| Would you prefer one PCB with 3 VCOs a la JH-5A, or 1 VCO per PCB with more features |
| One PCB with Oscillator Driver and 3 VCO cores (like JH-5A - cheap!) |
60% |
[ 62 ] |
| 1 PCB = 1 VCO (with many waveforms and inputs) |
39% |
[ 41 ] |
| Total Votes : 103 |
jhaible
Posted: Sat Dec 05, 2009 12:48 am Post subject:
Re: Vibrato Depth Sensitivity |
| dingebre wrote: | I've not seen this discussed, so I assume I have something wrong.
The vibrato depth is very sensitive. I see no effect on the scope (looking at the output of the driver) until about the 3:00 position. Then it increases very rapidly. If I put an open jack into VJK to break normaled ground, the control starts to show an effect at about 12:00 position, but still increases very rapidly.
That's intentional.
You use the front panel pot to set the threshold, and then use a modulation wheel to activate the vibrato. (Or aftertouch, or whatever.) The wide range of the front panel pot to set a threshold, is to adapt a wide range of possible potentiometer values for the mod wheel.
If you're *only* using the front panel pot, it may take a little practice to find the "sweet spot", but afterwards you can activate vibrato with just a tiny movement of your hand, and not turning a pot 270 degrees.
That's all for the typical vibrato effect. For general FM with various waveforms and high frequency range and amplitude range, you can use an external LFO, of course.
JH. _________________ "I tell you the truth, if anyone says to this mountain, 'Go, throw yourself into the sea,' and does not doubt in his heart but believes that what he says will happen, it will be done for him. Therefore I tell you, whatever you ask for in prayer, believe that you have received it, and it will be yours." (Mk 11,23f) |
davebr
Joined: Jun 09, 2007 Posts: 198 Location: portland, or
Posted: Sat Dec 05, 2009 9:40 am Post subject:
| dingebre wrote: | The vibrato depth is very sensitive. I see no effect on the scope (looking at the output of the driver) until about the 3:00 position. Then it increases very rapidly. If I put an open jack into VJK to break normaled ground, the control starts to show an effect at about 12:00 position, but still increases very rapidly.
Thanks.
David |
I added a 10K resistor from the center pin to the CW pin (ground) on the Depth control to make a semi-log response. This gives a more natural feel to the vibrato depth if you are just using the front panel control.
Dave |
dingebre
Joined: Aug 10, 2008 Posts: 270 Location: Salt Lake City, UT USA
Posted: Sat Dec 05, 2009 11:39 am Post subject:
Thanks JH and Dave. I'm just happy to know I didn't screw up something else when building (I assume you read my post about wiring the frequency pots...). I might try the 10K resistor.
Happy holidays to all, and a special and big thanks to everyone on this list who takes time to help and share their experience.
JH, a big thanks and Merry Christmas to you for making your designs not just available, but for all the support and patience.
David _________________ David M. Ingebretsen, M.S., M.E.
dingebre@3dphysics.net
http://www.xmission.com/~dingebre/Synthasystem.html |
Girts
Posted: Sat Dec 05, 2009 11:49 am Post subject:
I have found better Depth response with a 300 ohm resistor between CW pin and center pin. However, I am using a 10K pot and VJK is shorted with jumper for now.
btw, I wonder what control voltage is usable for the VJK (Vibrato depth CV)? |
jhaible
Posted: Sat Dec 05, 2009 11:55 am Post subject:
| Girts wrote: | I have found better Depth response with a 300 ohm resistor between CW pin and center pin. However, I am using a 10K pot and VJK is shorted with jumper for now.
Carefull with that 300 Ohm resistor!
If it's rated less than 1Watt, it may burn!
And worse: even if the resistor is rated high enough, the potentiometer may burn when it's left close to its ccw position!
This may really be dangerous - don't do it!!
(10k, or even 2k, will be ok, though.)
VJK: Whatever works for you, and is smaller than 15V.
Adjust R158 for the desired response.
But the real feature here is that you can simply connect a potentiometer here, without any external power supply.
Girts
Posted: Sat Dec 05, 2009 12:22 pm Post subject:
Thanks for warning, JH!
I will try external modulation to see how the Depth control will act without added resistor ...
and I will check if that potentiometer is still OK  |
/mr
Joined: Aug 05, 2007 Posts: 223 Location: Elektron City, Sweden
Posted: Sun Dec 06, 2009 4:07 am Post subject:
Haha, wonderful... we're all here because synthesizers are our lives, but now suddenly it's all about life or death!
Anyway, shunting potentiometers with a resistor to ground is a habit we should practice more often. There are many occasions where lin/log responses are not the optimal, and there is a lot tweakability to gan from adding some resolution to one end of the pot. Or to the middle of the pot, if it's bipolar.
