. Lift that ground. You'll soon be joining the people for whom conversations go like;
"My laptop's sound makes a...."
"Yeah, lift the ground, get a two prong adapter".
Just do it, ignore those types who say it's for safety; your adapter and case are plastic; you can't electrocute yourself touching plastic. Keep the adapter out of reach of beer glasses though. If you are still scared take a long grounded cable and put it on a grounded group that's not the group the rest of your gear is on, that can help too.
I keep a U.S. and a European two prong adapter in my laptop bag at all times. _________________ Kassen |
jamos
G2 patch files: 41
Posted: Tue Dec 06, 2005 8:23 am Post subject:
| Thanks - we've actually done both of those things with mixed results.. sometimes we get noise, sometimes not. It's nasty, whatever the cause. |
deknow
Posted: Tue Dec 06, 2005 8:38 am Post subject:
jamos, i have written about this a few times on the forum. i install/train speech recognition systems, and this is a common problem. it can happen under any (or all) of the following circumstances:
plugged in and battery is fully charged
plugged in and the battery is charging
running on battery
so there are a few obvious solutions (like if it only happens when the battery is charging, then plug the laptop in with the battery fully charged). you might also try removing the battery and running on ac
if none of this works, you can also try grounding the laptop (probably a good idea to use a multimeter to make sure there isn't a large current first). you can use any of the shields on any connector in the back printer port, etc), or what i've done is cut the end off a usb connector, and soldered a ground wire to the shield only.
deknow |
deknow
Posted: Tue Dec 06, 2005 8:40 am Post subject:
btw, i'm not convinced that it's the "power brick" that is at fault, so an aftermarket "clean" one might not help. the power supply (in the laptop) has to decide when to charge the battery, and i expect this is a large part of the problem.
deknow |
jamos
G2 patch files: 41
Posted: Tue Dec 06, 2005 9:17 am Post subject:
What we've found is that the noise is present any time the block is plugged in, regardless of whether the battery is fully charged or not. I think. We will need to do some experiementation. Thanks for all the suggestions.
I've always associated grounding problems with hum, not the high frequency hash noise that we hear, which I'm pretty sure is a result of the switching power supply. |
deknow
deknow
Posted: Tue Dec 06, 2005 10:22 am Post subject:
...one other suggestion. make sure all of the audio devices (cd, line, mic, wave,) that are not needed are muted in the system's mixer, i've seen these bring in tons of noise.
deknow |
Mohoyoho
Joined: Jan 31, 2003 Posts: 18314 Location: Durham, NC
Audio files: 235
Posted: Tue Dec 06, 2005 11:30 am Post subject:
Kassen. Your post about lifting the grounds brought tears of joy to my eyes. You are wise beyond your years... _________________ --Howard
my music and other stuff |
Posted: Tue Dec 06, 2005 12:41 pm Post subject:
My laptop gets crazy crap coinciding with what's displayed on the screen...I can actually *hear* my mouse moving! Not using the laptop's sound (an Emu 1616m PCMCIA card) changed everything.
However, once in a blue moon, I can faintly hear the same crap coming through into my speakers. The DAC's on my system are the outboard kind, and the mechanism to communicate between PCMCIA and external box is differential, with no ground. I can only guess it's electro-magnetically transmitted. Odd, even from an LCD.
Lifting the ground on the power supply can definitely help though, or if your laptop supports it, using SPDIF out to an external piece of gear. (I've noticed lots of laptops supporting SPDIF out via the microphone plug & external dongle). (btw- this is my method of getting good audio out of Linux, sending SPDIF into an outboard reverb that has good DACs and SPDIF!). |
Audio files: 235
Posted: Tue Dec 06, 2005 12:44 pm Post subject:
I would guess that Firewire and even USB (if you cut the ground) would provide the same isolation. _________________ --Howard
Posted: Tue Dec 06, 2005 12:49 pm Post subject:
Some IBM and Dell laptops will send a high frequency noise out on the audio line out in sync with mouse movements. In some cases this can also be solved by lifting the ground. On the 6 machines I have seen with this "problem" the high freq noise and the hum went away when an echo PC thingie was used instead of the PC audio line outs. Same thing with a Motu 896 firewire thingie. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
djfoxyfox
Joined: Feb 05, 2003 Posts: 3607 Location: Nazareth, Pennsylvania, USA
Audio files: 6
Posted: Tue Dec 06, 2005 3:56 pm Post subject:
Last September at Different Skies, my laptop's power supply was also making noise. But the noise wasn't only in my mixer's audio output. Noise was going THROUGH THE POWER CABLE'S GROUND into someone else's synthesizer. This synthesizer's audio outputs were not going through my mixer but still had noise since its power cord was plugged into my power strip.
