2009 Build Pictures
Page 9 of 16 [399 Posts]
Goto page: Previous 1, 2, 3, ..., 7, 8, 9, 10, 11, ..., 14, 15, 16 Next
thundarr
PostPosted: Tue Aug 25, 2009 2:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
That soundlab is awe-inspiring, Lars. Really nice.
Here's my first ever module, a stripboarded MFOS noise cornucopia... Fibreboard panel, biro lettering a-go-go!
 Filesize:  68.04 KB
 Viewed:  10131 Time(s)
 Filesize:  56.53 KB
TekniK
PostPosted: Thu Aug 27, 2009 1:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
hmm
DETOX
PostPosted: Thu Aug 27, 2009 4:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
where can i find such fibreboards? i've always only thought about plexiglass as an alternative for alu-panels, but thats somehow cool too !!!
Waldorf Pulse
thundarr
PostPosted: Thu Aug 27, 2009 8:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
I got mine from B&Q, a hardware store, in a 2x1 metre sheet for about 3 pounds.
It cuts messily with a saw, but with a metal ruler, a stanley knife and some patience you can cut it very cleanly. Drills well too, although it needs some filing after.
Another day, another one built Smile MFOS VC LFO this time.
 Filesize:  179.9 KB
 Viewed:  9947 Time(s)
Dan Lavin
Audio files: 21
PostPosted: Tue Sep 01, 2009 6:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not sure why I haven't posted anything earlier. I have a couple more things that I should finish this year.
Synsonics modded per RichardC64's mods listed on Burnkit 2600 website.
 Filesize:  1.4 MB
 Viewed:  215 Time(s)
I re-paneled my TH Midi to Trigger and Snare+ and Craig Anderton HipBass Drum. The open panel spot is for the Ken Stone Cynare. This rack and the Synsonics will form my hardware analog drum kit.
 Filesize:  1.52 MB
 Viewed:  201 Time(s)
This is a re-cased M-Audio 88e. Finally....I have a decent 88 key keyboard.
 Filesize:  1.76 MB
 Viewed:  216 Time(s)
Finished my modular after 2 years!!! Yea!! From top to bottom: TH MTS-100 Midi to CV/Gate-Trigger, TH SN-Voice #1, TH SN-Voice #2, TH Super Controller, Dual VCA/Dual ADSR based on PAIA CEM3330/3310 pcbs, Dual CEM3340 VCO's, Moog LPF/VCA and dual ADS env
 Filesize:  4.35 MB
 Viewed:  238 Time(s)
Dan Lavin
Audio files: 21
PostPosted: Wed Sep 02, 2009 10:02 am    Post subject: Reply with quote  Mark this post and the followings unread
oops, the last part of my description of my modular got cut off. The crowded 2u on the bottom contains a Moog LPF, dual Moog ADS and VCA (essentually the arse-end of a minimoog) and a MFOS SV VCF....that 2u is the most packed of all my modules! On top of the modular is a rack-mounted SR&D Rockman IIb....compressor, EQ,analog chorus, reverb and distortion unit. Makes your cheap strat sound just like late 1970's Boston...or 1980's ZZ Top. Not sure why I keep it there.
richardc64
Audio files: 26
PostPosted: Wed Sep 02, 2009 11:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Love the re-packaged keyboard. The percussion unit and modular are impressive, too.
Dan Lavin
Audio files: 21
PostPosted: Wed Sep 02, 2009 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Richard,
yeah the M-Audio 88e isn't a bad keyboard, but it is very light with a thin plastic case. Any real piano player is going to end up with it on the ground after a couple of bars. The wood case gives it some mass so I can dig into the keys a little more.
Incidently this was another "not working and something is rattling around inside" ebay find for cheap. Plugging in a proper wallwart, everything was fine out of the gate. The "rattle" ended up being a quarter that must have fallen in between the keys! 90%+ of my non-working ebay buys are 100% working and the others are 15-30 minute fixes of simple things like jacks and switches.
I did splurge and spent money on a frontpanel designer panel, though. I don't have a good way to machine nice looking square holes for the pitch bend and mod wheels or the slot for the volume slider.
rjd2
PostPosted: Sun Sep 06, 2009 2:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
here's some pics of a CGS voltage divider i built. unfortunately, after much troubleshooting, its still not functioning, and is currently in the stillborn pile.....oh well....
 Filesize:  837.96 KB
 Viewed:  178 Time(s)
rjd2
PostPosted: Sun Sep 06, 2009 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
closer
 Filesize:  786.84 KB
 Viewed:  180 Time(s)
Inventor
Audio files: 267
PostPosted: Sun Sep 06, 2009 7:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
More Gear Porn! I want more Gear Porn! Show us your jacks, your switches, your pots and dials. Amaze us with circuitry all wired neatly. Give us this day our daily modular, and forgive us our power consumption. OK, heh, I'll stop. Rolling Eyes
Les
neandrewthal
PostPosted: Tue Sep 08, 2009 9:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Les
You rang.
Klee with bridechamber panel:
 Filesize:  1.06 MB
 Viewed:  204 Time(s)
 Filesize:  867.79 KB
 Viewed:  218 Time(s)
Dan Lavin
Audio files: 21
PostPosted: Wed Sep 09, 2009 3:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Neandrewthal,
That's awesome! I especially like the colored washers under the jacks!
regards, Dan
creekree
PostPosted: Wed Sep 09, 2009 5:53 am    Post subject: Reply with quote  Mark this post and the followings unread
i think these are the actual nuts.
RF
Audio files: 28
PostPosted: Wed Sep 09, 2009 6:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Great job neandrewthal - looking good.
I wasn't aware that those panels were available yet - I've been waiting on them.
I'm off to spend some $$ @ bridechamber Smile
bruce
www.sdiy.org/rfeng
adambee7
PostPosted: Wed Sep 09, 2009 6:55 am    Post subject: Reply with quote  Mark this post and the followings unread
That's a babe mate. Wiring nice and neat too. Good stuff man. Very Happy
TekniK
PostPosted: Wed Sep 09, 2009 7:28 am    Post subject: Reply with quote  Mark this post and the followings unread
so far thats the most beautifull klee for me.
the layout with the different knobs combinations and colors works surprisely very well together
neandrewthal
PostPosted: Wed Sep 09, 2009 10:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks everyone. Very Happy I only wish Rean made those soft touch knobs with pink pointers too Laughing
creatorlars
PostPosted: Thu Sep 10, 2009 12:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Twins for the growing arsenal of modules in the drum cabinet!
 Filesize:  124.84 KB
 Viewed:  179 Time(s)
TekniK
PostPosted: Thu Sep 10, 2009 2:18 am    Post subject: Reply with quote  Mark this post and the followings unread
cool! Very Happy
adambee7
PostPosted: Thu Sep 10, 2009 7:16 am    Post subject: Reply with quote  Mark this post and the followings unread
nice. Need to get a percussion cabinet myself. When it's done whack up a few mp3s for us to here. Very Happy
creatorlars
PostPosted: Thu Sep 10, 2009 7:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Will do. Right now it's got 9 voices (2x MPS, Clangora, UD-1, Cynare, 808 BD, 808 SD, 808 CP, 808 CB) and should have over 30 when done. The Midibox-based midi-to-trigger distribution bus is already in place. Need to finish up the rest of the 808 voices, since I already have panel space ready for them.
PostPosted: Thu Sep 10, 2009 9:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Lars - very nice, that drum synth is going well, how many more modules are you going for or have you set a cap ???
PostPosted: Thu Sep 10, 2009 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Thundarr - i like the fiber board panels, have you started your MFoS ball point pen collection, i'm at 14 right now Smile Smile.
What kind of system are you building up, is it abstract (noise, randomness) or a melodic (tuned vco's & cv convertor)
thundarr
PostPosted: Thu Sep 10, 2009 9:57 am    Post subject: Reply with quote  Mark this post and the followings unread
3 pens so far... I use them to do the labelling too Razz Nearly have the MFOS VCO and VCA done now, need to order some more boards from Ray next month Razz
I'm aiming to do slow, sweeping drone stuff, along with slow, heavy doom bass... I'll need a keyboard eventually but it's not a priority Smile
Heavy psychedelic rock
http://www.myspace.com/landbong
Meandering ambient drone doom
http://www.myspace.com/trollmannavildtoppberg