Though, to get a large change in pot curve, the shunting resistor value often needs to be quite small compared to the pot value, and problems can arise with varying impedance issues or lethal currents as in the above example. Increasing both the pot and resistor values might be a solution in many cases. Stay alive!  |
dingebre
Posted: Wed Dec 09, 2009 12:11 pm Post subject:
I am happy to announce I finally got the first of two VCO's done.
After tracking down TWO bad panel pots (I did NOT overheat them and you can't prove I did ) it all seems to be working. I have never struggled so much with a module. I damaged more parts in this build than in every kit I have ever built combined, One multiturn frequency pot, two other panel pots, two or three transistors, mis-wired all three frequency pots, installed the wrong values for the high frequency trim pots, and could have labeled my panel mount trim pots better on the panel. So, that said the VCO's are humming along and I'm going to start the second board soon.
Merry Christmas, Happy Holidays, whatever you celebrate this time of year to you and yours.
Thanks again JH for your designs, very, very cool stuff.
Funky40
G2 patch files: 5
Posted: Sat Dec 12, 2009 4:51 am Post subject:
here are fotos of how i wired the fine tune ---> i solder a 3-pin header directly to the ICs.
Thatway i have the whole Board disconnectable whta is a good thing.
my camera is fucked up, shots from short work now ( in the past they didn't ) but modules i get very blurry.
| Description: |
| header for finetune wiring attached to the IC |
| Filesize: |
102.11 KB |
| Viewed: |
320 Time(s) |
| Description: |
| Filesize: |
118.03 KB |
| Viewed: |
311 Time(s) |
| Description: |
| two JH living VCOs in euroformat. sorry is blurry |
| Filesize: |
378.53 KB |
| Viewed: |
316 Time(s) |
dingebre
Varoudis
Posted: Tue Dec 22, 2009 1:11 pm Post subject:
where can I get the PCBs (if i can)?
thnx
tasos
EDIT! Sorry .. im stupid  |
neandrewthal
Posted: Tue Dec 22, 2009 9:53 pm Post subject:
Cool stuff! Might as well throw up a pic of mine too:
As you can see, it's on 2 separate panels since I don't have the equipment to make panels that large by myself. They are attached together by the PCB bracket. I also added a fine tune for each VCO, multiple outputs and a mixer. _________________ " I went through quite a few trannies til I found one I liked" - Wild Zebra |
The Bad Producer
Joined: Mar 08, 2009 Posts: 282 Location: The Manhole
Posted: Wed Dec 23, 2009 5:52 am Post subject:
Wow, really nice work from everyone, those Euro ones are tempting me back to that format from Frac, hmmmm.......
With bananas obviously.... _________________ http://loudestwarning.tumblr.com/ |
Funky40
G2 patch files: 5
Posted: Sat Dec 26, 2009 6:06 am Post subject:
for many projects euro is just a perfect format,
for some i would prefer 4HE.
i tryed btw. different Resistor for the fine tune.
IIRC Jürgen was speaking from 1M5.
i used 2M2 on my first triple VCO, but was not fine enough for my taste.
so i tested 3M3 on my second which gave me a little less than 2 semitones, so i went then with 3M.
I would recommend 3M as the vaule to choose for the finetune |
Luka
Posted: Sun Dec 27, 2009 5:41 pm Post subject:
just doing some testing before i fully power my vco up
jurgen what should the rails see on the 3046?
my vco 1+2 have +/- 15 on pins 1 and 13 but my vco3 has about +/-5
i have +15 going to R83 but for some reason it drops to 5v
is that correct? _________________ problemchild
melbourne australia
http://www.last.fm/user/prblmchild |
jhaible
Posted: Mon Dec 28, 2009 1:20 am Post subject:
| Luka wrote: | just doing some testing before i fully power my vco up
is that correct? |
There are no power "rails" on this chip - it's just a transistor pair, with 3 unused transitors included, and the substrate connected to the most negative voltage (about -0.7V, on pin 13).
Pin 1 sees (+15V) minus (0.7V fom eb drop of Q15) minus (the zener voltage of reverse biased Q16). The latter isn't exactly specified, but somewhere between 5 and 10 volts.
So your VCO3 looks ok, but the full supply voltage on the array in VCO 1 and 2 seems very wrong.
Luka
JoeMorris
Posted: Mon Dec 28, 2009 3:15 pm Post subject:
hi peoples, hoping one of you can help out a hapless rookie. Got my living vcos all set up again in situ... this time, I've got all three cores running well, I'd wired up one of the pulse outputs wrong before (doh!)...
