interested in a PCB or 4? |
yep |
98% |
[ 151 ] |
nope |
1% |
[ 2 ] |
Total Votes : 153 |
zthee
Posted: Wed Jul 02, 2008 11:37 pm Post subject:
Got my 2 boards up and running yesterday!
Thanks for a great module!
toppobrillo
Joined: Dec 10, 2005 Posts: 766 Location: oakland, ca
Posted: Thu Jul 03, 2008 12:36 am Post subject:
Quote: | ot my 2 boards up and running yesterday! |
glad to hear it! yours is maybe the 4th successful build i've heard about so i am confident now that noone should have any problems.
thanks!
josh |
Pehr
Joined: Aug 14, 2005 Posts: 1307 Location: Björkvik, Sweden
zthee
Posted: Thu Jul 03, 2008 11:54 am Post subject:
Pehr, I used a 78L05. But I only used 2 boards.. might be to small for 4? (I think Topp said it was OK a few pages back..). |
Pehr
zthee
Posted: Thu Jul 03, 2008 12:46 pm Post subject:
Ah, yes ofcourse I ment 78L10 (It's just that I'm building something with a 78L05 in it right now and it was the first numbers that came to my mind.. ) |
Rykhaard
Posted: Fri Jul 04, 2008 7:07 am Post subject:
My 2 x 281 clone boards arrived yesterday! Weeeee.
The day after my T.Henry 3080 book arrived from Magic Smoke / Lulu. (WONDERFUL book! Thanks greatly Thomas / Tim! )
Still have 2 K.Stone Gate Sequencer summing boards coming ......
As The Backlog Grows ..... lol
After my 6 month break from building, I'm having such a tough time on deciding what to build next!
- I can't wait for the 281's to be completed but
- I've only got 3 VCOs at the mo' (with boards for 4 more)
- I want to get my sequencer designs built
- I want to order more R.Wilson MFOS Sequencer digital boards, for modding
- 2 x R.Wilson State Variables have been started
- 1 x R.Wilson ADSR is almost finished
- 2 x R.Schultz/K.Stone VCA #'s 3 and 4 just need to be mounted
- and there're still a few little things to finish!
AIIIIEEIEIEEEIEEYYYEEEEEE! W/ 2hrs. per day allowed, to build.
At least now though, I have a high end Hewlett Packard Frequency Counter that I got free from work, to tune my VCOs with.
Gawd it's great to be back to building!! Now - if I'd finally register the FTP software that I use for building my webpage, I could get new photos up.
(/happy ranting over) lol |
RF
Joined: Mar 23, 2007 Posts: 1502 Location: Northern Minnesota, USA
Audio files: 28
Posted: Fri Jul 04, 2008 7:31 am Post subject:
Rykhaard wrote: |
Gawd it's great to be back to building!! |
Ditto!
I moved recently and my building stopped for two months.
I still can't manage 2 hours a day, ryk - so I envy your time allotment.
I have four of these boards - I just looked at them again last night as I was prioritizing MY backlog. Besides these and a bunch of CGS boards the Klee still haunts me. I keep blaming my lack of a perfect panel design....but really - it's just a daunting project.
I DO hope to have the 281 done in the next few weeks.
bruce |
Rykhaard
Posted: Fri Jul 04, 2008 11:23 am Post subject:
Less time than ME Bruce? OMFG! And I thought I had it bad.
I ran out of time today as well - using the Hewlett Packard tuner, found that my 3 VCOs are well within 0.25% tuning - cool. Finer tuning later, with this tool.
Checked the tuning on my 4 step rotary switch tuner - except for 1 dirty position on 2 rotaries; almost perfect tuning. Weeeee. (Detuning trouble I had earlier, COULD have been my wierd Ken Stone VCO, where 1 CV pot wasn't all the way and was throwing an off-voltage into things. Hope I fixed that, by zeroing the pot.)
Not much time left, I added the 5th bit switch, to my 5 bit switches (for 32 notes in 1V/octave) to my breadboard. After finding an errant extra resistor, found tuning to be within a couple of percent.
Sooooo .... the tuning of it IS possible. I just have 0.1% 16 resistors for it and all is cool. (I think. Haha.)
Ran out of time. This has been decided as my current project though. So if all goes well, within 2 or 3 weeks, I should have my 8 or 16 step, 5 bit switches per step, sequencer, up and running. Shall see.
Damn time - keeps running out! lol |
synthmonger
Posted: Fri Jul 11, 2008 9:22 am Post subject:
zthee wrote: | Got my 2 boards up and running yesterday!
Is that panel made of cardboard? |
zthee
Posted: Fri Jul 11, 2008 9:25 am Post subject:
Yes it is!
I'm getting the aluminum version of it next week. I always make a dummy before ordering. I don't want to miss any input/outputs or have to many. |
toppobrillo
Posted: Sat Jul 12, 2008 6:42 pm Post subject:
so i just wrote someone alot about how i labeled my most recent panel and i thought maybe someone here may find it helpful too. it involves laser transparency paper and spray adhesive... very durable!
1. print the art in reverse [so that the toner will contact the panel and stay protected]
2. cut it to where you have a bit of excess on all sides, maybe 1 1/2" orso
3. tape your painted, drilled and otherwise finished panel down with double-sided tape
4.position your 'decal' properly over the panel
5. tape the top-edge [you could do the side edge too] of it down to your work surface with masking tape while keeping it in position [remember you left some excess]
6. make sure your tape is stuck well, fold the decal back on the tape 'hinge' make sure when you pull it back over the panel, it stays in perfect position [ i learned this simple technique while working in a sign-shop applying vinyl decals to things, i think it is called the 'hinge' technique if you want to look it up]
7. pull it back again, and give the panel and the decal an even coat of spray-adhesive [i used 3M general purp.] let it dry for 10-15 seconds, as the instructions say for a stronger bond
8. then carefully!! fold it back over, keeping the 'hinge' pulled taut, with your thumb,start to 'apply' the transparency like a sticker, use alot of pressure and consistent coverge, side-to-side, continue to lower the decal onto the panel while and keep smoothing it down, don't push too hard where you have holes drilled right now.
9. get it all down, then press hard around all the edges, this is probably the most important part- work FAST! that stuff dries super fast
10. remove the masking tape hinge carefully so that your sheet is all flat, you don't want any resistance.. press the sheet down all over, then press around the holes, keep doing it for like a minute or two-i suppose a rubber mallet might be good to use here if you have one. i don't, i just pressed as hard as i could till i was confident that i could do no more.
11. ok, so it is down and all flat, now let it dry for a while, maybe over night.
12. flip it over and trim the excess off with an exacto knife
13. with fine sandpaper, carefully sand the edges to where there is no transparency protruding over the edges. it might be easiest to tape the sandpaper down flat, and move the panel instead.
14.ok so it is looking nice now right?? remove ALL the gunk from the transparency with denatured alcohol, then with the finest steel-wool you can get, ruff up the surface of the plastic, it will take the glare off it.
15. all that is left is to cut out your holes with an exacto knife. try your hardest not to lift the decal around the holes [use a narrow blade]
ok that's it! maybe a print-shop could do light print with a color-laser printer, or make long prints for rack-panels..
here is a photo of the panel::
josh
Description: |
Filesize: |
647.41 KB |
Viewed: |
294 Time(s) |
Posted: Sun Jul 13, 2008 5:35 am Post subject:
very nice work, man! looks awesome. _________________
Tech Buddy at Random*Source |
rjd2
Posted: Mon Jul 14, 2008 6:26 am Post subject:
i know this is lame, but if anyone is doing a panel in either motm or dotcom height, id love to buy one if you are having them made. please pm me if so-thanks! |
ericcoleridge
Posted: Mon Jul 14, 2008 7:23 pm Post subject:
topp wrote: |
josh |
This is such beautiful work, the kind of work that inspired me to build my own synth in the first place. This is as nice of a design as has ever been made commercially. Thanks for showing it and for making these boards available. |
Fernando
Joined: Dec 30, 2006 Posts: 286 Location: Barcelona & Emporda, Spain
Posted: Tue Jul 15, 2008 4:17 am Post subject:
both are very very nice panels, wow! |
toppobrillo
a_guy_called_tom
Posted: Sun Jul 20, 2008 6:29 am Post subject:
D10 |
Hi all,
First post on electro-music, so hi everyone! Describing myself as a complete noob when it comes to electric circuits would pretty much hit the nail:) However, due to the nice pcb and documentation offered here by topp (big thanks!) i'm still giving it a go. Really dont want to miss an Envelope as nice as this one.
Gladly i could find all needed parts and started to build the first pcb of the pair today. One thing i'm not quite sure is where to put D10. I cant seem to find it anywhere on the pcb or the schematics. Any hints?
Thanks,
Tom |
Fernando
Posted: Mon Jul 21, 2008 8:01 am Post subject:
Josh, where do you get your switch caps?
And, with wich type of switches they work (fit) ?
thank you, |
Joined: Apr 03, 2004 Posts: 24373 Location: The Netherlands, Enschede
Audio files: 296
Posted: Mon Jul 21, 2008 11:53 am Post subject:
Re: D10 |
a_guy_called_tom wrote: | Hi all |
Tom _________________ Jan
numbertalk
Posted: Mon Jul 21, 2008 12:06 pm Post subject:
All the PCBs for this are gone, right? Saw something saying there were some extras but then a posting referencing a mention on matrixsynth made it sound like those are now gone. Any plans to make more? If not, is there a ready-to-transfer image available for etching a board for myself?
Thanks! |
toppobrillo
Posted: Tue Jul 22, 2008 4:57 pm Post subject:
Quote: | Any plans to make more? |
well i have gotten alot of email requests for more boards- is there actually enough interest in a 2nd run of these? PM me if you would be interested..
i would need at least 50 pre-orders to do it. turnaround time would be very fast this time, like 2-4 weeks- but the price will likely increase with a smaller with a smaller qty. order with better turnaround. maybe $10-$12 ea.
ok so we will see... |
ericcoleridge
numbertalk
Posted: Wed Jul 23, 2008 9:27 am Post subject:
Sent you a PM - would definitely take 4.
topp wrote: | Quote: | Any plans to make more? |
zthee
