andrewF
Posted: Sat Mar 06, 2010 6:33 pm Post subject:
| j.dilisio wrote: | The board looks so simple for the amount of patch points there are on the panel.
I've always wondered how you could use an analog computer in a modular setup. Would you use it mostly as a CV generator/processor?
It would be cool to have a VU meter in there too. |
It is very simple, tho I really should make sure it works before saying that.
one good example of using an analogue computer with a synth is Dan Slater's Chaotic Sound Synthesis, you can see the 1st page here
It was common to have voltmeters on analogue computers, if I built this into a larger case it would have one.
| macumbista wrote: |
Consider me [fr]/[g]eekishly interested in any PCBs you might have for this project!!!!
D. |
| glacial23 wrote: |
Seconded. I was planning on building an analogue computer anyway - this would simplify matters a bit! |
no worries, once tested I intend to redesign the PCB to make it smaller (=cheaper) and then will do a larger run. Also considering getting panels made to suit the pactec case.
cheers
Andrew |
wmonk
Joined: Sep 15, 2008 Posts: 529 Location: Enschede, the Netherlands
Audio files: 15
Posted: Sat Mar 06, 2010 6:57 pm Post subject:
The Karplus Strong module by Inventor!
And you can see a little video on my blog: [url]woodymonk.blogspot.com[/url] It was streamed live to the people in the chat with my phone, so not the best sounds, but still nice  _________________ Weblog! |
slacker
Posted: Sun Mar 07, 2010 7:14 am Post subject:
Finally finished my first module, an ENS-76/CGS style VCO, nothing to look at compared to some of the amazing stuff in here, but apart from one slightly off centre socket I'm happy with it.
Obligatory guts shot
Looking lonely waiting for its friends
macumbista
Posted: Sun Mar 07, 2010 7:58 am Post subject:
| andrewF wrote: | | one good example of using an analogue computer with a synth is Dan Slater's Chaotic Sound Synthesis, you can see the 1st page here |
I had a feeling we'd been doing the same homework! _________________ Esoteric drones and nonlinear distortion
macumbista.net |
Joined: Apr 03, 2004 Posts: 24499 Location: The Netherlands, Enschede
Posted: Sun Mar 07, 2010 9:34 am Post subject:
| slacker wrote: | | nothing to look at compared to some of the amazing stuff in here |
They all started like that nice compact build! _________________ Jan
TekniK
Posted: Mon Mar 08, 2010 2:41 am Post subject:
| slacker wrote: | | Finally finished my first module, an ENS-76/CGS style VCO, nothing to look at compared to some of the amazing stuff in here, |
mistake,the format is awesome,am pretty sure it will looks cool when that case is filled up. |
DGTom
Posted: Mon Mar 08, 2010 6:06 am Post subject:
Awesome work slacker!
I really like that all in one line style. |
slacker
Posted: Mon Mar 08, 2010 1:46 pm Post subject:
| Thanks for the nice comments folks. Hopefully more to follow soon. |
RF
Audio files: 28
Posted: Sat Mar 13, 2010 3:30 pm Post subject:
Quad Bass ++ (Plus Lunetta)
Thomas Henry Quad Bass ++ board with Lunetta type counters/dividers/logic.
Logic included is a 4094 8 stage shift register, three 40106 clocks, 4024 divider, 4015 4 stage shift register, two XOR gates, a Divide by2/3/4/5/6/7/8 4017 circuit (a section of the CGS pulse divider), and two 4 input R/2R ladders for generating CV's. Iy uses mains power, the drum voices have individual and summed outputs and manual triggers. Banana and 1/4 inch so it'll play well with my Lunetta or modular.
I just finished a couple hours ago - Have not decided if I'll dress it up any more or not. (ie wood sides) Maybe too many colors of jacks and knobs... That may change too.
As I learn how to use it I'll make a vid or audio clip.
bruce
EDIT to add clip & comment -
Obviously I was going for the Headley Grange vibe on the recording....
180.15 KB |
| Viewed: |
349 Time(s) |
 Download (listen) |
| Filename: |
Drums1.mp3 |
3.18 MB |
| Downloaded: |
1334 Time(s) |
_________________ www.sdiy.org/rfeng
(Herb Deutsch to Bob Moog ~1963) Last edited by RF on Sat Mar 13, 2010 7:59 pm; edited 3 times in total |
loydb
Joined: Feb 04, 2010 Posts: 393 Location: Providence, RI
Posted: Sat Mar 13, 2010 6:27 pm Post subject:
| That is some dense panel! Congrats, great build. |
skylab76
Posted: Sun Mar 14, 2010 1:11 am Post subject:
I'm done with phase 1 of my modular named "Grendel" (ugly, but mean as hell)
Four VCOs, Two VCAs, Moog clone/Synthacon/MFOS 4 pole LP filters, 2 custom ADSRs, 3 LFOs, Rebote Delay, Knick Knacks here and there.
The "cabinet" is 100% Home Depot which is made up of oak planks (aisle 32), plexiglass front panels, 6 layers of black paint. To mount the panels, I used aluminum L strips which were screwed on to the top and bottom planks. The L strips were then threaded for 8/32 screw size. I'm adding another tier in the summer. |
Joined: Mar 28, 2006 Posts: 1452 Location: Kansas City, Mo USA
Posted: Tue Mar 16, 2010 5:54 pm Post subject:
New Clock Divider, Boolean Logic, and Schmitt Trigger module |
I completed the final troubleshooting on the Yusynth Boolean Logic and so this module is now up and running.
This module represents some "firsts" for me. All three PCBs are homemade -- the first three I've ever made.
The Schmitt Trigger circuit board is my own design -- nothing overly complicated but a chance for me to acquaint myself with Eagle software. The other boards are Yusynth designs.
The Schmitt trigger's output produces a trigger when both inputs go "high" and does not produce additional triggers until both inputs go low. Thus, I can delay the start of a note until a clock trigger and, once the trigger is received, suppress additional triggers until the note is lifted (and the gate goes back to zero).
I'm really having a lot of fun building new "stuff"!
| I decided to combine three different modules to conserve panel space -- Aries used to group related functions together in common modules. |
4.59 MB |
| Viewed: |
318 Time(s) |
| View of the Schmitt Trigger PCB (my first attempt to design circuitry with Eagle and to turn it into a PCB) and the Yusynth Clock Divider card. |
4.86 MB |
| Viewed: |
305 Time(s) |
| View of the Yusynth Boolean Logic PCB. I mounted the PCBs back to back (with spacers) to fit it all behind the panel. |
4.81 MB |
| Viewed: |
297 Time(s) |
_________________ -- Kevin
http://kevinkissinger.com |
mark_olson
Joined: Oct 26, 2006 Posts: 177 Location: Lawrence, Kansas
Posted: Tue Mar 16, 2010 7:44 pm Post subject:
Wow, Kevin!
Nice work.
Mark |
adambee7
Joined: Apr 04, 2009 Posts: 420 Location: united kingdom
Posted: Wed Mar 17, 2010 3:33 am Post subject:
Good job Kevin. Been thinking of this module aswell for a while. Made pcbs at work but not for myself at home. Will take the plunge. Post some music you've created with it.  |
Posted: Wed Mar 17, 2010 5:12 am Post subject:
my latest three modules using SMD got a frontpanel finaly. no wiring needed!
Tech Buddy at Random*Source |
j.dilisio
Posted: Wed Mar 17, 2010 7:23 am Post subject:
Fonik,. those are amazing.
You've got this diy thing down to a science. _________________ DRONEGOAT |
Posted: Wed Mar 17, 2010 7:28 am Post subject:
thanks for the laurels. however i will accept your comment as related to the hardware only, not for the circuits.
anyways, the hardest part for me was to find sockets, switches and potentiometers that matched in height (so consequently sockets and potentiometers are ordered directly from manufacturers in asia). _________________
Danno Gee Ray
Joined: Sep 25, 2005 Posts: 1351 Location: Telford, PA USA
Posted: Wed Mar 17, 2010 3:38 pm Post subject:
Kevin, Mathias,
You guys are machines! |
droffset
Joined: Feb 02, 2009 Posts: 515 Location: London area
toppobrillo
Joined: Dec 10, 2005 Posts: 766 Location: oakland, ca
Posted: Wed Mar 17, 2010 5:40 pm Post subject:
fonik- great job on those! I am making the transition to SMD for my modules as well... at least partially. it gets hard to squeeze everything behind these little panels  |
Inventor
Audio files: 267
Posted: Wed Mar 17, 2010 7:57 pm Post subject:
fonik, that is simply masterful! I shall have to follow in your footsteps someday, with your permission of course.
Posted: Wed Mar 17, 2010 10:53 pm Post subject:
fonic, beautiful workmanship! Wow! _________________ -- Kevin
adambee7
Posted: Thu Mar 18, 2010 2:50 am Post subject:
It will always get bigger (ahem). Mines grown twice the size in a year. That is going to be one nice groove machine. Lovely work.  |
Inventor
Audio files: 267
Posted: Thu Mar 18, 2010 7:20 pm Post subject:
I just gotta re-emphasize my astonishment at what fonik has revealed to us here. It's truly a whole new synth format. Noicely done fonik!