LIFT THE GROUND!!!!  _________________ Bill Fox------------------|\-------------
-----------()----soundscapes.us/bill |
sheldonstv
Posted: Wed Dec 07, 2005 4:37 am Post subject:
smps grounding |
The ground connection on the primary side of your laptop switch mode power supply is a saftey feature,but due to the way the power supply works (due to defective components-it is a fault!!!-but not a dangerouse one...) there can be a large amount of noise due to the earth connection.
UNDER NO CIRCUMSTANCES DO YOU CONNECT THE POWER SUPPLY - CONNECTION TO GROUND(THE SECONDARY SIDE NEGATIVE CONNECTION )!!!-THERE WILL BE A BANG!!
Due to the fact any smps doesnt supply mains isolation(switched mode power supply) any connection to mains earth will instantly kill it...
Have you access to a scope to check if there is any ripple on your power supply outputs?
regards mike
zyld crin
Joined: Jun 13, 2008 Posts: 1 Location: Normal, IL. USA
Posted: Fri Jun 13, 2008 10:30 pm Post subject:
A clean laptop power supply? Subject description: It worked! You're a genius! |
Mohoyoho you are a life-saver, nay, a genius - OK you're both!
I have a HP Pavilion that I have been using in my studio and the only way I could do a session is to unplug the brick power supply and run on batteries. The downside is that when the battery gets low I have to end my recording time and plug it back in. What a drag.
I had determined that I was going to buy (1) 6-Volt and (1) 12-Volt Gel Cell or Zinc-Acid or some other suitable battery compliment, run them in series and operate my computer from them when in record mode. The batteries would probably last days between charges and I would be rid of the hum, but with a new problem: battery maintenance and charging regulation.
Your solution worked wonderfully and at 1/1000th the cost!
Well done! |
Mohoyoho
TheShaggyDA
Posted: Sat Jun 14, 2008 12:09 pm Post subject:
| New terminology for me - how exactly does one "Lift the ground"? |
Posted: Sat Jun 14, 2008 12:23 pm Post subject:
| TheShaggyDA wrote: | | New terminology for me - how exactly does one "Lift the ground"? |
Scaffolds tend to help ;¬)
In case this wasn't a word-joke; just make sure the ground pin of the adapter doesn't connect to the mains ground. The is most easily done by getting a two-prong adapter, any good electricity bits store should have one for a buck or two.
When in a pinch; on US plugs you can saw off the ground pin, on mainland EU ones you can use tape over the ground connectors. _________________ Kassen |
factus10
Joined: Jun 20, 2007 Posts: 158 Location: Buffalo, NY
Posted: Mon Jun 16, 2008 3:23 pm Post subject:
I have an Echo Indigo and it is a very good card for laptops that have PCMCIA slots. I also have a Lexicon Lamba. Neither eliminates ground noise completely, however.
I've tried lifting the PS ground with both my HP and MacBook laptops. Results were ok but not great.
The solution I use is two DI boxes and I lift the ground with those. They provide absolutely amazing ground noise elimination. I use a pair of inexpensive Behringer DI boxes because, frankly, the power amps in venues just aren't that amazing and the slight loss of bandwidth isn't very noticeable. If it's a problem for you, get more expensive DI boxes. _________________ Nothing succeeds like excess. |
Coriolis
Joined: Apr 11, 2005 Posts: 616 Location: Stilling, Denmark
Posted: Sun Jul 20, 2008 4:40 am Post subject:
I have one of those IBM-noise sources:
-Internal sound on batteries = tons of static/glitchy noise
-Internal sound on AC = somewhat less of the above
- My Focusrite Saffire LE card (firewire) = Nothing. Not a sound.
I have not lifted my ground, but mebbe I should, cause I use the internal card to listen to music a lot. Good thread this - answers some questions for me..
C _________________ Some Rubber Stamp Sound Effects - and other sound effects |
