davemoog
Posted: Thu Dec 24, 2009 11:19 am Post subject:
Here's what I've built - took most of the year but sounds pretty great (I think:-)
More details at http://minimalist.davidleith.com/DeitzModSynth6.html
Module 1 (Top to Bottom)
- EMS Noise/Colour, Buchla VC Lag (3 preset times plus external VC), CGS Slope/Sensitivity
- Buchal 208, output 1 prewired to lag thanks to vtl5c3
- Buss mixer/attenuvertors, YuSynth Dual Min/Max (1/2)
- ARP 4027 VCO/LFO with External Sync and Lo-Hi Ranges, triangle, saw, pulse with external PM modulation
- ARP 4014 Ring modulator thanks to Bergfotron
Module 2
- Dual Moog 9001 VCO with sine, triangle saw and pulse with external PM modulation thanks to T, C and P.
Module 3
- Dual Moog 911/911A Envelope generator with delay & cycle mode (10 volt gate), Multiples, YuSynth Dual Min/Max (1/2)
Module 4
- ARP 2500 1047 MUltimode Filter Resonator
- ARP 2600 4013 (epoxy) VC Ladder Filter,
- ARP 2600 4019 (epoxy) VCA
- Matrix Mixer with switches and External Preamp (ARP 1047)
95.18 KB |
| Viewed: |
528 Time(s) |
86.48 KB |
| Viewed: |
424 Time(s) |
Danno Gee Ray
Joined: Sep 25, 2005 Posts: 1351 Location: Telford, PA USA
Posted: Thu Dec 24, 2009 5:23 pm Post subject:
| Utterly awesome! |
adambee7
Joined: Apr 04, 2009 Posts: 420 Location: united kingdom
Posted: Fri Dec 25, 2009 3:35 am Post subject:
man thats sexy. nice job.  |
TekniK
Posted: Fri Dec 25, 2009 3:59 am Post subject:
| agree,one of the nicest pieces i seen,saw it before on some site or blog but din't know it was from u! |
Funky40
G2 patch files: 5
Posted: Sat Dec 26, 2009 5:38 am Post subject:
beside that it looks good it seems to be a very well thought out layout spacewise.
Finally function counts, not optics.
hey, all lovely work what you guys show  |
glacial23
Joined: Apr 30, 2008 Posts: 32 Location: Cleveland, OH
Posted: Sun Dec 27, 2009 4:15 pm Post subject:
I filled up my Frac system the other day - I started it in late August:
 _________________ glacialcommunications.com |
neandrewthal
Posted: Mon Dec 28, 2009 1:43 pm Post subject:
I haven't posted much in this thread because I hardly got anything done in the first 8 months and then scrambled to complete as much as possible when the school year ended. Everything in the top cabinet is from 2009. I hope to finish it in 2010.
Fritz Jerkster/Double Well/DGTS&H, Topp Buchla Quad Function Generator, CGS Modulo Magic/CV Cluster:
Haible Living VCOs, Tellun Doomsday Machine
Dual Flight of Harmony plague Bearer, Yusynth Fixed Filter Bank, Haible Interpolating Scanner:
CGS Triple Quad Logic Gate, CGS Master Divider/Dual MFOS Quantizer/Dual Tellun Lag Processor, Dual Fritz Teezer:
CGS Steiner Filter/Fritz Threeler, Fritz Quad All in EG:
Some guts:
 _________________ " I went through quite a few trannies til I found one I liked" - Wild Zebra |
TekniK
Posted: Mon Dec 28, 2009 4:57 pm Post subject:
some great panel designs here.
love the diana V panel. |
patchdub
Posted: Mon Dec 28, 2009 7:56 pm Post subject:
| absolutely awesome cabinet neandrewthal!!! |
peng
Posted: Mon Dec 28, 2009 11:05 pm Post subject:
Just finished this one.
Blacet Time machine to Modcan refit:
I hope the owner will be as happy receiving this as I was (finally) finishing it!!!
Two different Wave Multipliers with a bit extra and a Burst Generator:
Unfortunately, all these modules left my possession as soon as they were finished. It was hard to say goodbye
p.
Wish I had more but the metalphoto place screwed up my prototype!
Ohhh, I need an aspirin.
132.52 KB |
| Viewed: |
23413 Time(s) |
180.9 KB |
| Viewed: |
386 Time(s) |
100.82 KB |
| Viewed: |
377 Time(s) |
104.71 KB |
| Viewed: |
345 Time(s) |
xpmtl
Joined: Aug 10, 2007 Posts: 162 Location: Brussels, Belgium
Posted: Tue Dec 29, 2009 4:03 am Post subject:
i really like those. the time machine panel is a pure beauty. good job peng _________________ http://sdiy.xpmtl.net |
TekniK
Posted: Tue Dec 29, 2009 4:05 am Post subject:
| great look peng! |
Posted: Wed Dec 30, 2009 2:12 am Post subject:
| xpmtl wrote: | | i really like those. the time machine panel is a pure beauty. good job peng |
+1! Gorgeous!
jnuaury
Audio files: 9
Sebo
Posted: Tue Jan 05, 2010 5:23 pm Post subject:
I finished my WASP VCF a few weeks ago. I added 2 extra gain stages at the output
as the level was a little weak compared with other modules. One stage amplifies X2
the Distortion out, and the other amplifies the main output X2, so when the
Distortion is engaged I get a X4 gain.
