lunetta sound samples
Page 7 of 13 [311 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13 Next
aerogramma
PostPosted: Sun Aug 23, 2009 4:45 am    Post subject: 4051 squencer Reply with quote  Mark this post and the followings unread
more 40106/4051/4040 action from the proven Mike Collins design.
for this one in particular i used Seamoss' implementation plus a few tweaks.
seq 1 is really just a demo of what it can do... at least in my hands
seq 2 is a bit more interesting with the pattern forming a cloud of pitches really close to each other resembling a bit what Ligeti used to do with hyperharmony
crude samples, no reverb or editing
Wink
aero
4051 sequencer 1.mp3
 Filename:  4051 sequencer 1.mp3
 Filesize:  2.94 MB
 Downloaded:  1086 Time(s)
4051 sequencer 2.mp3
 Filename:  4051 sequencer 2.mp3
 Filesize:  923.67 KB
 Downloaded:  1082 Time(s)
PostPosted: Sun Aug 23, 2009 8:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice ones!
Audio files: 228
PostPosted: Mon Aug 24, 2009 10:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice ones!
Quite nice!
adamon
PostPosted: Sat Oct 03, 2009 11:13 am    Post subject: Some new sounds Reply with quote  Mark this post and the followings unread
Hello again! I just thought I'd let everyone in the lunetta neck of the woods know that I posted two new tracks on my myspace page (10-2-09 and 9-12-09); its all lunetta except for some filtering here and there (MFOS WSG filter...), and obviously some reverb. I just got my first 4077 ring mod module going, and its been nice to have some new sounds to play with (see track 10-2-09 one)!
www.soundcloud.com/adamon
RF
Audio files: 28
PostPosted: Sat Oct 03, 2009 6:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
YEs! It's nice to see someone posting some tracks again!
Way to go!
bruce
www.sdiy.org/rfeng
LetterBeacon
PostPosted: Sat Oct 10, 2009 8:10 am    Post subject: Re: Some new sounds Reply with quote  Mark this post and the followings unread
Really enjoyed those - nice one!
Audio files: 228
PostPosted: Sat Oct 10, 2009 7:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice tracks, Adamon. I wouldn't have guessed you used your Lunetta for these. thumb up
adamon
PostPosted: Sat Oct 10, 2009 8:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the feedback guys, I appreciate it! I've found it hard to achieve a good balance between time spent working on the synth and time spent actually playing it (usually a little of both I guess...). Overall, its usually just hard to really just sit down and get a complete track done; I always have a handful of modules being used to test new concepts, so it seems like I rarely use it to it's full potential. Luckily, these two tracks really utilize just about everything I have gotten up and running so far.
mosc, a purist would have a good argument against me; as I mentioned, I used some filtering (so hard for me to not use some most of the time...) and technically I'm also using a triangle/sine LFO that is op-amp based. Aside from the filter though (and the copious amounts of reverb), everything is lunetta based. I think one of my main focuses while building up a new lunetta patch is layering a lot of oscillators (I usually have around six going, all doing different things). I almost always have two or three tuned to the same pitch or off by a common interval (octave...), I've found that I really enjoy the wave interactions that go on when a couple oscillators are all humming together. I think another thing that makes some of my stuff a little different is that I tend to do a lot of knob twiddling and manual switching; I come from a guitar and piano background, so I like to be active with my music. I don't have any shift registers going yet, so I don't have a lot of the "melody generator" stuff going as well (I'm totally into it though... I just need more time than I have to mess with it!).
I'll be posting more soon hopefully! Thanks again to everyone for the feedback!
Audio files: 228
PostPosted: Sun Oct 11, 2009 10:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
adamon wrote:
mosc, a purist would have a good argument against me; .
Fortunately, it's nonsense to link Lunetta and purist. Laughing
Psyingo
PostPosted: Mon Oct 12, 2009 3:20 am    Post subject: Reply with quote  Mark this post and the followings unread
new lunetta! well not completely new. probably a week old now... but !!!
its built into a small cash box which is a great case to use, the case is wired to ground. for the vca+env, input and D/A module i added 1/8" and 1/4" outputs for easy interfacing to other equipment. the paint and finish on the case is a faux hammered metal supposed finish. instead it just looks like a meltymess, which i love.
there is a switch to share the clock from the far right shift register with the other shift registers so that i can output random bits to a melody generator or somesuch and create some generative sequences.
6x oscs with overlapping freq ranges from quite low to i think around 2mhz or so.
2x 4-bit shift register
2x 4-bit binary counter
1x 64-bit shift registers
1x VCA+ENV combo
1x Input module
1x 4-Bit D/A
this thing is great and works obviously quite well with my first lunetta.
linkssS:
Inside shot:
Money shot:
Back shot showing jacks:
sounnz:
I offered these to Inventor for the lunetta show.
Schrang:
Simple patch. Bass beep to and gate for gating. Noise burst is a pair of asynchronous clocks going into the clock and data inputs of a shift register then into an and gate for gating. 3 shift registers with asynchronous data clocks are used for psuedo random bit sequences to drive the melody generator, which is then going into the VCA+ENV combo.
www.bitkins.com/ruin/schrang.mp3
technoz:
uhm this was kinda a complex patch,i dont really remember. the drum machine is an er-1, which has some of its voices going into the input module on the lunetta, which is driving both binary counters tied sequentialy, which is used to clock a shift register, which gives a psuedo random signal, feeding i think the melody gen. im also using the 64 bit shift register as a glitcher type thing, which repeats randomly some of the sounds from the er-1 at a pretty low bitrate. i think there might have been some and gates used as well for ringmods. i need more cables.
www.bitkins.com/ruin/papsmear_technoz.mp3
[Editor's note: I made the links to your photos show up in the post. You can do this yourself with the IMG bbcode tag around the URL. --mosc]
RF
Audio files: 28
PostPosted: Mon Oct 12, 2009 7:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Nicely done!~
bruce
www.sdiy.org/rfeng
PostPosted: Mon Oct 12, 2009 9:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Psyingo wrote:
Schrang:
Cool I really like that one!
technoz:
and another good one.
slacker
PostPosted: Mon Oct 12, 2009 11:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Great stuff Smile
DGTom
PostPosted: Mon Oct 12, 2009 5:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Psyingo crashed my computer!!! Laughing
heh, not really (thermal event! wtf its 9 degrees!) but I was listening to 'technoz' track & bbfffzzzzzztttt!!!! quite an intense moment Twisted Evil
Relly nice box! makes that ER-1 sound a million bucks (in bonds issued by the dada bank of course)
Audio files: 228
PostPosted: Wed Oct 14, 2009 6:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
great looking box and great tracks too. Thanks...
textual
PostPosted: Fri Mar 26, 2010 9:38 am    Post subject: Reply with quote  Mark this post and the followings unread
RF wrote:
Here is is...
this 4011 ring mod schematic... can the diodes be 1N914? what about the tranny can it be sub'd as well?
Thanks
______________________
www.dlbelectronics.com
www.textualmusic.com
www.mercuryprogram.com
slacker
PostPosted: Fri Mar 26, 2010 10:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Any diodes will work, any NPN transistor should work.
electri-fire
G2 patch files: 4
PostPosted: Sun Mar 28, 2010 11:52 am    Post subject: Re: 4051 squencer Reply with quote  Mark this post and the followings unread
That's the way I like it.
droffset
PostPosted: Tue Mar 30, 2010 1:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi folks, here's something I created with my Lunetta, a NAND synth and 3xDS8.
Editing in Audacity.(Try Audacity's pitch shift on your Lunetta recordings, it reveals awesome stuff.)
Enjoy!
Digest by droffset
Edit: Spelling mistakes.
RF
Audio files: 28
PostPosted: Tue Mar 30, 2010 2:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice clip droffset!
bruce
www.sdiy.org/rfeng
electri-fire
G2 patch files: 4
PostPosted: Tue Mar 30, 2010 3:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
droffset wrote:
Editing in Audacity. /.../ Enjoy!
I believe I have just been dissed? Laughing
Seriously enjoyable track droffset, I like it even editted Wink. Actually, I myself have been prone to using copious amounts of effects.
But it's good for those stumbling upon this forum to also hear lunetta's in their grand nakedness to familiarize themselves with their character and possibilities before people start building them to find they liked the processing or the DS8 especially.
Rykhaard
PostPosted: Tue Mar 30, 2010 5:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
That - were friggin' wild, droffset! In all of the Lunetta postings here, I've never heard a recording (Audacitied or not), like THAT! Surprised Smile
Your original post has been an inspiration! I've been an effects nut, for years and years. Finally - I have a fair pile of multi-fx units.
In a future recording though, I'm going to see if it's possible for me to record whatever is happening, at the same time:
- 1 recorder, with all effects / etc.
- another recorder, PRE-effects, for everything
When I get that done, I'll post the pair of recordings in a single message. That'll help clue others in, as to what things are like. Smile
- Mr. Multiple Delays into 10-20 second stereo reverb fan, I be ...
droffset
PostPosted: Tue Mar 30, 2010 7:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
RF, thanks man!
Electri-Fire... Diss to your FACE! Laughing Just kidding.
No diss intended, I'm just starting to try to organize stuff into a slightly more refined presentation. But hey if you like raw sound my Soundcloud has plenty of it, check it out. Smile
This one used cutting, volume automation, some pitch shifting, and a nifty plate reverb plugin. Three separate recording sessions were all cut and layered together then exported down to a single file, then the reverb applied to that and re-exported. My poor eeePC ran out of HD space a couple of times in the process.
Rykhaard - Thanks! Are you going to use stereo? It might work to record the left ear wet and the right ear dry.
textual
PostPosted: Mon Apr 05, 2010 4:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
a short clip. I am completely stoked and amazed at the music that this synth is capable of making! after this got somewhat set up, I increased 1 oscillator in speed driving the 4017 and then slowed it back down again.
lunetta drone 2.mp3
 Filename:  lunetta drone 2.mp3
 Filesize:  6.6 MB
 Downloaded:  911 Time(s)
PostPosted: Mon Apr 05, 2010 5:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Laughing some good sounds, yup Cool
