Luka
Scott Stites
Audio files: 96
Posted: Mon Aug 03, 2009 7:52 pm Post subject:
Luka and Photon,
Those are both really nice looking modules!
Cheerios,
adambee7
Joined: Apr 04, 2009 Posts: 420 Location: united kingdom
Posted: Mon Aug 03, 2009 9:29 pm Post subject:
Very nice system you have there. |
Photon
Posted: Tue Aug 04, 2009 5:54 am Post subject:
Luka--nice looking panels. Did you wind up etching them?
Thanks Scott. I appreciate you sharing your tap points and input mixer. cheers!
Here are a couple more pics:
Luka
ericcoleridge
Posted: Sun Aug 09, 2009 11:39 pm Post subject:
99% done with my 291. This is the original Verbos dual layout. I need to re-wire it, it's a rats nest right now... but I was anxious to get it up and running:
Description: |
Filesize: |
1.52 MB |
Viewed: |
501 Time(s) |
Description: |
Filesize: |
1.34 MB |
Viewed: |
649 Time(s) |
numbertalk
Posted: Mon Aug 10, 2009 5:27 am Post subject:
ericcoleridge wrote: | 99% done with my 291. This is the original Verbos dual layout. I need to re-wire it, it's a rats nest right now... but I was anxious to get it up and running: |
Looks great! |
frenchyinmunich
Posted: Sat Sep 05, 2009 8:58 am Post subject:
Mark verbos 291 clone component list |
Hello,
Somebody here knows where I could find a component list of the Mark Verbos PCB 291 clone?
Regards,
F |
Luka
Posted: Sat Sep 05, 2009 6:42 pm Post subject:
i think it is somethign like this
this is for a single filter so double everything
1r / FB 2
47k 2
62k 1
1.5k 4
15k 2
68r 1
1m 1
100k 1
10k 4
4m7 1
6k8 4
68k 1
1k 3
220r 1
2m2 1
10m 2
100k trim 1
5k trim 1
5k6 1
33k 2
4k7 2
470r 1
100uf 50v 2
10uf 50 1
470p 1
220p 1
901p 1
47p 1
22p 1
22n 2
470n 1
tl082 1
tl084 1
5534 1
vtl5c3 4
2n3566 2
1n4148 1
1n5228 1 _________________ problemchild
melbourne australia
http://www.last.fm/user/prblmchild |
frenchyinmunich
Posted: Sun Sep 06, 2009 4:21 am Post subject:
Merci |
Perfect!!
Thank you very much!
F |
frenchyinmunich
Posted: Sun Sep 06, 2009 10:35 am Post subject:
1r fb2 |
Thanks again for the list.
But, what means the 1r FB2?
Thanks,
f |
frenchyinmunich
Posted: Sun Sep 06, 2009 10:55 am Post subject:
291 component list |
Again... The 910 pf...
Seems there's a problem... |
Scott Stites
Audio files: 96
Posted: Sun Sep 06, 2009 12:42 pm Post subject:
A 1000 pF (1 nF) will do you just fine.
Cheerios,
KrIVIUM2323
Joined: Jan 01, 2009 Posts: 42 Location: Besancon/France/EU
Posted: Mon Sep 07, 2009 4:06 pm Post subject:
Quote: | But, what means the 1r FB2?
1 ohm resistor or a ferrite Bead. You can use either resistor or ferrite bead type (two needed )(ferrite bead allow better filtering if you have 'noisy' modules on the same supply). |
Scott Stites
Audio files: 96
Luka
Scott Stites
Audio files: 96
Posted: Mon Sep 14, 2009 6:52 pm Post subject:
I'm sure you did and I missed that part of the thread (I drift in and out of consciousness now and then); I'm glad it didn't zap you in any case. _________________ My Site |
LetterBeacon
Posted: Fri Dec 18, 2009 4:40 pm Post subject:
To Luka and Photon:
I just want to confirm that Luka's PCB layout works as in, with no modifications needed?
Thanks! |
Luka
numbernone
Joined: Aug 16, 2006 Posts: 477 Location: new york city
Posted: Sat Dec 19, 2009 11:04 am Post subject:
My 2 291s, which were built about a year apart behave completely different from one another. The first is quite tame and nice, while the second is a wicked beast that just loves to overload and distort in the worst/best fashion. Gonna be building the last one in 2010, and hope that I can dial it in to be very much on the money with Buchla, then I will have 3 kick ass filters from the same design.
It looks like by the end of next year there will be a lot more Buchla cloning than anyone previously imagined possible. Cant wait. |
Luka
Posted: Sun Dec 20, 2009 1:34 pm Post subject:
same here
one is really aggressive the other is a bit more timid, i might change the vactrols the timid one
LetterBeacon i might be etching some more 291s next year so ill change the layout a little to fix the kludges and change the mods a little. i didnt use the processor, instead i set up opamp to buffer and mix the filters to run in parallel model, perhaps making a vero board arrangement might be more handy _________________ problemchild
melbourne australia
LetterBeacon
Posted: Sun Dec 20, 2009 3:14 pm Post subject:
Luka wrote: | LetterBeacon i might be etching some more 291s next year so ill change the layout a little to fix the kludges and change the mods a little. i didnt use the processor, instead i set up opamp to buffer and mix the filters to run in parallel model, perhaps making a vero board arrangement might be more handy |
Excellent, I'll hold off etching the current PCB for a bit then. |
thermionicjunky
Joined: Dec 07, 2006 Posts: 90 Location: san francisco
Posted: Mon Dec 21, 2009 11:11 am Post subject:
I also built a dual filter using Luka's layout. I'm pretty new to DIY and the project, including the kludge in the output buffer, was pretty easy. I love this filter. My filters behave quite similarly, with maybe a bit of difference in the gain trimmer settings. With the LP and HP taps, this is my ideal multimode. I knew that I wanted a vactrol-heavy modular, but now my appetite is insatiable. I want to build the Music Easel balanced modulator and I'm still hoping that someone will do a layout of a properly functioning vactrol panner.
Thanks to Luka, Scott, Mark and Don for the 291! |
LetterBeacon
Posted: Mon Dec 21, 2009 12:20 pm Post subject:
Thats interesting to know. Are the kludges needed documented anywhere? |
thermionicjunky
Posted: Mon Dec 21, 2009 12:24 pm Post subject:
LetterBeacon wrote: | Thats interesting to know. Are the kludges needed documented anywhere? |
Luka sent out a diagram to the people using his boards. I believe that it was a simple matter of swapping pins 2 and 3 on the buffer IC. I suppose that you might as well wait for the layout to be redrawn, but it's not a big deal to correct it yourself if you can't wait. |