But now, I have a problem I didn't have before, which is weird.
I can trace the signal for all 3 oscs all the way up to the amp section, into the TL072s and out the other side and up to the R135, R121 & R130 resistors on the output of the TL072s - but not on the other side of these three resistors (leading to the amp outputs which lead to my extra mixer board)... why is the signal not making it through? am I missing something obvious?
Many many thanks if someone can answer this for me!
Joe |
dingebre
Posted: Fri Jan 01, 2010 7:17 pm Post subject:
All done! |
WoooHooo!
Got the second one finished and it fired right up. I'll post photos later.
Thanks JH, and Happy New Year to everyone!
[EDIT]
OK, here's a photo of the pair racked up. You see my Frac Frequency shifter above to the right and a spot for a TAU Phaser above it which will be my next project.
There are also some Blacet VCO's, Phaser, Mixer, and Splitter shown, as well as a Synthasonic produced MFOS Phaser.
I must say the Living VCO's calibrated easier than any other VCO I've tuned.
David
| Description: |
| Pair of Living VCO's built into a Euro Rack. The space to the right will house a Doepfer module. Above to the right is a JH frequency shifter and the space above is for a TAU Phaser. |
| Filesize: |
226.62 KB |
| Viewed: |
268 Time(s) |
dingebre
Posted: Sat Jan 02, 2010 2:23 am Post subject:
Detune |
When I turn the detune knob, what sort of change in frequency should I hear?
I re-read the information on the website, and I think I am missing the point of the detune function and how it works.
jhaible
Posted: Sat Jan 02, 2010 2:34 am Post subject:
Re: Detune |
| dingebre wrote: | When I turn the detune knob, what sort of change in frequency should I hear?
David |
The linear Detune? Less than 1 Hz. For slow chorus-like beating in the bass range.
dingebre
Posted: Sat Jan 02, 2010 3:20 am Post subject:
Thank you JH. A couple more questions then please.
1. The detune pot is connected between the +/- 15 volt supply, so is "zero" detune when the pot is in the middle?
2. I think I still don't quite understand what detuning does. It detunes with respect to what? I know the answer is to experiment, but I'm not following what exactly this knob does. I guess I just thought is was just a fine-fine tuning knob, but clearly it is not that at all.
3. What is the most effective way to setup the detuing?
eg: CV into the driver
Set detune to "zero" (see question above)
Set desired frequency for VCO 1 through 3
Dial in desired detuning for VCO 1 through 3
Make wonderful music (or in my case, random, arythmic, atonal bleeps and burps)
Or is there a better way to setup the chorus of VCO's?
Maybe the best thing to do is just play with it...
jhaible
Posted: Sat Jan 02, 2010 5:36 am Post subject:
It's not complicated, once you figured it out.
1. Set all the Linear Detune knobs to center position.
2. Tune the 3 VCOs with the multiturn pots, just like you would do with any other VCOs. Tune them to get slow beating rate at the upper end of the keyboard, to get a nice "phasing" sound that sounds rich, but not overly detuned.
3. You will notice, that with that setting (and carefully adjusted V/Oct tracking), you will get an almost beat-free and rather lifeless sound at the lower end of the keyboard. (The typical V/Oct VCO problem.)
4. Now, while holding a low note, turn one of the Lin Detune Knobs to the left, the next to the right, and leave the 3rd one alone. You can hear the magic happen immediately
5. If you leave that setting from (4), and play a high note, it won't be much more detuned than before step (4). If you think it's too detuned, adjust it with the multiturn pot (not the linear detune pot).
6. With a little practice, this can be set up within a few seconds, and you have rich beating along the whole keyboard range, without sounding too detuned anywhere.
dingebre
Posted: Sat Jan 02, 2010 11:04 am Post subject:
Thanks JH.
David
[EDIT]
JH,
I tuned the way you described above and the linear detune worked perfectly and the "chorus" like sound at the low end was wonderful. Not too much so the "beat" was annoying, but enough to get a rich full sound with very little effort. I'm glad I built two...
JoeMorris
Posted: Tue Jan 05, 2010 6:10 am Post subject:
right... I haven't had much luck with replies to my silly issues recently which is fair enough because i realise people are busy...
But i'm hoping as this is quite precise i might be able to get some response here...
I'm getting there, but one of my oscillators seems to be running at a very high pitch compared with the other two... (at the lowest frequency pot setting it's still very high pitch)
I've fiddled with the T trimmer but that doesnt have a huge range and cant be the problem... Ive also checked the components visually with the other two oscillators that seem to work fine, and cant see any discrepancies..
Is there a simple problem that could explain this issue? |