I will post a general picture of the actual state of my modular soon.
159.86 KB |
| Viewed: |
336 Time(s) |
| You can see the little board glued to the main PCB. |
178.03 KB |
| Viewed: |
345 Time(s) |
_________________ Sebo
My Music:
https://www.facebook.com/cosaquitos/ |
peng
Posted: Wed Jan 06, 2010 2:35 am Post subject:
| Antimon wrote: | | xpmtl wrote: | | i really like those. the time machine panel is a pure beauty. good job peng |
+1! Gorgeous!
/Stefan |
Thanks guys!
The Time machine and the Wave Multipliers have modified circuits.
The TM CV VCA is modified so that the envelope follower, LFO, and External Input are pre VCA instead of post VCA. Originally, only the LFO goes thru the VCA.
The Wave mults have a boost switch that pushes the module into some intense overdrive. Plus a bunch of component value tweaks.
I'll try and get up a couple posts documenting the mods and I'll put them in their relevant sub forums.
p. |
adamon
Joined: May 15, 2009 Posts: 96 Location: Lawrence Kansas
Posted: Wed Jan 06, 2010 1:18 pm Post subject:
The caliber of work in here is amazing (just plain ridiculous at times!)! I'm almost embarrassed to post my stuff, but I suppose this will be a good benchmark to compare to at then end of 2010.
Here's how my system ended up at then end of the year. This past year was really the beginning of it all for me as far as diy synth stuff is concerned, so most of it is fairly basic. Most of the modules are lunetta-based stuff (various 40106 oscillators, some dividers, 4077 ring mods, and others...), but I got a few op-amp based modules in as well (some lfos and a couple of filters). Many thanks go out to everyone in the lunetta forum for all the inspiration!
I just got my first volumes of electronotes, so it's on in 2010!
Also, I built a little synth for emraldadrift as a gift a few weeks back (probably my favorite build of the year!).
| Adamon's modular at the end of 2009 |
1.02 MB |
| Viewed: |
373 Time(s) |
| Emraldadrift's holiday synth built by Adamon |
1.52 MB |
| Viewed: |
334 Time(s) |
_________________ www.soundcloud.com/adamon |
ErichBreakfast
Joined: Nov 30, 2008 Posts: 20 Location: Massachusetts
Posted: Thu Jan 07, 2010 9:14 am Post subject:
That module looks great. Where did you get those knobs? I was thinking about using some knobs like that on my next sequencer project. |
RF
Audio files: 28
Posted: Thu Jan 07, 2010 9:43 am Post subject:
Love the plexi in the suitcase adamon! Nice job.
bruce _________________ www.sdiy.org/rfeng
(Herb Deutsch to Bob Moog ~1963) |
The Bad Producer
Joined: Mar 08, 2009 Posts: 282 Location: The Manhole
Posted: Thu Jan 07, 2010 10:14 am Post subject:
| adamon wrote: | The caliber of work in here is amazing (just plain ridiculous at times!)! I'm almost embarrassed to post my stuff, but I suppose this will be a good benchmark to compare to at then end of 2010.
I totally agree, every time I look in here I'm newly amazed and inspired! (your work included adamon - looks great!)
| ErichBreakfast wrote: |
They look like Davies 1900 clones available from Smallbear in the USA, either in phenolic:
http://www.smallbearelec.com/Detail.bok?no=707
or ABS:
http://www.smallbearelec.com/Detail.bok?no=831
or in lots of different colours:
http://www.smallbearelec.com/Detail.bok?no=727
Charlie _________________ http://loudestwarning.tumblr.com/ |
jnuaury
Audio files: 9
Posted: Thu Jan 07, 2010 6:51 pm Post subject:
| The Bad Producer wrote: |
thanks and yes, they are the serge-alikes from smallbear.
if you are talking about the three knobs on top...
one of my friends gave me about a hundred 1k pots with 1/8" shafts that have those knobs on them _________________ az/gde
Flickr
YouTube |
Sebo
Funky40
G2 patch files: 5
Posted: Sun Jan 10, 2010 8:52 am Post subject:
| The Bad Producer wrote: | | adamon wrote: | The caliber of work in here is amazing (just plain ridiculous at times!)! I'm almost embarrassed to post my stuff, but I suppose this will be a good benchmark to compare to at then end of 2010.
Charlie |
+1 on all
love that little box too adamon. very stylish ! |
TekniK
Posted: Mon Jan 11, 2010 5:10 pm Post subject:
| Sebo wrote: | Hi:
Here is a picture of my modular as it was at december 2009 (now it have
a new module, jeje).
Nice system! |
Sebo
Posted: Mon Jan 11, 2010 6:59 pm Post subject:
| TekniK wrote: | | Sebo wrote: | Hi:
Nice system! |
Thanks!!! _________________ Sebo
My Music:
